    Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream
    68 Posts 5 Posters 23.9k Views 4 Watching
      rkorell Module Developer @rkorell
      @rkorell @Cr4z33 with writing the above I’ve just noticed:
      Your RTSP module is NOT “RTSP-play” but "MMM-RTSPStream" !
      This should be your first trial then in your mqttDisctionary.js …
        sdetweil @rkorell
        @rkorell MMM-MPlayer should work for displaying on notification
          @sdetweil cool.
          had played around with this and it was frickling to position - but worth a try … :-)
            @rkorell said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
            @Cr4z33 just found “source” : you have copied this configuration .
            But I bet you have to place the module name as “notiID” …
            this is not “RTSP-play” but “MMM-RTSPStream” …
            Regards,
            Ralf
            (Pay attention : it is highly probably case-sensitive …)
              @Cr4z33
              MMM-RTSPStream is quite old and the author himself doesn’t use it anymore and recommend indeed other modules.
              So it a a wise advice from Sam (@sdetweil ) to use MMM-Mplayer …
              This one still have an active discussion here .
              Ralf
                @rkorell said
                use MMM-Mplayer …
                Just checked: You CAN use MMM-Pages notification to start and stop your stream …
                (e.g. “NEW_PAGE=0” will start the stream.
                Unfortunately you will have to care about switching OFF the stream by yourself - I guess the doorbell will not be sufficient to send a “STOP” signal - You likely would to see the stream longer that the visitor is pressing the doorbellbutton …
                Ralf
                • Cr4z33C Offline
                  Cr4z33
                  Thank you again @rkorell and @sdetweil for your precious help, but I am at a point where I don’t have enough skill to generate the needed code lines.
                  What comes afterwards (ie. stop the stream, etc.) is not what worries me hehe, but all I am able to do at today is how to install a module and give it a basic config.
                  Having two modules to “talk” to each other is another matter and that’s where I start asking for help to people who know what they are doing (I am more a copy&paste or a tutorial follower guy). 😁
                  Once again this is the RTSP URL:
                  rtsp://username:password@ipaddress/cam/realmonitor?channel=1&subtype=1#backchannel=0
                  and this is the MQTT button press line:
                  2025-04-16 11:40:58,897 INFO __main__ Publishing MQTT message DahuaVTO/Invite/Event: {'Action': 'Pulse', 'Code': 'Invite', 'Data': {'CallID': '3', 'IsEncryptedStream': False, 'LocaleTime': '2025-04-16 11:40:58', 'LockNum': 2, 'RealUTC': 1744796458, 'SupportPaas': False, 'TCPPort': 37777, 'UTC': 1744800058.0, 'UserID': '101'}, 'Index': 0, 'deviceType': 'DHI-VTO3311Q-WP', 'serialNumber': '*******'}
                  I tried creating a Home Assistant automation, but it’s probably wrong.
                    sdetweil @Cr4z33
                    @Cr4z33 you are composing a service that does not yet exist
                    button on doorbell causes window w video stream to
                    open
                    appears no one has done that w this video doorbell, welcome to the bleeding edge. u get to MAKE the sausage no one else wants to see!!
                    a MagicMirror module runs inside a web browser, all in javascript. it can consume info from the outside using url based apis http get or put/post
                    Now, sometimes, you want module A to work with data from module B. for example calendar. it reads the raw data file (ical/ics), parses all the events, gets the list of pertinent events ( dont care about 2 years ago, only next week…)
                    and displays them. hm id like a different display, but dont want to learn about all the file reading and parsing and selecting)
                    MagicMirror provides a way for one module to share its data with others, called Notifications. some identifying string, with some attached data. the mechanism is a broadcast. one send, every other module gets the same message.
                    if a modules doesn’t understand the identifying string, it ignores the message
                    if it DOES understand the identifying string, then it MUST understand the format of the attached data.
