    Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream
    68 Posts 5 Posters 23.9k Views 4 Watching
    • Cr4z33C Offline
      Cr4z33 @wishmaster270
      @wishmaster270 thanks for spending some time on my issue although you’re busy.
      As sdetweil said he’s already helping me into this. 🙂
      @sdetweil my bad, my bad and again my bad! 😓
      I was going to tryout your method when I realized I actually never checked deeply what was outputting npm start… There’s A LOT of doorbell data being captured by MMM-MQTTbridge indeed! 🤦🏼
      You can see here the output.
      Can you see at this point (maybe) some additional data that needs to be added to mqttDictionary.js or do you still believe I should go your way (HA, automation, etc.)?
      While waiting for your kind reply I will play at trying your method. 😁
      R S 2 Replies Last reply Reply Quote 0
      • R Online
        rkorell Module Developer @Cr4z33
        @Cr4z33 Good afternoon,
        I do not have the time to dig too deep into MMM-MQTTbridge …
        But what I see checking your console logfile and compare this to your first posting:
        You obviously had managed that the MQQT message arrives and is acknowledged.
        The message you receive is:
            "Action": "Pulse",
            "Code": "Invite",
            "Data": {
                "CallID": "5",
                "IsEncryptedStream": false,
                "LocaleTime": "2025-04-30 10:40:43",
                "LockNum": 2,
                "RealUTC": 1746002443,
                "SupportPaas": false,
                "TCPPort": 37777,
                "UTC": 1746006043.0,
                "UserID": "101"
            "Index": 0,
            "deviceType": "DHI-VTO3311Q-WP",
            "serialNumber": "****"
        This is what you trying to capture in your mqttDisctionary.js
        I’m not 100% sure if you
        1. catch the right data-value : - is your jsonpath correct?
        2. is “notiID” the right place for the module name you try to reach?
        Just spontaneous thoughts about your issue - maybe misleading …
        Regards,
        Ralf
        Cr4z33C 1 Reply Last reply Reply Quote 1
        • Cr4z33C Offline
          Cr4z33 @rkorell
          @rkorell hi it’s a good question indeed.
          However too bad that I am not skilled enough to know the answer lol that’s why I am posting here asking for help! 😂
          Let’s see if @sdetweil or someone else can find out.
            sdetweil @Cr4z33
            @Cr4z33 woohoo, i see the data, now its MQTTBridge configuration, and that part i dont know (yet)
            • R Online
              @Cr4z33 OK, I guess you have to dig a little bit deeper into MMM-MQTTbridge …
              You may give MQTTbind a try - this seems to be easier and more straightforward…
              In addition: I’m not really sure if your RTSP-play module is able to react on notification - had you double-checked this? (If it does not react on notification, you cannot be successful…).
              Regards,
              Ralf
              • R Online
                rkorell Module Developer @rkorell
                @rkorell @Cr4z33 with writing the above I’ve just noticed:
                Your RTSP module is NOT “RTSP-play” but "MMM-RTSPStream" !
                This should be your first trial then in your mqttDisctionary.js …
                  sdetweil @rkorell
                  @rkorell MMM-MPlayer should work for displaying on notification
                  • R Online
                    @sdetweil cool.
                    had played around with this and it was frickling to position - but worth a try … :-)
                    • R Online
                      @rkorell said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
                      @Cr4z33 just found “source” : you have copied this configuration .
                      But I bet you have to place the module name as “notiID” …
                      this is not “RTSP-play” but “MMM-RTSPStream” …
                      Regards,
                      Ralf
                      (Pay attention : it is highly probably case-sensitive …)
                      • R Online
                        @Cr4z33
                        MMM-RTSPStream is quite old and the author himself doesn’t use it anymore and recommend indeed other modules.
                        So it a a wise advice from Sam (@sdetweil ) to use MMM-Mplayer …
                        This one still have an active discussion here .
                        Ralf
                        • R Online
                          @rkorell said
                          use MMM-Mplayer …
                          Just checked: You CAN use MMM-Pages notification to start and stop your stream …
                          (e.g. “NEW_PAGE=0” will start the stream.
