    MMM-Todoist
    9 Posts 5 Posters 3.6k Views 5 Watching
      MrCoads
      Hi everyone,
      I’m trying to get Todoist to work, however, for the projects ID, it seems that they changed this?
      I can’t insert this into the config.js as 6XFQcvJpXM3rMQwh because the it complains: [ERROR] Your configuration file contains syntax errors :(
      Line 56 column 18: Parsing error: Identifier directly after number .
      Is there a way to find the project ID another way?
        MrCoads @sdetweil
        Thanks! Was not the solution I was looking for.
        But I fixed it regardless.
        Wrote a script in VSC to connect to my project and it gave me the ID in JSON ;)
        Thanks anyways!
          sdetweil @MrCoads
          @MrCoads
          stuff in js
          if value is true or false or a number, no quotes
          otherwise quotes are required, single or double doesn’t matter as long as they are matched
            MrCoads @sdetweil
            Thanks anyways!
            • O Offline
              OwenLars @MrCoads
              @MrCoads Hi, I am having the same problem that you encountered trying to use MMM-Todoist.
              The Project IDs I am getting from Todoist are all alphanumeric, and I cant work out how to get numerical format project IDs to us with the MMM-Todoist module.
              You mentioned that you managed to create a script to extract the ID in JSON. Would you be able to provide any more specific detail? Are you able to share the script that you created?
                sdetweil @MrCoads
                @MrCoads put the ID in quotes?
                Does the url change?
                • O Offline
                  OwenLars @sdetweil
                  @sdetweil I tried the ID in quotes, this doesn’t help. The Todoist URL never changes, it is always the same alphanumeric, which does not seem to be compatible with the module.
                  S A 2 Replies Last reply Reply Quote 0
                    sdetweil @OwenLars
                    @OwenLars maybe the url changed too from what the code is using
                    • G Offline
                      Gabian 0 @OwenLars
                      @OwenLars Hi, this module is no more maintained, personnally I use the @ZachR19 fork, it works well.
                        angeliKITTYx @OwenLars
                        @OwenLars I was able to get the proper project ID by running this command in the terminal. I just set it the module yesterday.
                        curl -s \
                          -H "Authorization: Bearer xxxxyourapikeyxxxx" \
                          https://api.todoist.com/rest/v2/projects