                    so, modules that DO participate in this data sharing must document ( in their readme.md file)
                    what notification strings they send (and its associated data format, if any)
                    AND
                    what notifications strings they accept (and its required data format)
                    nothing going outside the browser is known inside the browser,
                    to get that kind of info requires some module to be able to bridge the two environments
                    i have a simple one
                    id like some way for a script running outside MagicMirror to trigger a module to do something (receive a notification it knows about)
                    so i wrote MMM-CurlToNotification
                    from the command line outside MagicMirror you can issue the curl command to send a packet of data that turns into a notification sent to all modules
                    there are other modules that provide similar support (as well as others), mmm-remotecontrol for example
                    anyhow MMM-MqttBridge does that bridging for MQTT messages. in both directions
                    mqtt -> notifi(cation) and notification) -> mqtt
                    but you need to know a bunch of stuff, and figure out how to code the file that does the actual work
                    i work backwards
                    i need a video played from a url on demand
                    what modules can do that
                    and how do i setup for the on demand part
                    pick a module RTSPStream or Minfo, read its doc to understand what notifications it understands, and what data it needs
                    install and configure the selected module
                    now you ‘could’ use my curltonotification module to verify that the video player module works
                    then you back up to the MQTT bridge module config to send the same message you just tested with, and what mqtt message will trigger it
                    then back up, and find/setup what will send that mqtt message
                    and how it is triggered to to that
                    you can draw this all out on a piece of paper
                    coding is just making the computer fo the exact same thing over and over, just faster. if you dont know what, then it cant either
                    someone presses the doorbell button
                    how does something outside the doorbell know?
                    can that something send a msg via mqtt that the bridge is listening for? if not, can i find something that that can take the first things out and get it into our expected mqtt message
                    repeat along the way,
                    test each step
                      @sdetweil said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
                      Dear Sam,
                      trying to help I’m struggled with your module CurlToNotification :-(
                        module:"MMM-CurlToNotification",
                        config:{
                          url_name:"doorbell", // the path of the url for curl post
                      And consecutively running
                      curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                      Shows an error message:
                      pi@MagicMirrorPi5:~/MagicMirror/modules $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                      <!DOCTYPE html>
                      <html lang="en">
                      <head>
                      <meta charset="utf-8">
                      <title>Error</title>
                      </head>
                      <body>
                      <pre>InternalServerError: stream is not readable<br> &nbsp; &nbsp;at readStream (/home/pi/MagicMirror/node_modules/raw-body/index.js:185:17)<br> &nbsp; &nbsp;at getRawBody (/home/pi/MagicMirror/node_modules/raw-body/index.js:116:12)<br> &nbsp; &nbsp;at read (/home/pi/MagicMirror/node_modules/body-parser/lib/read.js:79:3)<br> &nbsp; &nbsp;at jsonParser (/home/pi/MagicMirror/node_modules/body-parser/lib/types/json.js:138:5)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:95:5)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:91:12)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/body-parser/lib/read.js:132:5<br> &nbsp; &nbsp;at AsyncResource.runInAsyncScope (node:async_hooks:206:9)<br> &nbsp; &nbsp;at invokeCallback (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:238:16)<br> &nbsp; &nbsp;at done (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:227:7)<br> &nbsp; &nbsp;at IncomingMessage.onEnd (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:287:7)<br> &nbsp; &nbsp;at IncomingMessage.emit (node:events:518:28)<br> &nbsp; &nbsp;at endReadableNT (node:internal/streams/readable:1698:12)<br> &nbsp; &nbsp;at process.processTicksAndRejections (node:internal/process/task_queues:82:21)</pre>
                      </body>
                      </html>
                      From Windows Client (changing localhost to MagicMirrors IP address a different error message:
                      PS C:\Users\Familienbenutzer> curl --header "Content-Type: application/json"   --request POST   --data "{\"notification\":\"SHOW_ALERT\",\"payload\":{\"message\":\"fribble\"}}" http://1xx.yy.zz.157:8080/doorbell
                      Invoke-WebRequest : Es wurde kein Positionsparameter gefunden, der das Argument "Content-Type: application/json"
                      akzeptiert.
                      In Zeile:1 Zeichen:1
                      + curl --header "Content-Type: application/json"   --request POST   --d ...
                          + CategoryInfo          : InvalidArgument: (:) [Invoke-WebRequest], ParameterBindingException
                          + FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
                      Any hint for me?
                      Thanks and regards,
                      Ralf
                        sdetweil @rkorell
                        @rkorell and you did restart MagicMirror after installing the module, right?
                        you can also add config parm (make sure there is a trailing comma after doorbell
                           debug:true,
                          yes, indeed :-)
                          And a trailing comma is there…
                          In the meantime I had even a PI-reboot (for other reasons) - error persists.
                          Even with debug-option enabled no debug message from your module.
                          Neither in pm2 logs nor in developer’s console…
                          Ralf
                          S R 3 Replies Last reply Reply Quote 0
                            sdetweil @rkorell
                            @rkorell weird
                            i am away from my computer for most of the day helping family
                            i will review asap
                              @sdetweil Take your time!
                              Family is most important.
                              This issue is REALLY not important, neither urgent.
                              I do not need this module right now - was just for testing, if I can help @Cr4z33 further with some examples to copy - as asked.
