    Need help MMM-touch MMM-pages MMM-page indicator
    27 Posts 7 Posters 10.6k Views 9 Watching
      sdetweil @tburk32
      @tburk32 maybe the dev console gives you access under the z-index for touch
      • T
        tburk32 @sdetweil
        @sdetweil I removed all of the other modules in my config.js file and experienced the same results. To go one step further with the z-index exploration, I added this to the custom.css.
        .MMM-Touch (position: absolute; z-index -1)
        Additionally, while having the dev console open, clicks with a mouse also register on MMM-Touch, so I it doesn’t seem like it’s unique to the display/touch function.
        I really appreciate your responses so far.
          sdetweil @tburk32
          @tburk32 you have an error there
          css has
          your z-index is missing both : and ;
          and -1 means background, down/further away , in the 3d stack
          so that puts other content on top of it, so touch wont work
          • T
            tburk32 @sdetweil
            @sdetweil thanks for pointing out the -1 index, I saw it as a resolution on another topic and figured I’d try. No values in the z-index seem to make a difference.
            While in devtools, I selected “restore defaults and reload” and the MMM-Touch inputs were no longer recognized, which aligns with the expectation that “the code doesn’t know”. This helped me realize that the Device toolbar (ctrl+shift+M) has to be displayed for the inputs to be recognized again, either with a touch or a click.
              sdetweil @tburk32
              @tburk32 did you enable touch events in custom.css
              cause they are disabled by default in main.css
              main.css
              html {
                cursor: none;
              custom.css
              html {
                cursor: default;
              • T
                tburk32 @sdetweil
                @sdetweil changing the cursor value doesn’t seem to make a difference. The touch functionality works for mmm-Calendarext3, to select a day, clicking on the mmm-page-indicator to change pages and mmm-Microsofttodo to complete tasks, so it doesn’t seem to be a problem aside from mmm-Touch not registering the values unless in devtools with the device toolbar open.
                  sdetweil @tburk32
                  @tburk32 so touch is under ext3
                  put touch on top then ext3 wont work
                    68jeeper
                    @tburk32 were you able to get this going? I am attempting to do the same and it is not working for me either.
                    S T 2 Replies Last reply Reply Quote 0
                      sdetweil @68jeeper
                      @68jeeper what is not working?
                      6 1 Reply Last reply Reply Quote 0
                        68jeeper @sdetweil
                        @sdetweil MMM-Touch. I have it setup exactly as shown in this thread, and I cannot get the swipe to do anything. Just like @tburk32, the touch screen works on CX3 and Page Indicator so I know my touch screen is working. Any advice?
                          sdetweil @68jeeper
                          @68jeeper well, I can’t get touch to trigger at all… only thing in bottom_bar…
                          (on my mac with mouse)
                          • T
                            tburk32 @68jeeper
                            @68jeeper yes! Sorry for the delayed response, I didn’t receive any notifications that you tagged me in this post.
                            My solution was to use (https://github.com/JanLoebel/mmm-touchgestures). Hammer.js seems to be the difference and why this one works. The documentation was challenging for me ti follow but I was able to get it working through trial and error. My config look like this for MMM-touchgestures
                                module: 'mmm-touchgestures',
                                    gestures: {
                                        "swipe": {
                                            enabled: true,
                                            threshold: 50
                                    actions: {
                                        "swiperight" : function() {
                                            return "PAGE_INCREMENT";
                                        "swipeleft" : function() {
                                            return "PAGE_DECREMENT";
                                        "swipeup" : function() {
                                            console.log("Triggered swipeup");
                                        "swipedown" : function() {
                                            console.log("Triggered swipedown");
