    Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream
    68 Posts 5 Posters 23.9k Views 4 Watching
      rkorell Module Developer @rkorell
      @rkorell said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
      Neither in pm2 logs nor in developer’s console…
      startup log
      0|MagicMir | > magicmirror@2.31.0-develop start
      0|MagicMir | > npm run start:x11
      0|MagicMir |
      0|MagicMir |
      0|MagicMir | > magicmirror@2.31.0-develop start:x11
      0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      0|MagicMir |
      0|MagicMir | [2025-05-03 17:06:27.179] [LOG]   Starting MagicMirror: v2.31.0-develop
      0|MagicMir | [2025-05-03 17:06:27.189] [LOG]   Loading config ...
      0|MagicMir | [2025-05-03 17:06:27.190] [LOG]   config template file not exists, no envsubst
      0|MagicMir | [2025-05-03 17:06:27.369] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
      0|MagicMir | [2025-05-03 17:06:27.436] [INFO]  Your configuration file doesn't contain syntax errors :)
      0|MagicMir | [2025-05-03 17:06:27.437] [INFO]  Checking modules structure configuration ...
      0|MagicMir | [2025-05-03 17:06:27.473] [INFO]  Your modules structure configuration doesn't contain errors :)
      0|MagicMir | [2025-05-03 17:06:27.474] [LOG]   Loading module helpers ...
      0|MagicMir | [2025-05-03 17:06:27.474] [LOG]   No helper found for module: alert.
      0|MagicMir | [2025-05-03 17:06:27.475] [LOG]   No helper found for module: MMM-MagicMover.
      0|MagicMir | [2025-05-03 17:06:27.476] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   Module helper loaded: MMM-CurlToNotification
      0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   No helper found for module: clock.
      0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   No helper found for module: MMM-Profilepicture.
      0|MagicMir | [2025-05-03 17:06:27.484] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.484] [LOG]   Module helper loaded: MMM-Logging
      0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   Module helper loaded: MMM-MoonPhase
      0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   No helper found for module: MMM-Globe.
      0|MagicMir | [2025-05-03 17:06:27.492] [LOG]   No helper found for module: weather.
      0|MagicMir | [2025-05-03 17:06:27.523] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.524] [LOG]   Module helper loaded: MMM-JsonValue
      0|MagicMir | [2025-05-03 17:06:27.531] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.531] [LOG]   Module helper loaded: MMM-MyGarbage
      0|MagicMir | [2025-05-03 17:06:27.532] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
      0|MagicMir | [2025-05-03 17:06:27.532] [LOG]   No helper found for module: MMM-RAIN-MAP.
      0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Check MagicMirror² version for node helper 'MMM-Strava' - Minimum version: 2.2.0 - Current version: 2.31.0-develop
      0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Version is ok!
      0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Module helper loaded: MMM-Strava
      0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   Module helper loaded: MMM-Todoist
      0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   No helper found for module: MMM-UselessFacts.
      0|MagicMir | [2025-05-03 17:06:27.748] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.748] [LOG]   Module helper loaded: MMM-FRITZ-Box-Callmonitor-py3
      0|MagicMir | [2025-05-03 17:06:27.749] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.749] [LOG]   Module helper loaded: MMM-SystemMonitor
      0|MagicMir | [2025-05-03 17:06:27.750] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.750] [LOG]   Module helper loaded: MMM-SystemInfo
      0|MagicMir | [2025-05-03 17:06:27.782] [LOG]   2025-05-03T17:06:27 <log> init module helper birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:15 Class.init)
      0|MagicMir | [2025-05-03 17:06:27.782] [LOG]   Module helper loaded: birthdaylist
      0|MagicMir | [2025-05-03 17:06:27.898] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.899] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
      0|MagicMir | [2025-05-03 17:06:27.925] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.925] [LOG]   Module helper loaded: newsfeed
      0|MagicMir | [2025-05-03 17:06:27.945] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.945] [LOG]   Module helper loaded: MMM-Remote-Control
      0|MagicMir | [2025-05-03 17:06:27.982] [LOG]   Initializing new module helper ...
      0|MagicMir | [2025-05-03 17:06:27.983] [LOG]   Module helper loaded: calendar
      0|MagicMir | [2025-05-03 17:06:27.983] [LOG]   All module helpers loaded.
      0|MagicMir | [2025-05-03 17:06:27.986] [LOG]   Starting server on port 8080 ...
      0|MagicMir | [2025-05-03 17:06:28.296] [LOG]   Server started ...
