    • MagicMirrorΒ² Repository
    Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream
    68 Posts 5 Posters 18.3k Views 4 Watching
    • Cr4z33C Offline
      Cr4z33
      Thank you again @rkorell and @sdetweil for your precious help, but I am at a point where I don’t have enough skill to generate the needed code lines.
      What comes afterwards (ie. stop the stream, etc.) is not what worries me hehe, but all I am able to do at today is how to install a module and give it a basic config.
      Having two modules to β€œtalk” to each other is another matter and that’s where I start asking for help to people who know what they are doing (I am more a copy&paste or a tutorial follower guy). 😁
      Once again this is the RTSP URL:
      rtsp://username:password@ipaddress/cam/realmonitor?channel=1&subtype=1#backchannel=0
      and this is the MQTT button press line:
      2025-04-16 11:40:58,897 INFO __main__ Publishing MQTT message DahuaVTO/Invite/Event: {'Action': 'Pulse', 'Code': 'Invite', 'Data': {'CallID': '3', 'IsEncryptedStream': False, 'LocaleTime': '2025-04-16 11:40:58', 'LockNum': 2, 'RealUTC': 1744796458, 'SupportPaas': False, 'TCPPort': 37777, 'UTC': 1744800058.0, 'UserID': '101'}, 'Index': 0, 'deviceType': 'DHI-VTO3311Q-WP', 'serialNumber': '*******'}
      I tried creating a Home Assistant automation, but it’s probably wrong.
        sdetweil @Cr4z33
        @Cr4z33 you are composing a service that does not yet exist
        button on doorbell causes window w video stream to
        open
        appears no one has done that w this video doorbell, welcome to the bleeding edge. u get to MAKE the sausage no one else wants to see!!
        a MagicMirror module runs inside a web browser, all in javascript. it can consume info from the outside using url based apis http get or put/post
        Now, sometimes, you want module A to work with data from module B. for example calendar. it reads the raw data file (ical/ics), parses all the events, gets the list of pertinent events ( dont care about 2 years ago, only next week…)
        and displays them. hm id like a different display, but dont want to learn about all the file reading and parsing and selecting)
        MagicMirror provides a way for one module to share its data with others, called Notifications. some identifying string, with some attached data. the mechanism is a broadcast. one send, every other module gets the same message.
        if a modules doesn’t understand the identifying string, it ignores the message
        if it DOES understand the identifying string, then it MUST understand the format of the attached data.
        so, modules that DO participate in this data sharing must document ( in their readme.md file)
        what notification strings they send (and its associated data format, if any)
        AND
        what notifications strings they accept (and its required data format)
        nothing going outside the browser is known inside the browser,
        to get that kind of info requires some module to be able to bridge the two environments
        i have a simple one
        id like some way for a script running outside MagicMirror to trigger a module to do something (receive a notification it knows about)
        so i wrote MMM-CurlToNotification
        from the command line outside MagicMirror you can issue the curl command to send a packet of data that turns into a notification sent to all modules
        there are other modules that provide similar support (as well as others), mmm-remotecontrol for example
        anyhow MMM-MqttBridge does that bridging for MQTT messages. in both directions
        mqtt -> notifi(cation) and notification) -> mqtt
        but you need to know a bunch of stuff, and figure out how to code the file that does the actual work
        i work backwards
        i need a video played from a url on demand
        what modules can do that
        and how do i setup for the on demand part
        pick a module RTSPStream or Minfo, read its doc to understand what notifications it understands, and what data it needs
        install and configure the selected module
        now you β€˜could’ use my curltonotification module to verify that the video player module works
        then you back up to the MQTT bridge module config to send the same message you just tested with, and what mqtt message will trigger it
        then back up, and find/setup what will send that mqtt message
        and how it is triggered to to that
        you can draw this all out on a piece of paper
        coding is just making the computer fo the exact same thing over and over, just faster. if you dont know what, then it cant either
        someone presses the doorbell button
        how does something outside the doorbell know?
