    MMM-CalendarExt3 and MMM-MonthlyCalendar blank
    59 Posts 3 Posters 24.0k Views 3 Watching
      Scott-M
      I didn’t do either, I just ran your script from first run on the OS on the first 2 cards. On the other 2 cards, on first run of the OS I entered
      sudo apt update
      sudo apt full-upgrade
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
      The only difference between them is your script not updating the system. It may all just be a coincidence and someone else with same hardware verifying would be helpful.
        sdetweil @Scott-M
        @Scott-M ah… ok, I don’t do full-upgrade… only upgrade
        Use apt upgrade for routine updates when you don't want to risk removing packages.
        Use apt full-upgrade when you need to ensure that all packages are up-to-date, even if it means removing some packages.
        Be cautious when using apt full-upgrade as it can potentially remove packages that you might need.
        but it seems that full-upgrade handles some dependencies NOT handled by upgrade, which seems like a bug to me… whats the point of upgrade if dependencies aren’t handled…
          sdetweil @Scott-M
          @Scott-M if you have a hankering to run another test, run the script from the test branch for next release… it will still get 2.30 , this does full-upgrade
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/v231/raspberry.sh)”
            Scott-M @sdetweil
            @sdetweil Bear with me, I have run it 3 times now and it seems to freeze / stop during the upgrade, I can’t see where in the upgrade process it is happening so I have modified the script to output to the treminal during the upgrade instead of the log after it has finished and running it locally on the Pi
            Will post back later…
            I am assuming the ugrade ran into a problem somewhere, I had left it for nearly an hour and progress hadn’t moved.
            Update::
            I think the issue is that despite having --assume-yes in the apt-get upgrade command it is still stopping and asking :
            Configuration file '/etc/xdg/labwc-greeter/autostart'
             ==> File on system created by you or by a script.
             ==> File also in package provided by package maintainer.
               What would you like to do about it ?  Your options are:
                Y or I  : install the package maintainer's version
                N or O  : keep your currently-installed version
                  D     : show the differences between the versions
                  Z     : start a shell to examine the situation
             The default action is to keep your current version.
            *** autostart (Y/I/N/O/D/Z) [default=N] ?
            But there is no output to terminal so you can’t answer.
              sdetweil @Scott-M
              @Scott-M that lovely problem again… thanks
                Scott-M @sdetweil
                On the plus side… It worked after answering Yes and MagicMirror started.
                It did take an unusually long time intalling dependencies and again fixing sandbox permissions. I almost gave up but it did finish, and works
                  sdetweil @Scott-M
                  @Scott-M yes, how to avoid the prompt and handle it some other time
                  searching leads to adding this in front of the apt full-upgrade command
                  DEBIAN_FRONTEND=‘noninteractive’
                  like this
                  DEBIAN_FRONTEND=‘noninteractive’ apt full-upgrade -y
                    Scott-M @sdetweil
                    @sdetweil said in MMM-CalendarExt3 and MMM-MonthlyCalendar blank:
                    That did not seem to make any difference, I tried apt-get update and then DEBIAN_FRONTEND=‘noninteractive’ apt-get --assume-yes full-upgrade
                    but was still asked about the config file /labwc-greeter/autostart
                      sdetweil @Scott-M
                      @Scott-M thanks… SO much fun…
                      I am trying to test on my pi5 , I am remote from my home office, and do not have my hdmi/micro adapter… so am trying headless…
                      pi imager, set ssh on, use pw authentication,
                      pi boots, ssh is on, but password doesn’t work…
                      using mac and ubuntu vm , and windows vm…
                      also of interest is that the wifi connection also does not work , only ethernet
                        Scott-M @sdetweil
                        Luckily I had a slow week at work!
                        This seems to have worked:
                        sudo apt-get -y  -o Dpkg::Options::=“–force-confdef” -o Dpkg::Options::=“–force-confnew” full-upgrade
                        I have brought my Pi5 home, and a couple of micro SDs so happy to test when I can. I do have a lot of driving chilren around to do but some time in between.