      0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Connecting socket for: MMM-CurlToNotification
      0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Starting module helper: MMM-CurlToNotification
      0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Connecting socket for: MMM-Logging
      0|MagicMir | [2025-05-03 17:06:28.298] [LOG]   2025-05-03T17:06:28 <log> Module helper started for MMM-Logging (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:19 Class.start)
      0|MagicMir | [2025-05-03 17:06:28.298] [LOG]   Connecting socket for: MMM-MoonPhase
      0|MagicMir | [2025-05-03 17:06:28.304] [LOG]   Starting module helper: MMM-MoonPhase
      0|MagicMir | [2025-05-03 17:06:28.304] [LOG]   Connecting socket for: MMM-JsonValue
      0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   Connecting socket for: MMM-MyGarbage
      0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   2025-05-03T17:06:28 <log> Starting node_helper for module: MMM-MyGarbage (/home/pi/MagicMirror/modules/MMM-MyGarbage/node_helper.js:9 Class.start)
      0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   Connecting socket for: MMM-Strava
      0|MagicMir | [2025-05-03 17:06:28.306] [LOG]   2025-05-03T17:06:28 <log> Starting module helper: MMM-Strava (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:47 Class.start)
      0|MagicMir | [2025-05-03 17:06:28.306] [LOG]   Connecting socket for: MMM-Todoist
      0|MagicMir | [2025-05-03 17:06:28.307] [LOG]   2025-05-03T17:06:28 <log> Starting node helper for: MMM-Todoist (/home/pi/MagicMirror/modules/MMM-Todoist/node_helper.js:19 Class.start)
      0|MagicMir | [2025-05-03 17:06:28.307] [LOG]   Connecting socket for: MMM-FRITZ-Box-Callmonitor-py3
      0|MagicMir | [2025-05-03 17:06:28.312] [LOG]   2025-05-03T17:06:28 <log> Starting module: MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:28 Class.start)
      0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: MMM-SystemMonitor
      0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Starting module helper: MMM-SystemMonitor
      0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: MMM-SystemInfo
      0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Starting node helper: MMM-SystemInfo
      0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: birthdaylist
      0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify
      0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Connecting socket for: newsfeed
      0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Starting node helper for: newsfeed
      0|MagicMir | [2025-05-03 17:06:28.318] [LOG]   Connecting socket for: MMM-Remote-Control
      0|MagicMir | [2025-05-03 17:06:28.319] [LOG]   Starting node helper for: MMM-Remote-Control
      0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Connecting socket for: calendar
      0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Starting node helper for: calendar
      0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Sockets connected & modules started ...
      0|MagicMir | [2025-05-03 17:06:28.540] [LOG]   Launching application.
      0|MagicMir | [2025-05-03 17:06:28.915] [INFO]  System information:
      0|MagicMir | ### SYSTEM:   manufacturer: ; model: ; virtual: false
      0|MagicMir | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-2712
      0|MagicMir | ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
      0|MagicMir | ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
      0|MagicMir | [2025-05-03 17:06:29.613] [LOG]   [MMM-Remote-Control] Could not get defaults for MMM-RAIN-MAP. See #335.
      0|MagicMir | [2025-05-03 17:06:31.249] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/xxxxxxxxxxxx%40group.calendar.google.com/private-5yyyyyyyyyyyyyyyyyyyyyy/basic.ics - Interval: 300000
      0|MagicMir | [2025-05-03 17:06:31.278] [LOG]   2025-05-03T17:06:31 <info> MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
      0|MagicMir | [2025-05-03 17:06:31.279] [LOG]   2025-05-03T17:06:31 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
      0|MagicMir | [2025-05-03 17:06:31.303] [LOG]   2025-05-03T17:06:31 <log> Received config for MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:56 Class.socketNotificationReceived)
      0|MagicMir | [2025-05-03 17:06:31.304] [LOG]   2025-05-03T17:06:31 <log> MMM-FRITZ-Box-Callmonitor-py3 is waiting for incoming calls. (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:118 Class.setupMonitor)
      0|MagicMir | [2025-05-03 17:06:31.376] [LOG]   Create new newsfetcher for url: https://www.gutekueche.de/feed/wochenrezepte - Interval: 300000
      0|MagicMir | [2025-05-03 17:06:31.382] [LOG]   Create new newsfetcher for url: https://www.gutekueche.de/feed/tagesrezept - Interval: 300000
      0|MagicMir | [2025-05-03 17:06:31.385] [LOG]   Create new newsfetcher for url: https://www.chefkoch.de/recipe-of-the-day/rss - Interval: 300000
      0|MagicMir | [2025-05-03 17:06:31.389] [LOG]   Create new calendarfetcher for url: https://www.feiertage-deutschland.de/kalender-download/ics/feiertage-deutschland.ics - Interval: 604800000
      0|MagicMir | [2025-05-03 17:06:31.394] [LOG]   2025-05-03T17:06:31 <log> Starting module helper:  birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:27 Class.socketNotificationReceived)
      0|MagicMir | [2025-05-03 17:06:32.046] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
      0|MagicMir | [2025-05-03 17:06:32.050] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
      0|MagicMir | [2025-05-03 17:06:32.194] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
      0|MagicMir | [2025-05-03 17:06:32.353] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
      0|MagicMir | [2025-05-03 17:06:32.398] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
      0|MagicMir | [2025-05-03 17:06:32.495] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
      0|MagicMir | [2025-05-03 17:06:32.734] [INFO]  Calendar-Fetcher: Broadcasting 51 events from https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-yyyyyyyyyyyyyyyyyyyyyyyyyyyy/basic.ics.