        can that something send a msg via mqtt that the bridge is listening for? if not, can i find something that that can take the first things out and get it into our expected mqtt message
        repeat along the way,
        test each step
          @sdetweil said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
          Dear Sam,
          trying to help I’m struggled with your module CurlToNotification :-(
            module:"MMM-CurlToNotification",
            config:{
              url_name:"doorbell", // the path of the url for curl post
          And consecutively running
          curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
          Shows an error message:
          pi@MagicMirrorPi5:~/MagicMirror/modules $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
          <!DOCTYPE html>
          <html lang="en">
          <head>
          <meta charset="utf-8">
          <title>Error</title>
          </head>
          <body>
          <pre>InternalServerError: stream is not readable<br> &nbsp; &nbsp;at readStream (/home/pi/MagicMirror/node_modules/raw-body/index.js:185:17)<br> &nbsp; &nbsp;at getRawBody (/home/pi/MagicMirror/node_modules/raw-body/index.js:116:12)<br> &nbsp; &nbsp;at read (/home/pi/MagicMirror/node_modules/body-parser/lib/read.js:79:3)<br> &nbsp; &nbsp;at jsonParser (/home/pi/MagicMirror/node_modules/body-parser/lib/types/json.js:138:5)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:95:5)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:91:12)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/body-parser/lib/read.js:132:5<br> &nbsp; &nbsp;at AsyncResource.runInAsyncScope (node:async_hooks:206:9)<br> &nbsp; &nbsp;at invokeCallback (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:238:16)<br> &nbsp; &nbsp;at done (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:227:7)<br> &nbsp; &nbsp;at IncomingMessage.onEnd (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:287:7)<br> &nbsp; &nbsp;at IncomingMessage.emit (node:events:518:28)<br> &nbsp; &nbsp;at endReadableNT (node:internal/streams/readable:1698:12)<br> &nbsp; &nbsp;at process.processTicksAndRejections (node:internal/process/task_queues:82:21)</pre>
          </body>
          </html>
          From Windows Client (changing localhost to MagicMirrors IP address a different error message:
          PS C:\Users\Familienbenutzer> curl --header "Content-Type: application/json"   --request POST   --data "{\"notification\":\"SHOW_ALERT\",\"payload\":{\"message\":\"fribble\"}}" http://1xx.yy.zz.157:8080/doorbell
          Invoke-WebRequest : Es wurde kein Positionsparameter gefunden, der das Argument "Content-Type: application/json"
          akzeptiert.
          In Zeile:1 Zeichen:1
          + curl --header "Content-Type: application/json"   --request POST   --d ...
              + CategoryInfo          : InvalidArgument: (:) [Invoke-WebRequest], ParameterBindingException
              + FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
          Any hint for me?
          Thanks and regards,
          Ralf
            sdetweil @rkorell
            @rkorell and you did restart MagicMirror after installing the module, right?
            you can also add config parm (make sure there is a trailing comma after doorbell
               debug:true,
              yes, indeed :-)
              And a trailing comma is there…
              In the meantime I had even a PI-reboot (for other reasons) - error persists.
              Even with debug-option enabled no debug message from your module.
              Neither in pm2 logs nor in developer’s console…
              Ralf
              S R 3 Replies Last reply Reply Quote 0
                sdetweil @rkorell
                @rkorell weird
                i am away from my computer for most of the day helping family
                i will review asap
                  @sdetweil Take your time!
                  Family is most important.
                  This issue is REALLY not important, neither urgent.
                  I do not need this module right now - was just for testing, if I can help @Cr4z33 further with some examples to copy - as asked.
                  So don’t hurry.
