    Face recognition
    6 Posts 2 Posters 1.3k Views 2 Watching
    • N Offline
      notgood
      Can anyone guide me on how to install face recognition in mm on a nuc.i tried installing it on a pi 3 but I can’t get it to install dlib it gets stuck for hours or restarts.
      S N 2 Replies Last reply Reply Quote 0
        sdetweil @notgood
        @notgood nuc is running Linux? ubuntu maybe
        fundamentally install should be the same. i didn’t see anything arm/pi specific in its install instructions
          @notgood I just installed FaceReco-DNN on an Ubutnu 22.04 virtual machine on my mac. using MagicMirror 2.30.0, nodejs 20.18.1, python 3.10.12
          dlib build took 5 minutes. (had to install cmake which his instructions didn’t handle)
          • N Offline
            notgood @sdetweil
            @sdetweil my pi 3 couldn’t install dlib I did install cmake, I will try with nuc thank you
            • N Offline
              notgood @notgood
              I installed everything it seems to work since I use nuc I don’t have picamera and the module use picamera to detect I want to use webcam,Does anyone know how to use webcam instead of pi camera
                sdetweil @notgood
                @notgood looks like he changed the ocv interface to ONLY use pi camera
                if you look at the older version (1.0.5)
                you can see the code for other cameras, usepicamera:true was an option then
