    Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream
    68 Posts 5 Posters 20.3k Views 4 Watching
      @sdetweil said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
      so i wrote MMM-CurlToNotification
      Dear Sam,
      trying to help I’m struggled with your module CurlToNotification :-(
        module:"MMM-CurlToNotification",
        config:{
          url_name:"doorbell", // the path of the url for curl post
      And consecutively running
      curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
      Shows an error message:
      pi@MagicMirrorPi5:~/MagicMirror/modules $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
      <!DOCTYPE html>
      <html lang="en">
      <head>
      <meta charset="utf-8">
      <title>Error</title>
      </head>
      <body>
      <pre>InternalServerError: stream is not readable<br> &nbsp; &nbsp;at readStream (/home/pi/MagicMirror/node_modules/raw-body/index.js:185:17)<br> &nbsp; &nbsp;at getRawBody (/home/pi/MagicMirror/node_modules/raw-body/index.js:116:12)<br> &nbsp; &nbsp;at read (/home/pi/MagicMirror/node_modules/body-parser/lib/read.js:79:3)<br> &nbsp; &nbsp;at jsonParser (/home/pi/MagicMirror/node_modules/body-parser/lib/types/json.js:138:5)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:95:5)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:91:12)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/body-parser/lib/read.js:132:5<br> &nbsp; &nbsp;at AsyncResource.runInAsyncScope (node:async_hooks:206:9)<br> &nbsp; &nbsp;at invokeCallback (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:238:16)<br> &nbsp; &nbsp;at done (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:227:7)<br> &nbsp; &nbsp;at IncomingMessage.onEnd (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:287:7)<br> &nbsp; &nbsp;at IncomingMessage.emit (node:events:518:28)<br> &nbsp; &nbsp;at endReadableNT (node:internal/streams/readable:1698:12)<br> &nbsp; &nbsp;at process.processTicksAndRejections (node:internal/process/task_queues:82:21)</pre>
      </body>
      </html>
      From Windows Client (changing localhost to MagicMirrors IP address a different error message:
      PS C:\Users\Familienbenutzer> curl --header "Content-Type: application/json"   --request POST   --data "{\"notification\":\"SHOW_ALERT\",\"payload\":{\"message\":\"fribble\"}}" http://1xx.yy.zz.157:8080/doorbell
      Invoke-WebRequest : Es wurde kein Positionsparameter gefunden, der das Argument "Content-Type: application/json"
      akzeptiert.
      In Zeile:1 Zeichen:1
      + curl --header "Content-Type: application/json"   --request POST   --d ...
          + CategoryInfo          : InvalidArgument: (:) [Invoke-WebRequest], ParameterBindingException
          + FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
      Any hint for me?
      Thanks and regards,
      Ralf
        sdetweil @rkorell
        @rkorell and you did restart MagicMirror after installing the module, right?
        you can also add config parm (make sure there is a trailing comma after doorbell
           debug:true,
          yes, indeed :-)
          And a trailing comma is there…
          In the meantime I had even a PI-reboot (for other reasons) - error persists.
          Even with debug-option enabled no debug message from your module.
          Neither in pm2 logs nor in developer’s console…
          Ralf
          S R 3 Replies Last reply Reply Quote 0
            sdetweil @rkorell
            @rkorell weird
            i am away from my computer for most of the day helping family
            i will review asap
              @sdetweil Take your time!
              Family is most important.
              This issue is REALLY not important, neither urgent.
              I do not need this module right now - was just for testing, if I can help @Cr4z33 further with some examples to copy - as asked.
              So don’t hurry.
              Ralf
                rkorell Module Developer @rkorell
                @rkorell said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
                all messages in dev-console …
                  startup log
                  0|MagicMir | > magicmirror@2.31.0-develop start
                  0|MagicMir | > npm run start:x11
                  0|MagicMir |
                  0|MagicMir |
                  0|MagicMir | > magicmirror@2.31.0-develop start:x11
                  0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                  0|MagicMir |
                  0|MagicMir | [2025-05-03 17:06:27.179] [LOG]   Starting MagicMirror: v2.31.0-develop
                  0|MagicMir | [2025-05-03 17:06:27.189] [LOG]   Loading config ...