                  Ralf
                    rkorell Module Developer @rkorell
                    @rkorell said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
                    all messages in dev-console …
                      startup log
                      0|MagicMir | > magicmirror@2.31.0-develop start
                      0|MagicMir | > npm run start:x11
                      0|MagicMir |
                      0|MagicMir |
                      0|MagicMir | > magicmirror@2.31.0-develop start:x11
                      0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                      0|MagicMir |
                      0|MagicMir | [2025-05-03 17:06:27.179] [LOG]   Starting MagicMirror: v2.31.0-develop
                      0|MagicMir | [2025-05-03 17:06:27.189] [LOG]   Loading config ...
                      0|MagicMir | [2025-05-03 17:06:27.190] [LOG]   config template file not exists, no envsubst
                      0|MagicMir | [2025-05-03 17:06:27.369] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
                      0|MagicMir | [2025-05-03 17:06:27.436] [INFO]  Your configuration file doesn't contain syntax errors :)
                      0|MagicMir | [2025-05-03 17:06:27.437] [INFO]  Checking modules structure configuration ...
                      0|MagicMir | [2025-05-03 17:06:27.473] [INFO]  Your modules structure configuration doesn't contain errors :)
                      0|MagicMir | [2025-05-03 17:06:27.474] [LOG]   Loading module helpers ...
                      0|MagicMir | [2025-05-03 17:06:27.474] [LOG]   No helper found for module: alert.
                      0|MagicMir | [2025-05-03 17:06:27.475] [LOG]   No helper found for module: MMM-MagicMover.
                      0|MagicMir | [2025-05-03 17:06:27.476] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   Module helper loaded: MMM-CurlToNotification
                      0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   No helper found for module: clock.
                      0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   No helper found for module: MMM-Profilepicture.
                      0|MagicMir | [2025-05-03 17:06:27.484] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.484] [LOG]   Module helper loaded: MMM-Logging
                      0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   Module helper loaded: MMM-MoonPhase
                      0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   No helper found for module: MMM-Globe.
                      0|MagicMir | [2025-05-03 17:06:27.492] [LOG]   No helper found for module: weather.
                      0|MagicMir | [2025-05-03 17:06:27.523] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.524] [LOG]   Module helper loaded: MMM-JsonValue
                      0|MagicMir | [2025-05-03 17:06:27.531] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.531] [LOG]   Module helper loaded: MMM-MyGarbage
                      0|MagicMir | [2025-05-03 17:06:27.532] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
                      0|MagicMir | [2025-05-03 17:06:27.532] [LOG]   No helper found for module: MMM-RAIN-MAP.
                      0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Check MagicMirrorΒ² version for node helper 'MMM-Strava' - Minimum version: 2.2.0 - Current version: 2.31.0-develop
                      0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Version is ok!
                      0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Module helper loaded: MMM-Strava
                      0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   Module helper loaded: MMM-Todoist
                      0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   No helper found for module: MMM-UselessFacts.
                      0|MagicMir | [2025-05-03 17:06:27.748] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.748] [LOG]   Module helper loaded: MMM-FRITZ-Box-Callmonitor-py3
                      0|MagicMir | [2025-05-03 17:06:27.749] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.749] [LOG]   Module helper loaded: MMM-SystemMonitor
                      0|MagicMir | [2025-05-03 17:06:27.750] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.750] [LOG]   Module helper loaded: MMM-SystemInfo
                      0|MagicMir | [2025-05-03 17:06:27.782] [LOG]   2025-05-03T17:06:27 <log> init module helper birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:15 Class.init)
                      0|MagicMir | [2025-05-03 17:06:27.782] [LOG]   Module helper loaded: birthdaylist
                      0|MagicMir | [2025-05-03 17:06:27.898] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.899] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
                      0|MagicMir | [2025-05-03 17:06:27.925] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.925] [LOG]   Module helper loaded: newsfeed
                      0|MagicMir | [2025-05-03 17:06:27.945] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.945] [LOG]   Module helper loaded: MMM-Remote-Control
                      0|MagicMir | [2025-05-03 17:06:27.982] [LOG]   Initializing new module helper ...
