    MMM-GooglePhotos suddenly stopped working this morning
    26 Posts 3 Posters 8.1k Views 4 Watching
      Jabl0
      Hello community,
      My MMM-GooglePhotos module stopped working this morning and i am getting the error below:
      0|mm | [2025-05-06 16:56:33.064] [ERROR] (node:9180) UnhandledPromiseRejectionWarning: AxiosError: Request failed with status code 403
      0|mm | at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:2031:12)
      0|mm | at Unzip.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:3148:11)
      0|mm | at Unzip.emit (node:events:530:35)
      0|mm | at endReadableNT (node:internal/streams/readable:1698:12)
      0|mm | at process.processTicksAndRejections (node:internal/process/task_queues:90:21)
      0|mm | at Axios.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:4258:41)
      0|mm | at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
      0|mm | at async GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:165:19)
      0|mm | at async getAlbum (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:208:24)
      0|mm | at async GPhotos.getAlbums (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:180:18)
      0|mm | at async Class.getAlbums (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:263:15)
      0|mm | at async Class.getAlbumList (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:313:18)
      0|mm | at async Class.scanJob (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:294:5)
      0|mm | [2025-05-06 16:56:33.066] [ERROR] (node:9180) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
      My token has not expired but i cannot seem to find the source of the issue.
      Is there any bigger issue that i am not aware of?
      I have the MMM-Google Calendar which is working fine and using the same Auth.
      Thanks in advance for your help :)
        sdetweil @Jabl0
        @Jabl0 error 403 is forbidden
        google has announced a change in behavior for the google photos service. they haven’t clearly said when it would take effect
        see
        https://forum.magicmirror.builders/topic/19460/google-photos-api-changing-mmm-googlephotos-will-stop-working-soon.
        https://developers.google.com/photos/support/updates
          Jabl0 @sdetweil
          @sdetweil said in MMM-GooglePhotos suddenly stopped working this morning:
          @sdetweil thanks for the reference, i will look at MMM-ImagesPhotos as an alternative and see if it fits my use case.
          • J Jabl0 has marked this topic as solved on
            Jabl0 @sdetweil
            @sdetweil Thanks for sharing the reference link. I have given it a go and its working. I would love to host the folder on a network drive ideally, so i will look at ways to do this.
              sdetweil @Jabl0
              @Jabl0 i host my pics on a network share
              i mount that share on my pi thru the /etc/fstab file
              i mount it to a directory in the /media folder
              sudo mkdir /media/fileserver
              here server-share local-folder and user/passsword on the server
              //ds-data/media /media/fileserver cifs username=xxx,password=yyy,iocharset=utf8,file_mode=0777,dir_mode=0777
              ImagePhotos uses the uploads folder in its directory
              now i rename that out of the way and use a filesystem link to make uploads map to the mounted folder
              cd ~/MagicMirror/modules/MMM-ImagePhotos
              mv uploads upload-orig
              sudo ln -s /media/fileserver uploads
              then you’ve got it
              the server folder will be auto mounted on boot
              you may have to force remount if the server is rebooted
              sudo mount -a
                sdetweil @Jabl0
                @Jabl0 i have a fork of ImagesPhotos that supports nested folders in the uploads folder
                i also have a module that allows guests to upload pics from their phones to the uploads folder via qr code
                https://github.com/sdetweil/uploadPics
                this supports upload to any folder. so works w any module providing view from locally accessible folder
                J J 2 Replies Last reply Reply Quote 0
                  JMac @sdetweil
                  @sdetweil is this module dead in the water now?
                  It was the backbone of my entire MM, using Carousel the mirror nicely flipped between the family calendar and the google photos.
                  is there a work around still using this module or is it a case of finding an alternative? If the latter which is the best module to use for the same end result?
                  Sorry to hijack but didn’t want to start a whole new thread.
                  Cheers.
                    sdetweil @JMac
                    @JMac we dont know. selecting photos to share requires using their app it appears.
                    we dont know what that means for api access like we do for MagicMirror. someone will have to dig in and find out
                    the old way doesn’t work, so this module is non-functional currently
                      Jabl0 @sdetweil
                      @sdetweil love all your solutions. This will keep me busy 😉 thanks again mate 🙌🏾
                        Jabl0 @Jabl0
                        @sdetweil just to update you. Network share works great and the kids are loving the QR code :) So thank you.
                        One thing i have noticed this module doing that the MMM-GooglePhotos module did not do, is it just goes black with only the mouse curser showing. Nothing shows up in PM2 logs when this happens. I guess its because it runs from browser?
                        Anyway i can troubleshoot this and see what is causing it? Maybe my Pi is not powerful enough? Its a Raspberry Pi 3 Model B.
                        See screenshot below:
                          sdetweil @Jabl0
                          @Jabl0 are you using my fork of the module? there was a bug handling restarting if one of the images failed to load
                          when you have the black screen you might be able to open the developers window , ctrl-shift-i, select the console tab
                          also i think there is a
                          debug:true
                          config option which will show the whole flow of getting files and selecting a file to display in the output of npm start
                          if you install MMM-Logging or MMM-LogExt it will capture the browser console and merge w the npm start console
                            Jabl0 @sdetweil
                            @sdetweil apologies but i am not sure what you mean by fork :( however, i am using this one https://github.com/roramirez/MMM-ImagesPhotos and i see you are a contributor on there?
                            I will give the recommended debugging log methods you have suggested and see what i can find.
                            Thank you.
                              sdetweil @Jabl0
                              @Jabl0 fork, means i have a copy too
                              https://github.com/sdetweil/MMM-ImagesPhotos
                                Jabl0 @sdetweil
                                @sdetweil Ah, right! Learnt something new :) I am using the other one. One more thing, i did enable debugging yesterday and for some strange reason i have not seen the black screen since i have done this. Fingers crossed though.
                                I did see these errors:
                                Invalid SOS parameters for sequential JPEG
                                But the module kept running fine with no black screen.
                                I would like to use your version, will i have to completely remove the module and clone yours instead, or is there a quicker way to migrate?
                                Thanks.
                                  sdetweil @Jabl0
                                  @Jabl0 just rename the module folder out of the way
                                  and install mine in its place. only change config for new parms if you want to use them
                                    Jabl0 @sdetweil
                                    @sdetweil Legend! Thanks :)
                                      Jabl0 @Jabl0
                                      @sdetweil its been a few days and that black screen keeps persisting. Using your fork and the original one.
                                      I am not seeing much from the logs, im keeping an eye on temperature as well. I do have over 3000 photos though. Dont know if that is an issue.
                                      I’d appreciate if you can help me with this.
                                      Let me know what i need to provide in order to be able to get this resolved.
                                        sdetweil @Jabl0
                                        @Jabl0 did you add
                                        debug:true,
                                        to the module config, and add MMM-Logext
                                        you should see logging where npm start is done
                                          Jabl0 @sdetweil
                                          @sdetweil yes I did. That’s where have been checking the past few days and all the images load just fine, even when it goes black which why im baffled. Is there anything else I should be looking for in the logs?
                                          I use pm2 logs to see the logs btw.
                                          I also check in dmesg
                                            sdetweil @Jabl0
                                            @Jabl0 ok, good. ill relook thru the code, i had a similar problem with a similar module on another mirror platform, was an out of memory problem.
                                            wont be able to get to that til this afternoon.
