    Needing help with Regions please
    5 Posts 2 Posters 763 Views 2 Watching
    • X Offline
      Xsoldier2000
      [alt text](MM Help.png image url)
      I’m trying to :
      1. Make the padding or margin around all my modules be like 1 pixel (custom css posted below) (edit: I had it stretched to the edges, made a couple changes to the css and lost the code to make it work)!
      2. Squish this bottom_right region down to just under the calendar and the css doesn’t seem to affect it.
      3. Make the bottom_center region right justified so the Current conditions are right next to the forcast
      I might not be doing things the right way, so if anyone has any better ideas, I’m all for learning.
      custom css:
        /* Region Definitions */
        .region .container .module {
        margin: 0px;
        background-color: rgba(0 0 0 /10);
        min-width: 300px;
        position: relative;
        .region.top.right {
          position: absolute;
          width: 80%;
          height: 90%;
       // .region.bottom.right {
          position: absolute;
          height: 30%;
          width: 16.5%;
        .region.bottom.left {
          position: absolute;
          width: 16.5%;
          .region.top.left {
          position: absolute;
          width: 16.5%;
       .clock .time {
          font-size: 75px;
        .anylist ul {
        margin: 0;
        font-size: 24px;
        padding: 0px;
        line-height: 25px;
        color: white;
        sdetweil @Xsoldier2000
        @Xsoldier2000 we define the module padding in
        css/main.css
        --gap-modules: 30px;
        you can override those in custom.css
        you dont need to change the regions themselves
        you can move your module right too
          @Xsoldier2000 also see the second link in my signature below about using dev window
          X 1 Reply Last reply Reply Quote 0
          • X Offline
            Xsoldier2000 @sdetweil
            @sdetweil yes, I was definitely the dev window, just didn’t know the terminology. Think I’ve read through your second link twice (might have nodded of there a couple times), but you pointed me in the right direction, thank you.
              @Xsoldier2000 yeh, the dev window has a lot of content