                      0|MagicMir | [2025-05-03 17:06:27.983] [LOG]   Module helper loaded: calendar
                      0|MagicMir | [2025-05-03 17:06:27.983] [LOG]   All module helpers loaded.
                      0|MagicMir | [2025-05-03 17:06:27.986] [LOG]   Starting server on port 8080 ...
                      0|MagicMir | [2025-05-03 17:06:28.296] [LOG]   Server started ...
                      0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Connecting socket for: MMM-CurlToNotification
                      0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Starting module helper: MMM-CurlToNotification
                      0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Connecting socket for: MMM-Logging
                      0|MagicMir | [2025-05-03 17:06:28.298] [LOG]   2025-05-03T17:06:28 <log> Module helper started for MMM-Logging (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:19 Class.start)
                      0|MagicMir | [2025-05-03 17:06:28.298] [LOG]   Connecting socket for: MMM-MoonPhase
                      0|MagicMir | [2025-05-03 17:06:28.304] [LOG]   Starting module helper: MMM-MoonPhase
                      0|MagicMir | [2025-05-03 17:06:28.304] [LOG]   Connecting socket for: MMM-JsonValue
                      0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   Connecting socket for: MMM-MyGarbage
                      0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   2025-05-03T17:06:28 <log> Starting node_helper for module: MMM-MyGarbage (/home/pi/MagicMirror/modules/MMM-MyGarbage/node_helper.js:9 Class.start)
                      0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   Connecting socket for: MMM-Strava
                      0|MagicMir | [2025-05-03 17:06:28.306] [LOG]   2025-05-03T17:06:28 <log> Starting module helper: MMM-Strava (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:47 Class.start)
                      0|MagicMir | [2025-05-03 17:06:28.306] [LOG]   Connecting socket for: MMM-Todoist
                      0|MagicMir | [2025-05-03 17:06:28.307] [LOG]   2025-05-03T17:06:28 <log> Starting node helper for: MMM-Todoist (/home/pi/MagicMirror/modules/MMM-Todoist/node_helper.js:19 Class.start)
                      0|MagicMir | [2025-05-03 17:06:28.307] [LOG]   Connecting socket for: MMM-FRITZ-Box-Callmonitor-py3
                      0|MagicMir | [2025-05-03 17:06:28.312] [LOG]   2025-05-03T17:06:28 <log> Starting module: MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:28 Class.start)
                      0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: MMM-SystemMonitor
                      0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Starting module helper: MMM-SystemMonitor
                      0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: MMM-SystemInfo
                      0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Starting node helper: MMM-SystemInfo
                      0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: birthdaylist
                      0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify
                      0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Connecting socket for: newsfeed
                      0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Starting node helper for: newsfeed
                      0|MagicMir | [2025-05-03 17:06:28.318] [LOG]   Connecting socket for: MMM-Remote-Control
                      0|MagicMir | [2025-05-03 17:06:28.319] [LOG]   Starting node helper for: MMM-Remote-Control
                      0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Connecting socket for: calendar
                      0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Starting node helper for: calendar
                      0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Sockets connected & modules started ...
                      0|MagicMir | [2025-05-03 17:06:28.540] [LOG]   Launching application.
                      0|MagicMir | [2025-05-03 17:06:28.915] [INFO]  System information:
                      0|MagicMir | ### SYSTEM:   manufacturer: ; model: ; virtual: false
                      0|MagicMir | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-2712
                      0|MagicMir | ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                      0|MagicMir | ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                      0|MagicMir | [2025-05-03 17:06:29.613] [LOG]   [MMM-Remote-Control] Could not get defaults for MMM-RAIN-MAP. See #335.
