    • MagicMirrorΒ² Repository
    Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream
    68 Posts 5 Posters 23.9k Views 4 Watching
      sdetweil @rkorell
      @rkorell git pull in the module folder restart MM
      in the npm start output, should see (I sent 3 requests)
      [2025-05-03 18:30:03.519] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'HIDE_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
      [2025-05-03 18:30:36.302] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'SHOW_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
      [2025-05-03 18:31:00.765] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'HIDE_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
      and in the dev console
      MMM-CurlToNotification.js:14 MMM-CurlToNotification received request to send notication  HIDE_ALERT  with payload  {message: 'fribble'}
      MMM-CurlToNotification.js:14 MMM-CurlToNotification received request to send notication  SHOW_ALERT  with payload  {message: 'fribble'}
      • R Online
        @sdetweil I`m away from home today, will check tomorrow…
        Thanks.
        Ralf
        • R Online
          As your posting above implies your debug message confirms a received message - but the message cannot be received, because the curl command doesn’t work …
          As per your advise I’ve git pulled, restarted mirror - but get same error message as before.
          The curl command is bad or the URL doesn’t work.
          I don’t know why and have no idea how to figure this out…
          Screen input- and output as follws:
          pi@MagicMirrorPi5:~ $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
          <!DOCTYPE html>
          <html lang="en">
          <head>
          <meta charset="utf-8">
          <title>Error</title>
          </head>
          <body>
          <pre>InternalServerError: stream is not readable<br> &nbsp; &nbsp;at readStream (/home/pi/MagicMirror/node_modules/raw-body/index.js:185:17)<br> &nbsp; &nbsp;at getRawBody (/home/pi/MagicMirror/node_modules/raw-body/index.js:116:12)<br> &nbsp; &nbsp;at read (/home/pi/MagicMirror/node_modules/body-parser/lib/read.js:79:3)<br> &nbsp; &nbsp;at jsonParser (/home/pi/MagicMirror/node_modules/body-parser/lib/types/json.js:138:5)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:95:5)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:91:12)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/body-parser/lib/read.js:132:5<br> &nbsp; &nbsp;at AsyncResource.runInAsyncScope (node:async_hooks:206:9)<br> &nbsp; &nbsp;at invokeCallback (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:238:16)<br> &nbsp; &nbsp;at done (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:227:7)<br> &nbsp; &nbsp;at IncomingMessage.onEnd (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:287:7)<br> &nbsp; &nbsp;at IncomingMessage.emit (node:events:518:28)<br> &nbsp; &nbsp;at endReadableNT (node:internal/streams/readable:1698:12)<br> &nbsp; &nbsp;at process.processTicksAndRejections (node:internal/process/task_queues:82:21)</pre>
          </body>
          </html>
          pi@MagicMirrorPi5:~ $ cd MagicMirror/modules
          pi@MagicMirrorPi5:~/MagicMirror/modules $ cd MMM-CurlToNotification/
          pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ git pull
          Updating 71ea1c1..bd1e417
          Fast-forward
           MMM-CurlToNotification.js | 14 ++++++++++----
           README.md                 |  1 +
           node_helper.js            | 13 +++++++++++--
           3 files changed, 22 insertions(+), 6 deletions(-)
          pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ pm2 restart MagicMirror
          [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
          [PM2] [MagicMirror](0) βœ“
          β”Œβ”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
          β”‚ id β”‚ name           β”‚ namespace   β”‚ version β”‚ mode    β”‚ pid      β”‚ uptime β”‚ β†Ί    β”‚ status    β”‚ cpu      β”‚ mem      β”‚ user     β”‚ watching β”‚
          β”œβ”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€
          β”‚ 0  β”‚ MagicMirror    β”‚ default     β”‚ 2.31.0… β”‚ fork    β”‚ 87731    β”‚ 0s     β”‚ 1    β”‚ online    β”‚ 0%       β”‚ 2.6mb    β”‚ pi       β”‚ enabled  β”‚
          β””β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
          pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
          <!DOCTYPE html>
          <html lang="en">
          <head>
          </head>
          <body>
          </body>
          </html>
          Any additional idea?