                  0|MagicMir | [2025-05-03 17:06:27.190] [LOG]   config template file not exists, no envsubst
                  0|MagicMir | [2025-05-03 17:06:27.369] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
                  0|MagicMir | [2025-05-03 17:06:27.436] [INFO]  Your configuration file doesn't contain syntax errors :)
                  0|MagicMir | [2025-05-03 17:06:27.437] [INFO]  Checking modules structure configuration ...
                  0|MagicMir | [2025-05-03 17:06:27.473] [INFO]  Your modules structure configuration doesn't contain errors :)
                  0|MagicMir | [2025-05-03 17:06:27.474] [LOG]   Loading module helpers ...
                  0|MagicMir | [2025-05-03 17:06:27.474] [LOG]   No helper found for module: alert.
                  0|MagicMir | [2025-05-03 17:06:27.475] [LOG]   No helper found for module: MMM-MagicMover.
                  0|MagicMir | [2025-05-03 17:06:27.476] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   Module helper loaded: MMM-CurlToNotification
                  0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   No helper found for module: clock.
                  0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   No helper found for module: MMM-Profilepicture.
                  0|MagicMir | [2025-05-03 17:06:27.484] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.484] [LOG]   Module helper loaded: MMM-Logging
                  0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   Module helper loaded: MMM-MoonPhase
                  0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   No helper found for module: MMM-Globe.
                  0|MagicMir | [2025-05-03 17:06:27.492] [LOG]   No helper found for module: weather.
                  0|MagicMir | [2025-05-03 17:06:27.523] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.524] [LOG]   Module helper loaded: MMM-JsonValue
                  0|MagicMir | [2025-05-03 17:06:27.531] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.531] [LOG]   Module helper loaded: MMM-MyGarbage
                  0|MagicMir | [2025-05-03 17:06:27.532] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
                  0|MagicMir | [2025-05-03 17:06:27.532] [LOG]   No helper found for module: MMM-RAIN-MAP.
                  0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Check MagicMirror² version for node helper 'MMM-Strava' - Minimum version: 2.2.0 - Current version: 2.31.0-develop
                  0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Version is ok!
                  0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Module helper loaded: MMM-Strava
                  0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   Module helper loaded: MMM-Todoist
                  0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   No helper found for module: MMM-UselessFacts.
                  0|MagicMir | [2025-05-03 17:06:27.748] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.748] [LOG]   Module helper loaded: MMM-FRITZ-Box-Callmonitor-py3
                  0|MagicMir | [2025-05-03 17:06:27.749] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.749] [LOG]   Module helper loaded: MMM-SystemMonitor
                  0|MagicMir | [2025-05-03 17:06:27.750] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.750] [LOG]   Module helper loaded: MMM-SystemInfo
                  0|MagicMir | [2025-05-03 17:06:27.782] [LOG]   2025-05-03T17:06:27 <log> init module helper birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:15 Class.init)
                  0|MagicMir | [2025-05-03 17:06:27.782] [LOG]   Module helper loaded: birthdaylist
                  0|MagicMir | [2025-05-03 17:06:27.898] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.899] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
                  0|MagicMir | [2025-05-03 17:06:27.925] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.925] [LOG]   Module helper loaded: newsfeed
                  0|MagicMir | [2025-05-03 17:06:27.945] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.945] [LOG]   Module helper loaded: MMM-Remote-Control
                  0|MagicMir | [2025-05-03 17:06:27.982] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.983] [LOG]   Module helper loaded: calendar
                  0|MagicMir | [2025-05-03 17:06:27.983] [LOG]   All module helpers loaded.