                      0|MagicMir | [2025-05-03 17:06:31.249] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/xxxxxxxxxxxx%40group.calendar.google.com/private-5yyyyyyyyyyyyyyyyyyyyyy/basic.ics - Interval: 300000
                      0|MagicMir | [2025-05-03 17:06:31.278] [LOG]   2025-05-03T17:06:31 <info> MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
                      0|MagicMir | [2025-05-03 17:06:31.279] [LOG]   2025-05-03T17:06:31 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                      0|MagicMir | [2025-05-03 17:06:31.303] [LOG]   2025-05-03T17:06:31 <log> Received config for MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:56 Class.socketNotificationReceived)
                      0|MagicMir | [2025-05-03 17:06:31.304] [LOG]   2025-05-03T17:06:31 <log> MMM-FRITZ-Box-Callmonitor-py3 is waiting for incoming calls. (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:118 Class.setupMonitor)
                      0|MagicMir | [2025-05-03 17:06:31.376] [LOG]   Create new newsfetcher for url: https://www.gutekueche.de/feed/wochenrezepte - Interval: 300000
                      0|MagicMir | [2025-05-03 17:06:31.382] [LOG]   Create new newsfetcher for url: https://www.gutekueche.de/feed/tagesrezept - Interval: 300000
                      0|MagicMir | [2025-05-03 17:06:31.385] [LOG]   Create new newsfetcher for url: https://www.chefkoch.de/recipe-of-the-day/rss - Interval: 300000
                      0|MagicMir | [2025-05-03 17:06:31.389] [LOG]   Create new calendarfetcher for url: https://www.feiertage-deutschland.de/kalender-download/ics/feiertage-deutschland.ics - Interval: 604800000
                      0|MagicMir | [2025-05-03 17:06:31.394] [LOG]   2025-05-03T17:06:31 <log> Starting module helper:  birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:27 Class.socketNotificationReceived)
                      0|MagicMir | [2025-05-03 17:06:32.046] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                      0|MagicMir | [2025-05-03 17:06:32.050] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                      0|MagicMir | [2025-05-03 17:06:32.194] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                      0|MagicMir | [2025-05-03 17:06:32.353] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                      0|MagicMir | [2025-05-03 17:06:32.398] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                      0|MagicMir | [2025-05-03 17:06:32.495] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                      0|MagicMir | [2025-05-03 17:06:32.734] [INFO]  Calendar-Fetcher: Broadcasting 51 events from https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-yyyyyyyyyyyyyyyyyyyyyyyyyyyy/basic.ics.
                      0|MagicMir | [2025-05-03 17:06:32.827] [LOG]   2025-05-03T17:06:32 <log> Refreshed access token because it has expired. Expired at: 17:06:31 now is: 17:06:32 (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/core/SpotifyConnector.js:24 )
                      0|MagicMir | [2025-05-03 17:06:33.418] [LOG]   2025-05-03T17:06:33 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                      0|MagicMir | [2025-05-03 17:06:34.302] [INFO]  Calendar-Fetcher: Broadcasting 22 events from https://www.feiertage-deutschland.de/kalender-download/ics/feiertage-deutschland.ics.
                        sdetweil @rkorell
                        @rkorell git pull in the module folder restart MM
                        in the npm start output, should see (I sent 3 requests)
                        [2025-05-03 18:30:03.519] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'HIDE_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
                        [2025-05-03 18:30:36.302] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'SHOW_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
                        [2025-05-03 18:31:00.765] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'HIDE_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
                        and in the dev console
                        MMM-CurlToNotification.js:14 MMM-CurlToNotification received request to send notication  HIDE_ALERT  with payload  {message: 'fribble'}
                        MMM-CurlToNotification.js:14 MMM-CurlToNotification received request to send notication  SHOW_ALERT  with payload  {message: 'fribble'}
                          @sdetweil I`m away from home today, will check tomorrow…
                          Thanks.
                          Ralf
                            As your posting above implies your debug message confirms a received message - but the message cannot be received, because the curl command doesn’t work …
                            As per your advise I’ve git pulled, restarted mirror - but get same error message as before.
                            The curl command is bad or the URL doesn’t work.
