    SD Card Full - Can't Install New Modules
    4 Posts 2 Posters 958 Views 2 Watching
      robertybob
      Hi, long time member, first time posting for a while! I’ve set up my MagicMirror installation from scratch, managed to install a handful of modules but now when trying to install MMM-Remote I get an error saying the SD card is full.
      I’ve seen a few similar posts here, but nothing within them is helping me.
      This is the contents of df -h
      Filesystem      Size  Used Avail Use% Mounted on
      udev            327M     0  327M   0% /dev
      tmpfs            93M  1.2M   91M   2% /run
      /dev/mmcblk0p2  6.7G  6.3G   16M 100% /
      tmpfs           461M   12M  450M   3% /dev/shm
      tmpfs           5.0M   12K  5.0M   1% /run/lock
      /dev/mmcblk0p1  510M  101M  410M  20% /boot/firmware
      tmpfs            93M   48K   93M   1% /run/user/1000
      and the contents of sudo find / -xdev -maxdepth 1 -type d -exec du -s {} ; | sort -rn
      du: cannot access '/run/user/1000/gvfs': Permission denied
      du: cannot access '/run/user/1000/doc': Permission denied
      du: cannot access '/proc/5110/task/5110/fd/3': No such file or directory
      du: cannot access '/proc/5110/task/5110/fdinfo/3': No such file or directory
      du: cannot access '/proc/5110/fd/4': No such file or directory
      du: cannot access '/proc/5110/fdinfo/4': No such file or directory
      du: cannot access '/proc/5121/task/5121/fd/3': No such file or directory
      du: cannot access '/proc/5121/task/5121/fdinfo/3': No such file or directory
      du: cannot access '/proc/5121/fd/4': No such file or directory
      du: cannot access '/proc/5121/fdinfo/4': No such file or directory
      6675246 /
      4366752 /usr
      1204020 /home
      801968  /var
      260014  /boot
      24744   /root
      9272    /opt
      7148    /etc
      1228    /run
      68      /tmp
      16      /lost+found
      4       /srv
      4       /mnt
      4       /media
      0       /sys
      0       /proc
      0       /dev
      in case either of those helps :)
      I installed the 32 bit RaspiOS and used the install script.
      Is there anything I can uninstall to make more space? 4.3GB used within /usr seems extremely high?
        sdetweil @robertybob
        @robertybob usually means the sd card has failed
        • R robertybob has marked this topic as solved on
          robertybob @sdetweil
          @sdetweil Ah, yeah I think you’re right. I’ve swapped to a different SD card and I’m not having the issue anymore. Thanks!
            @robertybob awesome
            backup/backup/backup