      0|MagicMir | [2025-05-03 17:06:32.827] [LOG]   2025-05-03T17:06:32 <log> Refreshed access token because it has expired. Expired at: 17:06:31 now is: 17:06:32 (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/core/SpotifyConnector.js:24 )
      0|MagicMir | [2025-05-03 17:06:33.418] [LOG]   2025-05-03T17:06:33 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
      0|MagicMir | [2025-05-03 17:06:34.302] [INFO]  Calendar-Fetcher: Broadcasting 22 events from https://www.feiertage-deutschland.de/kalender-download/ics/feiertage-deutschland.ics.
        sdetweil @rkorell
        @rkorell git pull in the module folder restart MM
        in the npm start output, should see (I sent 3 requests)
        [2025-05-03 18:30:03.519] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'HIDE_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
        [2025-05-03 18:30:36.302] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'SHOW_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
        [2025-05-03 18:31:00.765] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'HIDE_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
        and in the dev console
        MMM-CurlToNotification.js:14 MMM-CurlToNotification received request to send notication  HIDE_ALERT  with payload  {message: 'fribble'}
        MMM-CurlToNotification.js:14 MMM-CurlToNotification received request to send notication  SHOW_ALERT  with payload  {message: 'fribble'}
          @sdetweil I`m away from home today, will check tomorrow…
          Thanks.
          Ralf
            As your posting above implies your debug message confirms a received message - but the message cannot be received, because the curl command doesn’t work …
            As per your advise I’ve git pulled, restarted mirror - but get same error message as before.
            The curl command is bad or the URL doesn’t work.
            I don’t know why and have no idea how to figure this out…
            Screen input- and output as follws:
            pi@MagicMirrorPi5:~ $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
            <!DOCTYPE html>
            <html lang="en">
            <head>
            <meta charset="utf-8">
            <title>Error</title>
            </head>
            <body>
            <pre>InternalServerError: stream is not readable<br> &nbsp; &nbsp;at readStream (/home/pi/MagicMirror/node_modules/raw-body/index.js:185:17)<br> &nbsp; &nbsp;at getRawBody (/home/pi/MagicMirror/node_modules/raw-body/index.js:116:12)<br> &nbsp; &nbsp;at read (/home/pi/MagicMirror/node_modules/body-parser/lib/read.js:79:3)<br> &nbsp; &nbsp;at jsonParser (/home/pi/MagicMirror/node_modules/body-parser/lib/types/json.js:138:5)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:95:5)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:91:12)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/body-parser/lib/read.js:132:5<br> &nbsp; &nbsp;at AsyncResource.runInAsyncScope (node:async_hooks:206:9)<br> &nbsp; &nbsp;at invokeCallback (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:238:16)<br> &nbsp; &nbsp;at done (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:227:7)<br> &nbsp; &nbsp;at IncomingMessage.onEnd (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:287:7)<br> &nbsp; &nbsp;at IncomingMessage.emit (node:events:518:28)<br> &nbsp; &nbsp;at endReadableNT (node:internal/streams/readable:1698:12)<br> &nbsp; &nbsp;at process.processTicksAndRejections (node:internal/process/task_queues:82:21)</pre>
            </body>
            </html>
            pi@MagicMirrorPi5:~ $ cd MagicMirror/modules
            pi@MagicMirrorPi5:~/MagicMirror/modules $ cd MMM-CurlToNotification/
            pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ git pull
            Updating 71ea1c1..bd1e417
            Fast-forward
             MMM-CurlToNotification.js | 14 ++++++++++----
             README.md                 |  1 +
             node_helper.js            | 13 +++++++++++--
             3 files changed, 22 insertions(+), 6 deletions(-)
            pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ pm2 restart MagicMirror
            [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
            [PM2] [MagicMirror](0) ✓
            │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
            │ 0  │ MagicMirror    │ default     │ 2.31.0… │ fork    │ 87731    │ 0s     │ 1    │ online    │ 0%       │ 2.6mb    │ pi       │ enabled  │
            pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
            <!DOCTYPE html>
            <html lang="en">
            <head>
            </head>
            <body>
            </body>
            </html>
            Any additional idea?