                            I don’t know why and have no idea how to figure this out…
                            Screen input- and output as follws:
                            pi@MagicMirrorPi5:~ $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                            <!DOCTYPE html>
                            <html lang="en">
                            <head>
                            </head>
                            <body>
                            </body>
                            </html>
                            pi@MagicMirrorPi5:~ $ cd MagicMirror/modules
                            pi@MagicMirrorPi5:~/MagicMirror/modules $ cd MMM-CurlToNotification/
                            pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ git pull
                            Updating 71ea1c1..bd1e417
                            Fast-forward
                             MMM-CurlToNotification.js | 14 ++++++++++----
                             README.md                 |  1 +
                             node_helper.js            | 13 +++++++++++--
                             3 files changed, 22 insertions(+), 6 deletions(-)
                            pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ pm2 restart MagicMirror
                            [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                            [PM2] [MagicMirror](0) βœ“
                            β”Œβ”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
                            β”‚ id β”‚ name           β”‚ namespace   β”‚ version β”‚ mode    β”‚ pid      β”‚ uptime β”‚ β†Ί    β”‚ status    β”‚ cpu      β”‚ mem      β”‚ user     β”‚ watching β”‚
                            β”œβ”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€
                            β”‚ 0  β”‚ MagicMirror    β”‚ default     β”‚ 2.31.0… β”‚ fork    β”‚ 87731    β”‚ 0s     β”‚ 1    β”‚ online    β”‚ 0%       β”‚ 2.6mb    β”‚ pi       β”‚ enabled  β”‚
                            β””β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
                            pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                            <!DOCTYPE html>
                            <html lang="en">
                            <head>
                            </head>
                            <body>
                            </body>
                            </html>
                            Any additional idea?
                            regards,
                            Ralf
                              sdetweil @rkorell
                              @rkorell do curl -v
                                curl --v --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                                curl: option --v: is ambiguous
                                curl: try 'curl --help' or 'curl --manual' for more information
                                  sdetweil @rkorell
                                  @rkorell not double dash
                                  just trying to figure out what the problem is
                                  maybe curl version
                                    @sdetweil OK
                                    this is curl --version :-) (just successfully trial&errored)
                                    curl --version
                                    curl 7.88.1 (aarch64-unknown-linux-gnu) libcurl/7.88.1 OpenSSL/3.0.15 zlib/1.2.13 brotli/1.0.9 zstd/1.5.4 libidn2/2.3.3 libpsl/0.21.2 (+libidn2/2.3.3) libssh2/1.10.0 nghttp2/1.52.0 librtmp/2.3 OpenLDAP/2.5.13
                                    Release-Date: 2023-02-20, security patched: 7.88.1-10+deb12u12
                                    Protocols: dict file ftp ftps gopher gophers http https imap imaps ldap ldaps mqtt pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
                                    Features: alt-svc AsynchDNS brotli GSS-API HSTS HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile libz NTLM NTLM_WB PSL SPNEGO SSL threadsafe TLS-SRP UnixSockets zstd
                                      @sdetweil because it doesn’t work on windows either this is most likely not a version but a command or URL thing …
                                        Dear Sam,
                                        I caught it …
                                        The Windows command is not working for other reasons - doesn’t matter…
                                        The curl on MY Pi doesn’t work because - for some strange reason the resolving of β€œlocalhost” doesn’t work ???
                                        Figured this out by using another linux client (Macbook) and therefor using IP address of pi remotely - which worked instantly.
                                        And trying this locally on Pi with IP adreees does the job as well.
                                        Thanks again for your help!
                                        Regards,
                                        Ralf
                                          sdetweil @rkorell
                                          @rkorell weird, it works on windows for me
                                          i just copy/pasted from the repo and
                                          changed the address and port at the end
                                          i can do it on the same machine or across the network to other machines
                                            sdetweil @rkorell
                                            @rkorell localhost is(always) mapped to 127.0.0.1 on the same system
                                            which is called the loopback adapter, cause the packets never leave the system
                                            ping localhost
                                            should work
                                            With your input, this post could be even better πŸ’—
                                            • 3 / 4