          regards,
          Ralf
            sdetweil @rkorell
            @rkorell do curl -v
            • R Online
              curl --v --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
              curl: option --v: is ambiguous
              curl: try 'curl --help' or 'curl --manual' for more information
                sdetweil @rkorell
                @rkorell not double dash
                just trying to figure out what the problem is
                maybe curl version
                R 3 Replies Last reply Reply Quote 0
                • R Online
                  @sdetweil OK
                  this is curl --version :-) (just successfully trial&errored)
                  curl --version
                  curl 7.88.1 (aarch64-unknown-linux-gnu) libcurl/7.88.1 OpenSSL/3.0.15 zlib/1.2.13 brotli/1.0.9 zstd/1.5.4 libidn2/2.3.3 libpsl/0.21.2 (+libidn2/2.3.3) libssh2/1.10.0 nghttp2/1.52.0 librtmp/2.3 OpenLDAP/2.5.13
                  Release-Date: 2023-02-20, security patched: 7.88.1-10+deb12u12
                  Protocols: dict file ftp ftps gopher gophers http https imap imaps ldap ldaps mqtt pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
                  Features: alt-svc AsynchDNS brotli GSS-API HSTS HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile libz NTLM NTLM_WB PSL SPNEGO SSL threadsafe TLS-SRP UnixSockets zstd
                  • R Online
                    @sdetweil because it doesn’t work on windows either this is most likely not a version but a command or URL thing …
                    • R Online
                      @sdetweil said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
                      Dear Sam,
                      I caught it …
                      The Windows command is not working for other reasons - doesn’t matter…
                      The curl on MY Pi doesn’t work because - for some strange reason the resolving of β€œlocalhost” doesn’t work ???
                      Figured this out by using another linux client (Macbook) and therefor using IP address of pi remotely - which worked instantly.
                      And trying this locally on Pi with IP adreees does the job as well.
                      Thanks again for your help!
                      Regards,
                      Ralf
                        sdetweil @rkorell
                        @rkorell weird, it works on windows for me
                        i just copy/pasted from the repo and
                        changed the address and port at the end
                        i can do it on the same machine or across the network to other machines
                          sdetweil @rkorell
                          @rkorell localhost is(always) mapped to 127.0.0.1 on the same system
                          which is called the loopback adapter, cause the packets never leave the system
                          ping localhost
                          should work
                          • R Online
                            Yes. I’m aware of this, thanks.
                            ping localhost
                            should work
                            Yes, do work:
                            pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ ping localhost
                            PING localhost(localhost (::1)) 56 data bytes
                            64 bytes from localhost (::1): icmp_seq=1 ttl=64 time=0.027 ms
                            64 bytes from localhost (::1): icmp_seq=2 ttl=64 time=0.035 ms
                            64 bytes from localhost (::1): icmp_seq=3 ttl=64 time=0.035 ms
                            64 bytes from localhost (::1): icmp_seq=4 ttl=64 time=0.036 ms
                            64 bytes from localhost (::1): icmp_seq=5 ttl=64 time=0.031 ms
                            64 bytes from localhost (::1): icmp_seq=6 ttl=64 time=0.039 ms
                            ^Z
                            [1]+  Stopped                 ping localhost
                            thanks anyway,
                            Regards,
                            Ralf
                              sdetweil @rkorell
                              @rkorell so, its a curl problem… weird…
                              but its using ipv6 (::1 is the ipv6 version of 127.0.0.1)
                              • R Online
                                good catch!
                                THis may is the reason, because - as far as I. know - ipV6 isn’t implemented (properly?) in my network (at least I do not have anything configured. My AVM (Fritzbox) router is ipV6 aware but I do not β€œuse” it esplicitely …
                                Strange!
                                Ralf
                                  sdetweil @rkorell
                                  @rkorell can you edit your /etc/hosts
                                  to see how localhost is defined
                                  on my amd host it is
                                  127.0.0.1       localhost
                                  on my pi it is
                                  127.0.0.1       localhost
                                  ::1             localhost ip6-localhost ip6-loopback
                                  • R Online
                                    @sdetweil Oh, yes - I remember …
                                    interesting enough my /etc/hosts is likely the same as on your Pi - with ipV6 entries.
                                    If I delete them, error remains :-(
                                    Ralf
                                      sdetweil @rkorell
                                      @rkorell weird
                                      • R Online
                                        @sdetweil :-) indeed
                                        • R Online
                                          @sdetweil and now 3hours later more weird it doesn’t work with IP address as well.
                                          In addition for some strange reason the enablement of the MMM-Mplayer module leads to unrecoverable disconnects of PI from network.
                                          This currently is too much resistance to me, so sorry dear @Cr4z33 - I’m not able to dig in deeper to assist you…
                                          Regards,
                                          Ralf
                                          • Cr4z33C Offline
                                            Cr4z33 @rkorell
                                            Once again thank you @rkorell and @sdetweil for willing to help me!
                                            Unfortunately real life last minute serious event had to stop me to dedicate to this matter for a long while.
                                            With your input, this post could be even better πŸ’—
                                            • 3 / 4