            regards,
            Ralf
              sdetweil @rkorell
              @rkorell do curl -v
                curl --v --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                curl: option --v: is ambiguous
                curl: try 'curl --help' or 'curl --manual' for more information
                  sdetweil @rkorell
                  @rkorell not double dash
                  just trying to figure out what the problem is
                  maybe curl version
                  R 3 Replies Last reply Reply Quote 0
                    @sdetweil OK
                    this is curl --version :-) (just successfully trial&errored)
                    curl --version
                    curl 7.88.1 (aarch64-unknown-linux-gnu) libcurl/7.88.1 OpenSSL/3.0.15 zlib/1.2.13 brotli/1.0.9 zstd/1.5.4 libidn2/2.3.3 libpsl/0.21.2 (+libidn2/2.3.3) libssh2/1.10.0 nghttp2/1.52.0 librtmp/2.3 OpenLDAP/2.5.13
                    Release-Date: 2023-02-20, security patched: 7.88.1-10+deb12u12
                    Protocols: dict file ftp ftps gopher gophers http https imap imaps ldap ldaps mqtt pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
                    Features: alt-svc AsynchDNS brotli GSS-API HSTS HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile libz NTLM NTLM_WB PSL SPNEGO SSL threadsafe TLS-SRP UnixSockets zstd
                      @sdetweil because it doesn’t work on windows either this is most likely not a version but a command or URL thing …
                        @sdetweil said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
                        Dear Sam,
                        I caught it …
                        The Windows command is not working for other reasons - doesn’t matter…
                        The curl on MY Pi doesn’t work because - for some strange reason the resolving of “localhost” doesn’t work ???
                        Figured this out by using another linux client (Macbook) and therefor using IP address of pi remotely - which worked instantly.
                        And trying this locally on Pi with IP adreees does the job as well.
                        Thanks again for your help!
                        Regards,
                        Ralf
                          sdetweil @rkorell
                          @rkorell weird, it works on windows for me
                          i just copy/pasted from the repo and
                          changed the address and port at the end
                          i can do it on the same machine or across the network to other machines
                            sdetweil @rkorell
                            @rkorell localhost is(always) mapped to 127.0.0.1 on the same system
                            which is called the loopback adapter, cause the packets never leave the system
                            ping localhost
                            should work
                              Yes. I’m aware of this, thanks.
                              ping localhost
                              should work
                              Yes, do work:
                              pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ ping localhost
                              PING localhost(localhost (::1)) 56 data bytes
                              64 bytes from localhost (::1): icmp_seq=1 ttl=64 time=0.027 ms
                              64 bytes from localhost (::1): icmp_seq=2 ttl=64 time=0.035 ms
                              64 bytes from localhost (::1): icmp_seq=3 ttl=64 time=0.035 ms
                              64 bytes from localhost (::1): icmp_seq=4 ttl=64 time=0.036 ms
                              64 bytes from localhost (::1): icmp_seq=5 ttl=64 time=0.031 ms
                              64 bytes from localhost (::1): icmp_seq=6 ttl=64 time=0.039 ms
                              ^Z
                              [1]+  Stopped                 ping localhost
                              thanks anyway,
                              Regards,
                              Ralf
                                sdetweil @rkorell
                                @rkorell so, its a curl problem… weird…
                                but its using ipv6 (::1 is the ipv6 version of 127.0.0.1)
                                  good catch!
                                  THis may is the reason, because - as far as I. know - ipV6 isn’t implemented (properly?) in my network (at least I do not have anything configured. My AVM (Fritzbox) router is ipV6 aware but I do not “use” it esplicitely …
                                  Strange!
                                  Ralf
                                    sdetweil @rkorell
                                    @rkorell can you edit your /etc/hosts
                                    to see how localhost is defined
                                    on my amd host it is
                                    127.0.0.1       localhost
                                    on my pi it is
                                    127.0.0.1       localhost
                                    ::1             localhost ip6-localhost ip6-loopback
                                      @sdetweil Oh, yes - I remember …
                                      interesting enough my /etc/hosts is likely the same as on your Pi - with ipV6 entries.
                                      If I delete them, error remains :-(
                                      Ralf
                                        sdetweil @rkorell
                                        @rkorell weird
                                          @sdetweil :-) indeed
                                            @sdetweil and now 3hours later more weird it doesn’t work with IP address as well.
                                            In addition for some strange reason the enablement of the MMM-Mplayer module leads to unrecoverable disconnects of PI from network.
                                            This currently is too much resistance to me, so sorry dear @Cr4z33 - I’m not able to dig in deeper to assist you…
                                            Regards,
                                            Ralf
                                            • 3 / 4