                          Unfortunately you will have to care about switching OFF the stream by yourself - I guess the doorbell will not be sufficient to send a “STOP” signal - You likely would to see the stream longer that the visitor is pressing the doorbellbutton …
                          Ralf
                          • Cr4z33C Offline
                            Cr4z33
                            Thank you again @rkorell and @sdetweil for your precious help, but I am at a point where I don’t have enough skill to generate the needed code lines.
                            What comes afterwards (ie. stop the stream, etc.) is not what worries me hehe, but all I am able to do at today is how to install a module and give it a basic config.
                            Having two modules to “talk” to each other is another matter and that’s where I start asking for help to people who know what they are doing (I am more a copy&paste or a tutorial follower guy). 😁
                            Once again this is the RTSP URL:
                            rtsp://username:password@ipaddress/cam/realmonitor?channel=1&subtype=1#backchannel=0
                            and this is the MQTT button press line:
                            2025-04-16 11:40:58,897 INFO __main__ Publishing MQTT message DahuaVTO/Invite/Event: {'Action': 'Pulse', 'Code': 'Invite', 'Data': {'CallID': '3', 'IsEncryptedStream': False, 'LocaleTime': '2025-04-16 11:40:58', 'LockNum': 2, 'RealUTC': 1744796458, 'SupportPaas': False, 'TCPPort': 37777, 'UTC': 1744800058.0, 'UserID': '101'}, 'Index': 0, 'deviceType': 'DHI-VTO3311Q-WP', 'serialNumber': '*******'}
                            I tried creating a Home Assistant automation, but it’s probably wrong.
                              sdetweil @Cr4z33
                              @Cr4z33 you are composing a service that does not yet exist
                              button on doorbell causes window w video stream to
                              open
                              appears no one has done that w this video doorbell, welcome to the bleeding edge. u get to MAKE the sausage no one else wants to see!!
                              a MagicMirror module runs inside a web browser, all in javascript. it can consume info from the outside using url based apis http get or put/post
                              Now, sometimes, you want module A to work with data from module B. for example calendar. it reads the raw data file (ical/ics), parses all the events, gets the list of pertinent events ( dont care about 2 years ago, only next week…)
                              and displays them. hm id like a different display, but dont want to learn about all the file reading and parsing and selecting)
                              MagicMirror provides a way for one module to share its data with others, called Notifications. some identifying string, with some attached data. the mechanism is a broadcast. one send, every other module gets the same message.
                              if a modules doesn’t understand the identifying string, it ignores the message
                              if it DOES understand the identifying string, then it MUST understand the format of the attached data.
                              so, modules that DO participate in this data sharing must document ( in their readme.md file)
                              what notification strings they send (and its associated data format, if any)
                              AND
                              what notifications strings they accept (and its required data format)
                              nothing going outside the browser is known inside the browser,
                              to get that kind of info requires some module to be able to bridge the two environments
                              i have a simple one
                              id like some way for a script running outside MagicMirror to trigger a module to do something (receive a notification it knows about)
                              so i wrote MMM-CurlToNotification
                              from the command line outside MagicMirror you can issue the curl command to send a packet of data that turns into a notification sent to all modules
                              there are other modules that provide similar support (as well as others), mmm-remotecontrol for example
                              anyhow MMM-MqttBridge does that bridging for MQTT messages. in both directions
                              mqtt -> notifi(cation) and notification) -> mqtt
                              but you need to know a bunch of stuff, and figure out how to code the file that does the actual work
                              i work backwards
                              i need a video played from a url on demand
                              what modules can do that
                              and how do i setup for the on demand part
                              pick a module RTSPStream or Minfo, read its doc to understand what notifications it understands, and what data it needs
                              install and configure the selected module
                              now you ‘could’ use my curltonotification module to verify that the video player module works
                              then you back up to the MQTT bridge module config to send the same message you just tested with, and what mqtt message will trigger it
                              then back up, and find/setup what will send that mqtt message
                              and how it is triggered to to that
                              you can draw this all out on a piece of paper
                              coding is just making the computer fo the exact same thing over and over, just faster. if you dont know what, then it cant either
                              someone presses the doorbell button
                              how does something outside the doorbell know?