                              So don’t hurry.
                              Ralf
                                all messages in dev-console …
                                  startup log
                                  0|MagicMir | > magicmirror@2.31.0-develop start
                                  0|MagicMir | > npm run start:x11
                                  0|MagicMir |
                                  0|MagicMir |
                                  0|MagicMir | > magicmirror@2.31.0-develop start:x11
                                  0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                  0|MagicMir |
                                  0|MagicMir | [2025-05-03 17:06:27.179] [LOG]   Starting MagicMirror: v2.31.0-develop
                                  0|MagicMir | [2025-05-03 17:06:27.189] [LOG]   Loading config ...
                                  0|MagicMir | [2025-05-03 17:06:27.190] [LOG]   config template file not exists, no envsubst
                                  0|MagicMir | [2025-05-03 17:06:27.369] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
                                  0|MagicMir | [2025-05-03 17:06:27.436] [INFO]  Your configuration file doesn't contain syntax errors :)
                                  0|MagicMir | [2025-05-03 17:06:27.437] [INFO]  Checking modules structure configuration ...
                                  0|MagicMir | [2025-05-03 17:06:27.473] [INFO]  Your modules structure configuration doesn't contain errors :)
                                  0|MagicMir | [2025-05-03 17:06:27.474] [LOG]   Loading module helpers ...
                                  0|MagicMir | [2025-05-03 17:06:27.474] [LOG]   No helper found for module: alert.
                                  0|MagicMir | [2025-05-03 17:06:27.475] [LOG]   No helper found for module: MMM-MagicMover.
                                  0|MagicMir | [2025-05-03 17:06:27.476] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   Module helper loaded: MMM-CurlToNotification
                                  0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   No helper found for module: clock.
                                  0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   No helper found for module: MMM-Profilepicture.
                                  0|MagicMir | [2025-05-03 17:06:27.484] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.484] [LOG]   Module helper loaded: MMM-Logging
                                  0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   Module helper loaded: MMM-MoonPhase
                                  0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   No helper found for module: MMM-Globe.
                                  0|MagicMir | [2025-05-03 17:06:27.492] [LOG]   No helper found for module: weather.
                                  0|MagicMir | [2025-05-03 17:06:27.523] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.524] [LOG]   Module helper loaded: MMM-JsonValue
                                  0|MagicMir | [2025-05-03 17:06:27.531] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.531] [LOG]   Module helper loaded: MMM-MyGarbage
                                  0|MagicMir | [2025-05-03 17:06:27.532] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
                                  0|MagicMir | [2025-05-03 17:06:27.532] [LOG]   No helper found for module: MMM-RAIN-MAP.
                                  0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Check MagicMirror² version for node helper 'MMM-Strava' - Minimum version: 2.2.0 - Current version: 2.31.0-develop
                                  0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Version is ok!
                                  0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Module helper loaded: MMM-Strava
                                  0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   Module helper loaded: MMM-Todoist
                                  0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   No helper found for module: MMM-UselessFacts.
                                  0|MagicMir | [2025-05-03 17:06:27.748] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.748] [LOG]   Module helper loaded: MMM-FRITZ-Box-Callmonitor-py3
                                  0|MagicMir | [2025-05-03 17:06:27.749] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.749] [LOG]   Module helper loaded: MMM-SystemMonitor
                                  0|MagicMir | [2025-05-03 17:06:27.750] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.750] [LOG]   Module helper loaded: MMM-SystemInfo
                                  0|MagicMir | [2025-05-03 17:06:27.782] [LOG]   2025-05-03T17:06:27 <log> init module helper birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:15 Class.init)
                                  0|MagicMir | [2025-05-03 17:06:27.782] [LOG]   Module helper loaded: birthdaylist
                                  0|MagicMir | [2025-05-03 17:06:27.898] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.899] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
                                  0|MagicMir | [2025-05-03 17:06:27.925] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.925] [LOG]   Module helper loaded: newsfeed
                                  0|MagicMir | [2025-05-03 17:06:27.945] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.945] [LOG]   Module helper loaded: MMM-Remote-Control
                                  0|MagicMir | [2025-05-03 17:06:27.982] [LOG]   Initializing new module helper ...
                                  0|MagicMir | [2025-05-03 17:06:27.983] [LOG]   Module helper loaded: calendar
                                  0|MagicMir | [2025-05-03 17:06:27.983] [LOG]   All module helpers loaded.
                                  0|MagicMir | [2025-05-03 17:06:27.986] [LOG]   Starting server on port 8080 ...
                                  0|MagicMir | [2025-05-03 17:06:28.296] [LOG]   Server started ...