                  0|MagicMir | [2025-05-03 17:06:27.986] [LOG]   Starting server on port 8080 ...
                  0|MagicMir | [2025-05-03 17:06:28.296] [LOG]   Server started ...
                  0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Connecting socket for: MMM-CurlToNotification
                  0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Starting module helper: MMM-CurlToNotification
                  0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Connecting socket for: MMM-Logging
                  0|MagicMir | [2025-05-03 17:06:28.298] [LOG]   2025-05-03T17:06:28 <log> Module helper started for MMM-Logging (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:19 Class.start)
                  0|MagicMir | [2025-05-03 17:06:28.298] [LOG]   Connecting socket for: MMM-MoonPhase
                  0|MagicMir | [2025-05-03 17:06:28.304] [LOG]   Starting module helper: MMM-MoonPhase
                  0|MagicMir | [2025-05-03 17:06:28.304] [LOG]   Connecting socket for: MMM-JsonValue
                  0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   Connecting socket for: MMM-MyGarbage
                  0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   2025-05-03T17:06:28 <log> Starting node_helper for module: MMM-MyGarbage (/home/pi/MagicMirror/modules/MMM-MyGarbage/node_helper.js:9 Class.start)
                  0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   Connecting socket for: MMM-Strava
                  0|MagicMir | [2025-05-03 17:06:28.306] [LOG]   2025-05-03T17:06:28 <log> Starting module helper: MMM-Strava (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:47 Class.start)
                  0|MagicMir | [2025-05-03 17:06:28.306] [LOG]   Connecting socket for: MMM-Todoist
                  0|MagicMir | [2025-05-03 17:06:28.307] [LOG]   2025-05-03T17:06:28 <log> Starting node helper for: MMM-Todoist (/home/pi/MagicMirror/modules/MMM-Todoist/node_helper.js:19 Class.start)
                  0|MagicMir | [2025-05-03 17:06:28.307] [LOG]   Connecting socket for: MMM-FRITZ-Box-Callmonitor-py3
                  0|MagicMir | [2025-05-03 17:06:28.312] [LOG]   2025-05-03T17:06:28 <log> Starting module: MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:28 Class.start)
                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: MMM-SystemMonitor
                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Starting module helper: MMM-SystemMonitor
                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: MMM-SystemInfo
                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Starting node helper: MMM-SystemInfo
                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: birthdaylist
                  0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify
                  0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Connecting socket for: newsfeed
                  0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Starting node helper for: newsfeed
                  0|MagicMir | [2025-05-03 17:06:28.318] [LOG]   Connecting socket for: MMM-Remote-Control
                  0|MagicMir | [2025-05-03 17:06:28.319] [LOG]   Starting node helper for: MMM-Remote-Control
                  0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Connecting socket for: calendar
                  0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Starting node helper for: calendar
                  0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Sockets connected & modules started ...
                  0|MagicMir | [2025-05-03 17:06:28.540] [LOG]   Launching application.
                  0|MagicMir | [2025-05-03 17:06:28.915] [INFO]  System information:
                  0|MagicMir | ### SYSTEM:   manufacturer: ; model: ; virtual: false
                  0|MagicMir | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-2712
                  0|MagicMir | ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                  0|MagicMir | ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                  0|MagicMir | [2025-05-03 17:06:29.613] [LOG]   [MMM-Remote-Control] Could not get defaults for MMM-RAIN-MAP. See #335.