                          sdetweil @Scott-M
                          @Scott-M thank you very much
                          ok, I’ve updated raspberry.sh on the v231 branch
                          let me know what you find when u can
                            Scott-M @sdetweil
                            These seems to be a subtle difference between our keyboard layouts perhaps,
                            raspberry.sh has this line
                            upgrade_result=$(sudo apt-get -y  -o Dpkg::Options::=“–force-confdef” -o Dpkg::Options::=“–force-confnew” full-upgrade | pv -l -p)
                            but the quotes around –force-confdef and –force-confnew are the wrong type . Should be:
                            upgrade_result=$(sudo apt-get -y  -o Dpkg::Options::="–force-confdef" -o Dpkg::Options::="–force-confnew" full-upgrade | pv -l -p)
                            It causes this error:
                            dpkg: error: need an action option
                            Type dpkg --help for help about installing and deinstalling packages [*];
                            Use 'apt' or 'aptitude' for user-friendly package management;
                            Type dpkg -Dhelp for a list of dpkg debug flag values;
                            Type dpkg --force-help for a list of forcing options;
                            Type dpkg-deb --help for help about manipulating *.deb files;
                            Options marked [*] produce a lot of output - pipe it through 'less' or 'more' !
                            E: Sub-process dpkg --set-selections returned an error code (2)
                            E: Couldn't record the approved state changes as dpkg selection states
                            Maybe just replace the quotes rather than copy and pase. I noticed the same thing when I copied the link you sent previously for the test branch.
                              sdetweil @Scott-M
                              @Scott-M I copied directly from your original post, it also shows the curved quotes
                              pushed fix
                              S S 2 Replies Last reply Reply Quote 0
                                Scott-M @sdetweil
                                @sdetweil So it does, not sure why, I copied it from the terminal window.
                                  sdetweil @Scott-M
                                  @Scott-M said in MMM-CalendarExt3 and MMM-MonthlyCalendar blank:
                                  the MagicMirror forums assume word processing for quotes unless in a code block
                                  once you save it, poof… it will never change back automatically
                                  so it looks like you decided to add the code black later… (just experience )
                                    @Scott-M note this latest fix also changes MagicMirror.sh to detect which window manager is running (wayland or labwc) and use the different start command if detected
                                      Scott-M @sdetweil
                                      I probably did add the code block after. Lesson learned! And this is partly why I am having more issues with this. It has been very frustating, after it worked last night, it isn’t now.
                                      I think I know what the issue is but it is time consuming writing the SD image and running the script so if you can bear with me. I want to test it at least twice before I update here.
                                      I suspect the 2 dashes before
                                      --force-confdef
                                      --force-confnew
                                      have been replaced by a single dash of a different character type. Again, because I put the code block around the text after I copied it.
                                      This should be the correct code but let me test again to make sure. It has worked once, just want to do it again and will update.
                                      sudo apt-get -y -o Dpkg::Options::="--force-confdef" -o Dpkg::Options::="--force-confnew" full-upgrade
                                      In the mean time, the above code will auto select the default option if one is available and then answer Yes if there is no default. In the case of the prompt that was appearing, the old configuration file ‘/etc/xdg/labwc-greeter/autostart’ is kept. If you want the package maintainers file instead just remove the first option:
                                        sdetweil @Scott-M
                                        @Scott-M yes the double dash was replaced with single… new update pushed…
                                          Scott-M @sdetweil
                                          It seemed to get through the upgrade stage very quickly and
                                          apt-get upgrade  started
                                          apt-get upgrade result =rc=0 Reading package lists...
                                          Building dependency tree...
                                          in the log seems to show the upgrade didn’t work. I will run the script locally on the pi and send the output to the termnial to see what is happening but it won’t be tonight, I have to go out now.
                                          Update tomorrow…
                                            Scott-M @Scott-M
                                            MagicMirror did run though…
                                            • 3 / 3
