    MMM-OpenWeatherForecast... CSS
    8 Posts 2 Posters 1.4k Views 2 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      I wanna move the wind icon to the right of it’s cell… How to do this?
      Custom CSS at present:
      /* Weather Alerts */
      .MMM-OpenWeatherForecast .weather-alert {
        display: none;
      .MMM-OpenWeatherForecast .weather-alert .weather-alert-title {
        display: none;
      .MMM-OpenWeatherForecast .weather-alert .weather-alert-description {
        display: none;
      .MMM-OpenWeatherForecast .weather-alert .weather-alert-source {
        display: none;
      .MMM-OpenWeatherForecast .module-content {
        width: 620px;
      .MMM-OpenWeatherForecast .wrapper.tiled .forecast-container .forecast-item .time,
      .MMM-OpenWeatherForecast .wrapper.tiled .forecast-container .forecast-item .day-name {
        font-size: unset;
      .MMM-OpenWeatherForecast .wrapper.tiled .forecast-container .forecast-item > *,
      .MMM-OpenWeatherForecast .wrapper.tiled .forecast-container .forecast-item > * {
        font-size: unset;
      .MMM-OpenWeatherForecast .wrapper.tiled .forecast-container .forecast-item .temperature,
      .MMM-OpenWeatherForecast .wrapper.tiled .forecast-container .forecast-item .temperature-container {
        font-size: unset;
      .MMM-OpenWeatherForecast .wrapper.table .forecast-container {
        font-size: unset;
      .MMM-OpenWeatherForecast .wrapper.table .forecast-container .forecast-item > span,
      .MMM-OpenWeatherForecast .wrapper.table .forecast-container .header-row > span {
        font-size: unset;
        font-size: unset;
        sdetweil @BKeyport
        @BKeyport see the second link in my signature below
        And google search
        Move icon to the right on web page
        The second will give you styles to try
        The first will give you the tool to test with
        • BKeyportB Offline
          @sdetweil I’ve tried everything I could think of, and can’t get it to translate to custom CSS.
            sdetweil @BKeyport
            @BKeyport if you can do it in the dev window just copy paste and add the module name prefix.
            I don’t use that module
            Use the dev window , select the element, maybe element parent right-justify
              @BKeyport care to share config without api key
                @BKeyport
                using the default everything config
                google search result
                https://stackoverflow.com/questions/56289240/how-to-move-the-icon-to-the-right-end
                and with
                .MMM-OpenWeatherForecast .wind-header {
                   float;right;
                • BKeyportB Offline
                  @sdetweil odd - I tried that before and it didn’t work. Now it does.
                  CSS man.
                  Thanks.
                    sdetweil @BKeyport
                    @BKeyport not me. I just tried what Google search results suggested
                    Key item the style was on the span, not the img