                  0|MagicMir | [2025-05-03 17:06:31.249] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/xxxxxxxxxxxx%40group.calendar.google.com/private-5yyyyyyyyyyyyyyyyyyyyyy/basic.ics - Interval: 300000
                  0|MagicMir | [2025-05-03 17:06:31.278] [LOG]   2025-05-03T17:06:31 <info> MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:31.279] [LOG]   2025-05-03T17:06:31 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:31.303] [LOG]   2025-05-03T17:06:31 <log> Received config for MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:56 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:31.304] [LOG]   2025-05-03T17:06:31 <log> MMM-FRITZ-Box-Callmonitor-py3 is waiting for incoming calls. (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:118 Class.setupMonitor)
                  0|MagicMir | [2025-05-03 17:06:31.376] [LOG]   Create new newsfetcher for url: https://www.gutekueche.de/feed/wochenrezepte - Interval: 300000
                  0|MagicMir | [2025-05-03 17:06:31.382] [LOG]   Create new newsfetcher for url: https://www.gutekueche.de/feed/tagesrezept - Interval: 300000
                  0|MagicMir | [2025-05-03 17:06:31.385] [LOG]   Create new newsfetcher for url: https://www.chefkoch.de/recipe-of-the-day/rss - Interval: 300000
                  0|MagicMir | [2025-05-03 17:06:31.389] [LOG]   Create new calendarfetcher for url: https://www.feiertage-deutschland.de/kalender-download/ics/feiertage-deutschland.ics - Interval: 604800000
                  0|MagicMir | [2025-05-03 17:06:31.394] [LOG]   2025-05-03T17:06:31 <log> Starting module helper:  birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:27 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:32.046] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:32.050] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:32.194] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:32.353] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                  0|MagicMir | [2025-05-03 17:06:32.398] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                  0|MagicMir | [2025-05-03 17:06:32.495] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                  0|MagicMir | [2025-05-03 17:06:32.734] [INFO]  Calendar-Fetcher: Broadcasting 51 events from https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-yyyyyyyyyyyyyyyyyyyyyyyyyyyy/basic.ics.
                  0|MagicMir | [2025-05-03 17:06:32.827] [LOG]   2025-05-03T17:06:32 <log> Refreshed access token because it has expired. Expired at: 17:06:31 now is: 17:06:32 (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/core/SpotifyConnector.js:24 )
                  0|MagicMir | [2025-05-03 17:06:33.418] [LOG]   2025-05-03T17:06:33 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:34.302] [INFO]  Calendar-Fetcher: Broadcasting 22 events from https://www.feiertage-deutschland.de/kalender-download/ics/feiertage-deutschland.ics.
                    sdetweil @rkorell
                    @rkorell git pull in the module folder restart MM
                    in the npm start output, should see (I sent 3 requests)
                    [2025-05-03 18:30:03.519] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'HIDE_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
                    [2025-05-03 18:30:36.302] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'SHOW_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
                    [2025-05-03 18:31:00.765] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'HIDE_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
                    and in the dev console
                    MMM-CurlToNotification.js:14 MMM-CurlToNotification received request to send notication  HIDE_ALERT  with payload  {message: 'fribble'}
                    MMM-CurlToNotification.js:14 MMM-CurlToNotification received request to send notication  SHOW_ALERT  with payload  {message: 'fribble'}
                      @sdetweil I`m away from home today, will check tomorrow…
                      Thanks.
                      Ralf
                        As your posting above implies your debug message confirms a received message - but the message cannot be received, because the curl command doesn’t work …
                        As per your advise I’ve git pulled, restarted mirror - but get same error message as before.
                        The curl command is bad or the URL doesn’t work.
                        I don’t know why and have no idea how to figure this out…
                        Screen input- and output as follws:
                        pi@MagicMirrorPi5:~ $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                        <!DOCTYPE html>
                        <html lang="en">
                        <head>
                        </head>
                        <body>
                        </body>
                        </html>
                        pi@MagicMirrorPi5:~ $ cd MagicMirror/modules
                        pi@MagicMirrorPi5:~/MagicMirror/modules $ cd MMM-CurlToNotification/
                        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ git pull
                        Updating 71ea1c1..bd1e417
                        Fast-forward
                         MMM-CurlToNotification.js | 14 ++++++++++----
                         README.md                 |  1 +
                         node_helper.js            | 13 +++++++++++--
                         3 files changed, 22 insertions(+), 6 deletions(-)
                        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ pm2 restart MagicMirror
                        [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                        [PM2] [MagicMirror](0) ✓
                        │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                        │ 0  │ MagicMirror    │ default     │ 2.31.0… │ fork    │ 87731    │ 0s     │ 1    │ online    │ 0%       │ 2.6mb    │ pi       │ enabled  │
                        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                        <!DOCTYPE html>
                        <html lang="en">
                        <head>
                        </head>
                        <body>
                        </body>
                        </html>
                        Any additional idea?
