    Default Caledar module not broadcasting or other modules not picking up broadcast (MMM--MonthlyCalendar, MMM-CalendarExt3)
    3 Posts 2 Posters 831 Views 2 Watching
      calyorbro
      I am trying to add a Calendar to my MM that shows the next 4 weeks. I figured either MMM–MonthlyCalendar, or MMM-CalendarExt3 does this well enough for my needs, however both modules dont seem to pick up on the CALENDAR_EVENTS broadcast from the default module.
      First here is the configuration of the Calendar module:
      			//position: "top_left", // Comment out to hide module
      				broadcastPastEvents: true,
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
      						color: "red"
      						symbol: "calendar-check",
      						url: "https://calendar.google.com/calendar/ical/USER%40gmail.com/private-XXXXXXXXXXXXXXXXX/basic.ics",
      I added the default US-Holidays to test. And this does work perfectly fine for the normal module, however when using either MMM–MonthlyCalendar:
      			module: "MMM-MonthlyCalendar",
      				mode: "fourWeeks",
      or MMM-CalendarExt3 :
      			module: "MMM-CalendarExt3",
      				weekIndex: 0,
      				weeksInView: 4,
      The calander does not show up. I checked the logs which seem to be telling that everything is working fine:
      [2025-02-15 18:11:09.989] [INFO]  Calendar-Fetcher: Broadcasting 517 events from https://calendar.google.com/calendar/ical/USER%40gmail.com/private-XXXXXXXXXXXXXXXXXXXXXX/basic.ics.
      [2025-02-15 18:11:10.681] [LOG]   [CALEXT2] calendar:0 >> Scanned: 231, Selected: 231
      [2025-02-15 18:11:11.276] [INFO]  Calendar-Fetcher: Broadcasting 24 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
      In the attached picture you can see the events loading perfectly in the default module(removed the private calendar for privacy). and not at all in the MMM-CalendarExt3 module. The weather does load however so I am thinking that this is an issue with Calander
        sdetweil @calyorbro
        @calyorbro if this is MagicMirror 2.30 did you put on the clipping fix?
        see the pinned items top of troubleshooting section
          calyorbro @sdetweil
          @sdetweil I did not see this, sorrz about that. Now both work perfectly thank you
          • S Scott-M referenced this topic on
