    ERROR:gbm_wrapper.cc(253) Failed to export buffer to dma_buf: No such file or directory
    15 Posts 3 Posters 10.9k Views 3 Watching
      sdetweil @dathbe
      @dathbe said in ERROR:gbm_wrapper.cc(253) Failed to export buffer to dma_buf: No such file or directory:
      export ELECTRON_DISABLE_GPU=1
      the default now is disabled…
      and the env var has changed to
      export ELECTRON_ENABLE_GPU=1
      to turn it on
        dathbe @sdetweil
        No luck. with DISPLAY=:0 npm start, I get the long list of errors, but everything seems to work ok with the mirror. with
        WAYLAND_DISPLAY=wayland-1
           npm run start:wayland
        It throws other errors and gets stuck in what seems to be a restart loop.
        0|mm  | [3351:0415/211257.942494:ERROR:wayland_connection.cc(199)] Failed to connect to Wayland display: No such file or directory (2)
        0|mm  | [3351:0415/211257.942729:ERROR:ozone_platform_wayland.cc(276)] Failed to initialize Wayland platform
        0|mm  | [3351:0415/211257.942774:ERROR:env.cc(257)] The platform failed to initialize.  Exiting.
        0|mm  | /home/mmuser/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
          sdetweil @dathbe
          @dathbe yeh, thats what I found too…
          maybe its labwc display now?
          from the labwc doc,
          https://labwc.github.io/labwc-config.5.html
          it sounds like DISPLAY is the correct variable
          The autostart file is executed as a shell script after labwc has read its configuration and set variables defined in the environment file. Additionally, the environment variables WAYLAND_DISPLAY and (when labwc is built with Xwayland support) DISPLAY will be defined
            dathbe @sdetweil
            I tried all three options in raspi-config > Advanced > Wayland (those being 1) X11, 2) Wayfire, and 3) Labwc), and was getting the same error on all of them. I went back to Labwc because my understanding is that is the current recommended.
            I’ve tried many different combinations. Anything having to do with start:wayland seems to truly fail and get stuck in a restart loop. npm run start:wayland technically works, but throws about 20 ugly error messages on start.
            Various options I’ve tried:
            # Work with error messages
            # Cause endless start loop
            DISPLAY=wayland-1
              sdetweil @dathbe
              @dathbe restart loop is pm2, its job is to keep the app running
                dathbe @sdetweil
                @sdetweil Ok. When I have some time, I’m going to test an install with 32-bit PiOS.
                  sdetweil @dathbe
                  @dathbe 32bit is x11 only . as i recall
                    dathbe @sdetweil
                    @sdetweil It appears to load labwc by default, but either way it didn’t do anything different – fails to start with start:wayland and multiple phantom errors with start. I guess I just have to close my eyes and not read the logs on startup. Though weird it’s doing it with my Pi 4B, but not my Pi 2B.
                      sdetweil @dathbe
                      @dathbe yeh some config setup, i think something in /boot/config. txt
                        dathbe @sdetweil
                        @sdetweil In case for some reason it’s helpful, I’ve reviewed the contents of /boot/config.txt from my two devices (4B gets errors, 2B does not).
                        In 2B, not in 4B:
                        #dtoverlay=vc4-kms-v3d
                        # see https://forums.raspberrypi.com/viewtopic.php?p=1507622#p1507247
                        dtoverlay=vc4-fkms-v3d
                        In 4B, not in 2B:
                        # Run in 64-bit mode
                        arm_64bit=1
                        [cm5]
                        dtoverlay=dwc2,dr_mode=host
