    How to communicate with magic mirror from a second raspberry pi?
    5 Posts 2 Posters 888 Views 2 Watching
      raspberrypi9
      I want to use the MMM-gestures module which requires that you connect a grove gesture sensor to the GPIO of the raspberry pi that is running your magic mirror. That raspberry pi is attached to a frame that is mounted to my bathroom wall and is totally not easily accessible. So instead I would like to connect the grove gesture sensor to the gpio of a second raspberry pi that will talk over the WiFi network to the pi that runs my mirror. What is the best way to make this pi to magic
      Mirror connection happen?
      Thanks so much for your help.
        sdetweil @raspberrypi9
        @raspberrypi9 you will have to use something like socket io between the two systems
        node_helper on the MagicMirror side, maybe some node app on the other (sensor)
        if you used a second MagicMirror on the sensor machine you could do an logical send notification to the mirror node_helper
        at the point it senses and the mirror would forward that on to the module side
          @raspberrypi9 the MagicMirror socketNotifications use socketio under the covers
          so at the sensor side you can send the same data the sendSocketNotification would have sent up to the module to the mirror side which can forward it up to the module
          pretty small mods on each side, all in the node helper
            @raspberrypi9 see here
            https://github.com/sdetweil/MMM-Gestures
            branch withremote
            config parms
            role : "none"(default, normal execution)| "server"| "remote"
            in role=remote (with sensor)
            server=url   in your wall, server: "http://mirror:port"
            I also lifted the commands for monitor off/on to config
            	power_on_command: 'vcgencmd display_power 1',
            	power_off_command: 'vcgencmd display_power 0'
            that way you can config them
            so the remote listens for the arduino like always, but sends the data to the server side
            the server side sendSocketNotification to the module like always
            the server side does NOT attempt to contact arduino
            tested with local fixed list of gesture commands, two instances,
            one server
            one remote
            hard coded to set in node_helper test_local:true (defaults to false)
              @raspberrypi9 i deleted the duplicate topic
