    Calendar EXT3 not displaying either local or remote
    5 Posts 2 Posters 891 Views 2 Watching
    • K Offline
      Kayos
      I have moved this from my build thread.
      I tried last night and this morning and completely failed to get EXT3 showing anything
      Base Setup
      MagicMirror v2.31.0
      Raspberry Pi 4 Model B (ARM64)
      Debian 12 / Raspberry Pi OS Bookworm
      Initial install using default Electron setup (v35+)
      Node.js initially v22 (required by MM), later downgraded to v18 for compatibility
      What Worked -
      EXT3 loaded successfully (no module errors)
      calendar module fetched events from:
      Outlook 365 ICS feed
      GOV.UK Bank Holidays feed
      EXT3 debug logs confirmed:
      Events were parsed and saved
      Views and scenes were initialized
      DOM was constructed in memory
      clock and other modules rendered normally
      What Didn’t Work
      EXT3 views never displayed (month grid, daily, upcoming)
      No .calendarExt3 DOM elements injected in browser or Electron
      Even the README-based example scene rendered nothing
      No browser console errors
      fetch() errors occurred when Node was downgraded, fixed with undici
      Troubleshooting Steps Taken
      mode: “month” → views + scenes - No visible output
      Added header to force rendering - Still no view
      Added clock + multiple regions - MM layout OK, EXT3 still hidden
      Inspected DOM in browser - .calendarExt3 not found
      Forced CSS override in custom.css - No change
      Tried testView: true - Still no visible EXT3
      Downgraded Node to v18 (for Electron 22) - Fixed fetch error
      Patched calendarfetcher.js with const { fetch } = require(“undici”) - Fixed ICS loading
      Installed undici@5.26.5 to match Node 18 - Resolved fetch issue
      Downgraded Electron to v22.3.27 -No render issues, but still no EXT3 DOM
      Tried server-only mode (npm run server) - Still blank EXT3
      This morning I went back to a default MM install and setup my known good config, with EXT2 and my working modules
      I would like EXT3 working though, seems I am missing something obvious when even the most basic config from the Readme loads the module but wont display
      • K Offline
        Kayos @sdetweil
        MM reinstall seems to have worked
        Now to set it up properly
          sdetweil @Kayos
          @Kayos so, this should be the minimal config for ext3
            module: "MMM-CalendarExt3",
            position: "bottom_bar",
          and you DID you the npm install IN the MMM-CalendarExt3 folder, right?
          AND the MM default calendar is displaying events. as Ext3 gets events from the default calendar
          • K Offline
            Kayos @sdetweil
            @sdetweil said in Calendar EXT3 not displaying either local or remote:
            Yes to all
            I might have a bit of time to experiment further this evening
            I am back with a fully current install
              sdetweil @Kayos
              @Kayos I just added Ext3 to the copy of the sample config .js and got this
              this is the end of my config.js
              the default Ext3 config is ‘week’ mode , with 3 weeks in view
              I changed to mode: “month”
              and got this
              config.js now ends
                                                 mode:"month"
              • K Offline
                Kayos @sdetweil