                                  0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Connecting socket for: MMM-CurlToNotification
                                  0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Starting module helper: MMM-CurlToNotification
                                  0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Connecting socket for: MMM-Logging
                                  0|MagicMir | [2025-05-03 17:06:28.298] [LOG]   2025-05-03T17:06:28 <log> Module helper started for MMM-Logging (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:19 Class.start)
                                  0|MagicMir | [2025-05-03 17:06:28.298] [LOG]   Connecting socket for: MMM-MoonPhase
                                  0|MagicMir | [2025-05-03 17:06:28.304] [LOG]   Starting module helper: MMM-MoonPhase
                                  0|MagicMir | [2025-05-03 17:06:28.304] [LOG]   Connecting socket for: MMM-JsonValue
                                  0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   Connecting socket for: MMM-MyGarbage
                                  0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   2025-05-03T17:06:28 <log> Starting node_helper for module: MMM-MyGarbage (/home/pi/MagicMirror/modules/MMM-MyGarbage/node_helper.js:9 Class.start)
                                  0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   Connecting socket for: MMM-Strava
                                  0|MagicMir | [2025-05-03 17:06:28.306] [LOG]   2025-05-03T17:06:28 <log> Starting module helper: MMM-Strava (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:47 Class.start)
                                  0|MagicMir | [2025-05-03 17:06:28.306] [LOG]   Connecting socket for: MMM-Todoist
                                  0|MagicMir | [2025-05-03 17:06:28.307] [LOG]   2025-05-03T17:06:28 <log> Starting node helper for: MMM-Todoist (/home/pi/MagicMirror/modules/MMM-Todoist/node_helper.js:19 Class.start)
                                  0|MagicMir | [2025-05-03 17:06:28.307] [LOG]   Connecting socket for: MMM-FRITZ-Box-Callmonitor-py3
                                  0|MagicMir | [2025-05-03 17:06:28.312] [LOG]   2025-05-03T17:06:28 <log> Starting module: MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:28 Class.start)
                                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: MMM-SystemMonitor
                                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Starting module helper: MMM-SystemMonitor
                                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: MMM-SystemInfo
                                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Starting node helper: MMM-SystemInfo
                                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: birthdaylist
                                  0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify
                                  0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Connecting socket for: newsfeed
                                  0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Starting node helper for: newsfeed
                                  0|MagicMir | [2025-05-03 17:06:28.318] [LOG]   Connecting socket for: MMM-Remote-Control
                                  0|MagicMir | [2025-05-03 17:06:28.319] [LOG]   Starting node helper for: MMM-Remote-Control
                                  0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Connecting socket for: calendar
                                  0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Starting node helper for: calendar
                                  0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Sockets connected & modules started ...
                                  0|MagicMir | [2025-05-03 17:06:28.540] [LOG]   Launching application.
                                  0|MagicMir | [2025-05-03 17:06:28.915] [INFO]  System information:
                                  0|MagicMir | ### SYSTEM:   manufacturer: ; model: ; virtual: false
                                  0|MagicMir | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-2712
                                  0|MagicMir | ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                                  0|MagicMir | ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                                  0|MagicMir | [2025-05-03 17:06:29.613] [LOG]   [MMM-Remote-Control] Could not get defaults for MMM-RAIN-MAP. See #335.
