    Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream
    68 Posts 5 Posters 23.9k Views 4 Watching
      sdetweil @rkorell
      @rkorell not double dash
      just trying to figure out what the problem is
      maybe curl version
      R 3 Replies Last reply Reply Quote 0
        @sdetweil OK
        this is curl --version :-) (just successfully trial&errored)
        curl --version
        curl 7.88.1 (aarch64-unknown-linux-gnu) libcurl/7.88.1 OpenSSL/3.0.15 zlib/1.2.13 brotli/1.0.9 zstd/1.5.4 libidn2/2.3.3 libpsl/0.21.2 (+libidn2/2.3.3) libssh2/1.10.0 nghttp2/1.52.0 librtmp/2.3 OpenLDAP/2.5.13
        Release-Date: 2023-02-20, security patched: 7.88.1-10+deb12u12
        Protocols: dict file ftp ftps gopher gophers http https imap imaps ldap ldaps mqtt pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
        Features: alt-svc AsynchDNS brotli GSS-API HSTS HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile libz NTLM NTLM_WB PSL SPNEGO SSL threadsafe TLS-SRP UnixSockets zstd
          @sdetweil because it doesn’t work on windows either this is most likely not a version but a command or URL thing …
            @sdetweil said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
            Dear Sam,
            I caught it …
            The Windows command is not working for other reasons - doesn’t matter…
            The curl on MY Pi doesn’t work because - for some strange reason the resolving of “localhost” doesn’t work ???
            Figured this out by using another linux client (Macbook) and therefor using IP address of pi remotely - which worked instantly.
            And trying this locally on Pi with IP adreees does the job as well.
            Thanks again for your help!
            Regards,
            Ralf
              sdetweil @rkorell
              @rkorell weird, it works on windows for me
              i just copy/pasted from the repo and
              changed the address and port at the end
              i can do it on the same machine or across the network to other machines
                sdetweil @rkorell
                @rkorell localhost is(always) mapped to 127.0.0.1 on the same system
                which is called the loopback adapter, cause the packets never leave the system
                ping localhost
                should work
                  Yes. I’m aware of this, thanks.
                  ping localhost
                  should work
                  Yes, do work:
                  pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ ping localhost
                  PING localhost(localhost (::1)) 56 data bytes
                  64 bytes from localhost (::1): icmp_seq=1 ttl=64 time=0.027 ms
                  64 bytes from localhost (::1): icmp_seq=2 ttl=64 time=0.035 ms
                  64 bytes from localhost (::1): icmp_seq=3 ttl=64 time=0.035 ms
                  64 bytes from localhost (::1): icmp_seq=4 ttl=64 time=0.036 ms
                  64 bytes from localhost (::1): icmp_seq=5 ttl=64 time=0.031 ms
                  64 bytes from localhost (::1): icmp_seq=6 ttl=64 time=0.039 ms
                  ^Z
                  [1]+  Stopped                 ping localhost
                  thanks anyway,
                  Regards,
                  Ralf
                    sdetweil @rkorell
                    @rkorell so, its a curl problem… weird…
                    but its using ipv6 (::1 is the ipv6 version of 127.0.0.1)
                      good catch!
                      THis may is the reason, because - as far as I. know - ipV6 isn’t implemented (properly?) in my network (at least I do not have anything configured. My AVM (Fritzbox) router is ipV6 aware but I do not “use” it esplicitely …
                      Strange!
                      Ralf
                        sdetweil @rkorell
                        @rkorell can you edit your /etc/hosts
                        to see how localhost is defined
                        on my amd host it is
                        127.0.0.1       localhost
                        on my pi it is
                        127.0.0.1       localhost
                        ::1             localhost ip6-localhost ip6-loopback
                          @sdetweil Oh, yes - I remember …
                          interesting enough my /etc/hosts is likely the same as on your Pi - with ipV6 entries.
                          If I delete them, error remains :-(
                          Ralf
                            sdetweil @rkorell
                            @rkorell weird
                              @sdetweil :-) indeed
                                @sdetweil and now 3hours later more weird it doesn’t work with IP address as well.
                                In addition for some strange reason the enablement of the MMM-Mplayer module leads to unrecoverable disconnects of PI from network.
                                This currently is too much resistance to me, so sorry dear @Cr4z33 - I’m not able to dig in deeper to assist you…
                                Regards,
                                Ralf
                                • Cr4z33C Offline
                                  Cr4z33 @rkorell
                                  Once again thank you @rkorell and @sdetweil for willing to help me!
                                  Unfortunately real life last minute serious event had to stop me to dedicate to this matter for a long while.
                                    rkorell Module Developer @Cr4z33
                                    @Cr4z33 OH…
                                    All the best!
                                    Ralf
                                    • 4 / 4
