    MMM-Config with Message "builder encountered a problem, see MagicMirror messages for info"
    11 Posts 2 Posters 1.8k Views 2 Watching
      sdetweil @dphotograph
      @dphotograph can you show the rest of the startup messages please
        @dphotograph i am not near my system for a couple hours
        but you could try one test
        in the MMM-Config folder do
        node -c xxx
        xxx is that defaults filename
        if all is good you should get no results, and back to the prompt
        i don’t See anything quick look
          dphotograph @sdetweil
          @sdetweil Hello
          Thank You for the fast response
          it looks like there is a typo in the defaults file
          node -c defaults_17951887168800.js
          /home/Admin/MagicMirror/modules/MMM-Config/defaults_17951887168800.js:69
                          language: "---!config.languag"e
          SyntaxError: Unexpected identifier 'e'
              at wrapSafe (node:internal/modules/cjs/loader:1378:20)
              at checkSyntax (node:internal/main/check_syntax:78:3)
          Node.js v20.18.1
          in the line 69 is this
          But now that i now that can i change this my self?
          if i change it myself, on the next restart “pm2 restart 0” it is back to the typo :-O
          Thank you
            @dphotograph also, do you know the rough change you made last? installed a module?
              i think the last ones are
              MMM_homeassistant_sensors
              MMM_HomeAssistantDisplay
              MMM_SteamPlaytime
              Unfortunately, I was too impatient and installed three modules at once.
              Typical beginner’s mistake
                i just removed the Steam Playtime from MM now it is back to normal :-)
                i think i can live without it ;-)
                But really! Thank You for the help to indentify the Problem :-)
                S 3 Replies Last reply Reply Quote 0
                  @dphotograph thanks the discovery of all the module config contents is pretty tricky
                  ill look at this shortly
                    @dphotograph did you install the modules thru the MMM-Config installer?
                      @dphotograph you should have seen this in the logs, MagicMirror
                      startup messages
                      --------------------MMM-Config
                      module MMM-SteamPlaytime has an error in the construction of its defaults section
                      the error line is 		language: "---!config.languag"e
                      please change it to the literal value of the referenced variable
                      and restart MagicMirror
                      because you are using pm2, you will have to ask to display more lines of output than the default 15
                      for example
                      pm2 logs --lines=100
                      100 can be any number, default is last 15…
                        @dphotograph you can use that module again now
                        git pull
                        then restart MagicMirror