                              can that something send a msg via mqtt that the bridge is listening for? if not, can i find something that that can take the first things out and get it into our expected mqtt message
                              repeat along the way,
                              test each step
                              • R Online
                                @sdetweil said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
                                Dear Sam,
                                trying to help I’m struggled with your module CurlToNotification :-(
                                  module:"MMM-CurlToNotification",
                                  config:{
                                    url_name:"doorbell", // the path of the url for curl post
                                And consecutively running
                                curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                                Shows an error message:
                                pi@MagicMirrorPi5:~/MagicMirror/modules $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                                <!DOCTYPE html>
                                <html lang="en">
                                <head>
                                <meta charset="utf-8">
                                <title>Error</title>
                                </head>
                                <body>
                                <pre>InternalServerError: stream is not readable<br> &nbsp; &nbsp;at readStream (/home/pi/MagicMirror/node_modules/raw-body/index.js:185:17)<br> &nbsp; &nbsp;at getRawBody (/home/pi/MagicMirror/node_modules/raw-body/index.js:116:12)<br> &nbsp; &nbsp;at read (/home/pi/MagicMirror/node_modules/body-parser/lib/read.js:79:3)<br> &nbsp; &nbsp;at jsonParser (/home/pi/MagicMirror/node_modules/body-parser/lib/types/json.js:138:5)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:95:5)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:91:12)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/body-parser/lib/read.js:132:5<br> &nbsp; &nbsp;at AsyncResource.runInAsyncScope (node:async_hooks:206:9)<br> &nbsp; &nbsp;at invokeCallback (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:238:16)<br> &nbsp; &nbsp;at done (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:227:7)<br> &nbsp; &nbsp;at IncomingMessage.onEnd (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:287:7)<br> &nbsp; &nbsp;at IncomingMessage.emit (node:events:518:28)<br> &nbsp; &nbsp;at endReadableNT (node:internal/streams/readable:1698:12)<br> &nbsp; &nbsp;at process.processTicksAndRejections (node:internal/process/task_queues:82:21)</pre>
                                </body>
                                </html>
                                From Windows Client (changing localhost to MagicMirrors IP address a different error message:
                                PS C:\Users\Familienbenutzer> curl --header "Content-Type: application/json"   --request POST   --data "{\"notification\":\"SHOW_ALERT\",\"payload\":{\"message\":\"fribble\"}}" http://1xx.yy.zz.157:8080/doorbell
                                Invoke-WebRequest : Es wurde kein Positionsparameter gefunden, der das Argument "Content-Type: application/json"
                                akzeptiert.
                                In Zeile:1 Zeichen:1
                                + curl --header "Content-Type: application/json"   --request POST   --d ...
                                    + CategoryInfo          : InvalidArgument: (:) [Invoke-WebRequest], ParameterBindingException
                                    + FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
                                Any hint for me?
                                Thanks and regards,
                                Ralf
                                  sdetweil @rkorell
                                  @rkorell and you did restart MagicMirror after installing the module, right?
                                  you can also add config parm (make sure there is a trailing comma after doorbell
                                     debug:true,
                                  • R Online
                                    yes, indeed :-)
                                    And a trailing comma is there…
                                    In the meantime I had even a PI-reboot (for other reasons) - error persists.
                                    Even with debug-option enabled no debug message from your module.
                                    Neither in pm2 logs nor in developer’s console…
                                    Ralf
                                    S R 3 Replies Last reply Reply Quote 0
                                      sdetweil @rkorell
                                      @rkorell weird
                                      i am away from my computer for most of the day helping family
                                      i will review asap
                                      • R Online
                                        @sdetweil Take your time!
                                        Family is most important.
                                        This issue is REALLY not important, neither urgent.
                                        I do not need this module right now - was just for testing, if I can help @Cr4z33 further with some examples to copy - as asked.
                                        So don’t hurry.