                        regards,
                        Ralf
                          sdetweil @rkorell
                          @rkorell do curl -v
                            curl --v --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                            curl: option --v: is ambiguous
                            curl: try 'curl --help' or 'curl --manual' for more information
                              sdetweil @rkorell
                              @rkorell not double dash
                              just trying to figure out what the problem is
                              maybe curl version
                                @sdetweil OK
                                this is curl --version :-) (just successfully trial&errored)
                                curl --version
                                curl 7.88.1 (aarch64-unknown-linux-gnu) libcurl/7.88.1 OpenSSL/3.0.15 zlib/1.2.13 brotli/1.0.9 zstd/1.5.4 libidn2/2.3.3 libpsl/0.21.2 (+libidn2/2.3.3) libssh2/1.10.0 nghttp2/1.52.0 librtmp/2.3 OpenLDAP/2.5.13
                                Release-Date: 2023-02-20, security patched: 7.88.1-10+deb12u12
                                Protocols: dict file ftp ftps gopher gophers http https imap imaps ldap ldaps mqtt pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
                                Features: alt-svc AsynchDNS brotli GSS-API HSTS HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile libz NTLM NTLM_WB PSL SPNEGO SSL threadsafe TLS-SRP UnixSockets zstd
                                  @sdetweil because it doesn’t work on windows either this is most likely not a version but a command or URL thing …
                                    Dear Sam,
                                    I caught it …
                                    The Windows command is not working for other reasons - doesn’t matter…
                                    The curl on MY Pi doesn’t work because - for some strange reason the resolving of “localhost” doesn’t work ???
                                    Figured this out by using another linux client (Macbook) and therefor using IP address of pi remotely - which worked instantly.
                                    And trying this locally on Pi with IP adreees does the job as well.
                                    Thanks again for your help!
                                    Regards,
                                    Ralf
                                      sdetweil @rkorell
                                      @rkorell weird, it works on windows for me
                                      i just copy/pasted from the repo and
                                      changed the address and port at the end
                                      i can do it on the same machine or across the network to other machines
                                        sdetweil @rkorell
                                        @rkorell localhost is(always) mapped to 127.0.0.1 on the same system
                                        which is called the loopback adapter, cause the packets never leave the system
                                        ping localhost
                                        should work
                                          Yes. I’m aware of this, thanks.
                                          ping localhost
                                          should work
                                          Yes, do work:
                                          pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ ping localhost
                                          PING localhost(localhost (::1)) 56 data bytes
                                          64 bytes from localhost (::1): icmp_seq=1 ttl=64 time=0.027 ms
                                          64 bytes from localhost (::1): icmp_seq=2 ttl=64 time=0.035 ms
                                          64 bytes from localhost (::1): icmp_seq=3 ttl=64 time=0.035 ms
                                          64 bytes from localhost (::1): icmp_seq=4 ttl=64 time=0.036 ms
                                          64 bytes from localhost (::1): icmp_seq=5 ttl=64 time=0.031 ms
                                          64 bytes from localhost (::1): icmp_seq=6 ttl=64 time=0.039 ms
                                          ^Z
                                          [1]+  Stopped                 ping localhost
                                          thanks anyway,
                                          Regards,
                                          Ralf
                                            sdetweil @rkorell
                                            @rkorell so, its a curl problem… weird…
                                            but its using ipv6 (::1 is the ipv6 version of 127.0.0.1)
                                            • 3 / 4