                                  0|MagicMir | [2025-05-03 17:06:31.249] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/xxxxxxxxxxxx%40group.calendar.google.com/private-5yyyyyyyyyyyyyyyyyyyyyy/basic.ics - Interval: 300000
                                  0|MagicMir | [2025-05-03 17:06:31.278] [LOG]   2025-05-03T17:06:31 <info> MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
                                  0|MagicMir | [2025-05-03 17:06:31.279] [LOG]   2025-05-03T17:06:31 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                  0|MagicMir | [2025-05-03 17:06:31.303] [LOG]   2025-05-03T17:06:31 <log> Received config for MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:56 Class.socketNotificationReceived)
                                  0|MagicMir | [2025-05-03 17:06:31.304] [LOG]   2025-05-03T17:06:31 <log> MMM-FRITZ-Box-Callmonitor-py3 is waiting for incoming calls. (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:118 Class.setupMonitor)
                                  0|MagicMir | [2025-05-03 17:06:31.376] [LOG]   Create new newsfetcher for url: https://www.gutekueche.de/feed/wochenrezepte - Interval: 300000
                                  0|MagicMir | [2025-05-03 17:06:31.382] [LOG]   Create new newsfetcher for url: https://www.gutekueche.de/feed/tagesrezept - Interval: 300000
                                  0|MagicMir | [2025-05-03 17:06:31.385] [LOG]   Create new newsfetcher for url: https://www.chefkoch.de/recipe-of-the-day/rss - Interval: 300000
                                  0|MagicMir | [2025-05-03 17:06:31.389] [LOG]   Create new calendarfetcher for url: https://www.feiertage-deutschland.de/kalender-download/ics/feiertage-deutschland.ics - Interval: 604800000
                                  0|MagicMir | [2025-05-03 17:06:31.394] [LOG]   2025-05-03T17:06:31 <log> Starting module helper:  birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:27 Class.socketNotificationReceived)
                                  0|MagicMir | [2025-05-03 17:06:32.046] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                  0|MagicMir | [2025-05-03 17:06:32.050] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                  0|MagicMir | [2025-05-03 17:06:32.194] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                  0|MagicMir | [2025-05-03 17:06:32.353] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                                  0|MagicMir | [2025-05-03 17:06:32.398] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                                  0|MagicMir | [2025-05-03 17:06:32.495] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                                  0|MagicMir | [2025-05-03 17:06:32.734] [INFO]  Calendar-Fetcher: Broadcasting 51 events from https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-yyyyyyyyyyyyyyyyyyyyyyyyyyyy/basic.ics.
                                  0|MagicMir | [2025-05-03 17:06:32.827] [LOG]   2025-05-03T17:06:32 <log> Refreshed access token because it has expired. Expired at: 17:06:31 now is: 17:06:32 (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/core/SpotifyConnector.js:24 )
                                  0|MagicMir | [2025-05-03 17:06:33.418] [LOG]   2025-05-03T17:06:33 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                  0|MagicMir | [2025-05-03 17:06:34.302] [INFO]  Calendar-Fetcher: Broadcasting 22 events from https://www.feiertage-deutschland.de/kalender-download/ics/feiertage-deutschland.ics.
                                    sdetweil @rkorell
                                    @rkorell git pull in the module folder restart MM
                                    in the npm start output, should see (I sent 3 requests)
                                    [2025-05-03 18:30:03.519] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'HIDE_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
                                    [2025-05-03 18:30:36.302] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'SHOW_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
                                    [2025-05-03 18:31:00.765] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'HIDE_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
                                    and in the dev console
                                    MMM-CurlToNotification.js:14 MMM-CurlToNotification received request to send notication  HIDE_ALERT  with payload  {message: 'fribble'}
                                    MMM-CurlToNotification.js:14 MMM-CurlToNotification received request to send notication  SHOW_ALERT  with payload  {message: 'fribble'}
                                      @sdetweil I`m away from home today, will check tomorrow…
                                      Thanks.
                                      Ralf
                                        As your posting above implies your debug message confirms a received message - but the message cannot be received, because the curl command doesn’t work …
                                        As per your advise I’ve git pulled, restarted mirror - but get same error message as before.
                                        The curl command is bad or the URL doesn’t work.
                                        I don’t know why and have no idea how to figure this out…
                                        Screen input- and output as follws:
                                        pi@MagicMirrorPi5:~ $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                                        <!DOCTYPE html>
                                        <html lang="en">
                                        <head>
                                        </head>
                                        <body>
                                        </body>
                                        </html>
                                        pi@MagicMirrorPi5:~ $ cd MagicMirror/modules
                                        pi@MagicMirrorPi5:~/MagicMirror/modules $ cd MMM-CurlToNotification/
                                        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ git pull
                                        Updating 71ea1c1..bd1e417
                                        Fast-forward
                                         MMM-CurlToNotification.js | 14 ++++++++++----
                                         README.md                 |  1 +
                                         node_helper.js            | 13 +++++++++++--
                                         3 files changed, 22 insertions(+), 6 deletions(-)
                                        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ pm2 restart MagicMirror
                                        [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                                        [PM2] [MagicMirror](0) ✓
                                        │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                                        │ 0  │ MagicMirror    │ default     │ 2.31.0… │ fork    │ 87731    │ 0s     │ 1    │ online    │ 0%       │ 2.6mb    │ pi       │ enabled  │
                                        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                                        <!DOCTYPE html>
                                        <html lang="en">
                                        <head>
                                        </head>
                                        <body>
                                        </body>
                                        </html>
                                        Any additional idea?
                                        regards,
                                        Ralf
                                          sdetweil @rkorell
                                          @rkorell do curl -v
                                            curl --v --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                                            curl: option --v: is ambiguous
                                            curl: try 'curl --help' or 'curl --manual' for more information
                                            • 3 / 4
