    MMM-CalendarExt3Journal - How to set colors for calendars?
    4 Posts 2 Posters 760 Views 2 Watching
    • N Offline
      nobbistyles
      I’m new to MM2 and tried to find a clear answer to my question but was not really able to find it.
      The Goal is a Senior-Calender for my very old parents with dementia showing only those informations they need. The calender “Abfall” and “Feiertag” should have a white background, “Mom” should be yellow, dad should be “green”.
      I used the standard calender app to define my calenders, set background colors but they don’t appear in Ext3Journal. I also tried to work over the eventTransformer function with symbol but this also didn’t work (maybe my syntax was wrong because everything appeared in the first defined color).
      Attached my current config.js:
      /* Config Sample
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
       * You can use environment variables using a `config.js.template` file instead of `config.js`
       * which will be converted to `config.js` while starting. For more information
       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
      let config = {
      	address: "localhost",	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
      	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
      	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
      	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
      	language: "de",
      	locale: "de-DE",   // this variable is provided as a consistent location
      			   // it is currently only used by 3rd party modules. no MagicMirror code uses this value
      			   // as we have no usage, we  have no constraints on what this field holds
      			   // see https://en.wikipedia.org/wiki/Locale_(computer_software) for the possibilities
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			module: "weather",
      			// position: "top_center",
      				weatherProvider: "openmeteo",
      				type: "current",
      				lat: ?,
      				lon: ?
      			module: "weather",
      			// position: "top_right",
      			header: "Wetter Vorhersage",
      				type: "forecast",
      				lat: ?,
      				lon: ?			}
      			header: "Kalender",
      			// position: "top_left",
      				coloredBackground: true,
      						symbol: "calendar-check",
      						url: 'webcal://localhost:8080/modules/ical/Abfall2025.ics',
      						bgColor: '#FFFFFF'
      						url: 'webcal://localhost:8080/modules/ical/feiertag.ics',
      						bgColor: '#FFFFFF'
      						fetchInterval: 1000 * 60 * 1,
      						symbol: "fa-solid fa-venus",
      						url: "google cal mom",
      						bgColor: '#FFFF00'
      						symbol: "fa-solid fa-mars",
      						url: "google cal dad",
      						bgColor: '#00FF00'
      			module: "MMM-CalendarExt3Journal",
      			position: "middle_center",
      						height: '50vh',
      						width: '100%',
      						locale: 'de-DE',
      						staticWeek: false,
      						staticTime: true,
      						days: 7,
      						hourLength: 12,
      						beginHour:  8,
      						dateHeaderOptions: {
      							day: 'numeric',
      							weekday: 'long'
      						calendarSet: ["Abfall", "Feiertag", "mom", "dad"],
      Perhaps someone can point me in the right direction?
        sdetweil @nobbistyles
        @nobbistyles in MagicMirror calendar its just color, not bgColor. you are changing the color of the text, not the background
        then Ext3 will pick that up
        ext3 eventTransformer is a routine that gets passed every event
        eventTransformer:  (evt)=>{
           if(evt.?????){ // check event field for needing to be changed
               //do something to this event
          //return the modified evt
          return evt
        • N Offline
          nobbistyles @sdetweil
          Thank you.
          Finally I solved it with:
          eventTransformer: (ev) => {
          							const customEvents = [
          								{ keyword: "Mum", symbol: ["fa-solid fa-venus"], color: "yellow" },
          								{ keyword: "Dad", symbol: ["fa-regular fa-mars"], color: "green" },
          							const found = customEvents.find((condition) => {
          							return ev.title.search(condition.keyword) !== -1
          						if (found) {
          							ev.icon = [ found.symbol ]
          							ev.color = found.color
          						return ev
          • N nobbistyles has marked this topic as solved on
            @nobbistyles cool
