    ZOOM /Scaling
    9 Posts 8 Posters 14.4k Views 9 Watching
    • impuislupusI Offline
      impuislupus
      So i tried the the default config/ zoom setting and dont seem to do anything i was wondering if some one could shed some light on the issue for me. ps im using a 47in tv and im trying to down scale the words as i made a Boo boo and cracked the edge of the screen
        SeaPanther
        I also tried using the zoom setting yesterday, both in in the main configuration (under the ip address whitelist) and inside of various modules. I saw no change to the size of anything, and I tried values from 10.0 to 0.1. Not sure of the proper format, i used both zoom: ‘0.5’, and zoom: 0.5,.
        Not sure if it makes a difference but I am running mine serveronly on a Pi3 and viewing on a web page on a Pi0.
        • F Offline
          FredSWG
          you can change it in css/custom.css file
           body {
           	zoom: 75%;
          I didn’t find why the config file value is not taken in consideration. I assume something is overwriting this value.
          • icekuhnI Offline
            icekuhn
            I set the zoom on 0.25 for a test, this worked. But thats much to small… I want to set it back to 1.0, but this doesn’t work anymore. The font keeps small. Changing the css/custom.css doesnt work for me too. Any Idea?
              jukums
              Ok, got same problem…
              Connecting the keyboard and hitting Ctrl+0 to reset zoom seemed to work.
              Seems that zoom value is being cached somewhere…
              Feedy88F 1 Reply Last reply Reply Quote 4
              • N Offline
                nagaculun
                Same issue here. It was fine before the latest update.
                  Reotch2 @nagaculun
                  @nagaculun
                  Try using @FredSWG fix above. The custom.css works great for me.
                  • N Offline
                    nagaculun @Reotch2
                    @Reotch2
                    Can’t do that. I have 2 set of config; day and night.
                    On day time, it would display all those weather, calendar, news feed and 3 clocks. Zoom is set to 2.
                    On night time, it would only show 1 clock, with zoom set to 6.
                    So the custom.css fix can’t be used or I have to create a separate custom.css.
                    • Feedy88F Offline
                      Feedy88 @jukums
                      @jukums said in ZOOM /Scaling:
                      Thanks a lot for this. I am currently in setup, so I still have a Keyboard connected and this did the trick.
