    MMM-Pir alternative for bookworm
    8 Posts 2 Posters 1.7k Views 2 Watching
      sdetweil @Muffex
      @Muffex a couple other pir modules were added to the 3rd party list
      also see
      https://forum.magicmirror.builders/topic/19362/googleassistant-and-related-modules
        Muffex @Muffex
        Hello again.
        Thanks @sdetweil :)
        I’m now using MMM-Universal-Pir from here: https://gitlab.com/khassel/MMM-Universal-Pir
        This is my config to turn the screen (connected via HDMI) on/off :
        module: "MMM-Universal-Pir",
                        hiddenOnStartup: true,
                                gpioCommand: "gpiomon -r -b gpiochip0 4",
                                onCommand: "vcgencmd display_power 1",
                                offCommand: "vcgencmd display_power 0",
                                deactivateDelay: 60 * 1000,
        regards
        Muffex
          Muffex @Muffex
          After switching to “dtoverlay=vc4-kms-v3d” in /boot/firmware/config.txt the commands did not work anymore.
          This is my current config:
                                  onCommand: "echo on | sudo tee /sys/class/drm/card1-HDMI-A-1/status",
                                  offCommand: "echo off | sudo tee /sys/class/drm/card1-HDMI-A-1/status",
            sdetweil @Muffex
            @Muffex yes the commands change. don’t know what to.
              sdetweil @Muffex
              @Muffex do those work,
                Muffex @sdetweil
                @sdetweil said in MMM-Pir alternative for bookworm:
                Hey @sdetweil,
                yes, now everything works as inteded. :)
                I was just thinking of others who may read this thread at a later date. Since bookworm is in the title I didn’t want to mislead them with the old vcgencmd which does not work with wayland. (At least in my case it didn’t.)
                regards
                  sdetweil @Muffex
                  @Muffex awesome! your prior post wasn’t clear to me