                                        Ralf
                                        • R Online
                                          all messages in dev-console …
                                          • R Online
                                            startup log
                                            0|MagicMir | > magicmirror@2.31.0-develop start
                                            0|MagicMir | > npm run start:x11
                                            0|MagicMir |
                                            0|MagicMir |
                                            0|MagicMir | > magicmirror@2.31.0-develop start:x11
                                            0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                            0|MagicMir |
                                            0|MagicMir | [2025-05-03 17:06:27.179] [LOG]   Starting MagicMirror: v2.31.0-develop
                                            0|MagicMir | [2025-05-03 17:06:27.189] [LOG]   Loading config ...
                                            0|MagicMir | [2025-05-03 17:06:27.190] [LOG]   config template file not exists, no envsubst
                                            0|MagicMir | [2025-05-03 17:06:27.369] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
                                            0|MagicMir | [2025-05-03 17:06:27.436] [INFO]  Your configuration file doesn't contain syntax errors :)
                                            0|MagicMir | [2025-05-03 17:06:27.437] [INFO]  Checking modules structure configuration ...
                                            0|MagicMir | [2025-05-03 17:06:27.473] [INFO]  Your modules structure configuration doesn't contain errors :)
                                            0|MagicMir | [2025-05-03 17:06:27.474] [LOG]   Loading module helpers ...
                                            0|MagicMir | [2025-05-03 17:06:27.474] [LOG]   No helper found for module: alert.
                                            0|MagicMir | [2025-05-03 17:06:27.475] [LOG]   No helper found for module: MMM-MagicMover.
                                            0|MagicMir | [2025-05-03 17:06:27.476] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   Module helper loaded: MMM-CurlToNotification
                                            0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   No helper found for module: clock.
                                            0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   No helper found for module: MMM-Profilepicture.
                                            0|MagicMir | [2025-05-03 17:06:27.484] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.484] [LOG]   Module helper loaded: MMM-Logging
                                            0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   Module helper loaded: MMM-MoonPhase
                                            0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   No helper found for module: MMM-Globe.
                                            0|MagicMir | [2025-05-03 17:06:27.492] [LOG]   No helper found for module: weather.
                                            0|MagicMir | [2025-05-03 17:06:27.523] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.524] [LOG]   Module helper loaded: MMM-JsonValue
                                            0|MagicMir | [2025-05-03 17:06:27.531] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.531] [LOG]   Module helper loaded: MMM-MyGarbage
                                            0|MagicMir | [2025-05-03 17:06:27.532] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
                                            0|MagicMir | [2025-05-03 17:06:27.532] [LOG]   No helper found for module: MMM-RAIN-MAP.
                                            0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Check MagicMirror² version for node helper 'MMM-Strava' - Minimum version: 2.2.0 - Current version: 2.31.0-develop
                                            0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Version is ok!
                                            0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Module helper loaded: MMM-Strava
                                            0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   Module helper loaded: MMM-Todoist
                                            0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   No helper found for module: MMM-UselessFacts.
                                            0|MagicMir | [2025-05-03 17:06:27.748] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.748] [LOG]   Module helper loaded: MMM-FRITZ-Box-Callmonitor-py3
                                            0|MagicMir | [2025-05-03 17:06:27.749] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.749] [LOG]   Module helper loaded: MMM-SystemMonitor
                                            0|MagicMir | [2025-05-03 17:06:27.750] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.750] [LOG]   Module helper loaded: MMM-SystemInfo
                                            0|MagicMir | [2025-05-03 17:06:27.782] [LOG]   2025-05-03T17:06:27 <log> init module helper birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:15 Class.init)
                                            0|MagicMir | [2025-05-03 17:06:27.782] [LOG]   Module helper loaded: birthdaylist
                                            0|MagicMir | [2025-05-03 17:06:27.898] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.899] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
                                            0|MagicMir | [2025-05-03 17:06:27.925] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.925] [LOG]   Module helper loaded: newsfeed
                                            0|MagicMir | [2025-05-03 17:06:27.945] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.945] [LOG]   Module helper loaded: MMM-Remote-Control
                                            0|MagicMir | [2025-05-03 17:06:27.982] [LOG]   Initializing new module helper ...
                                            0|MagicMir | [2025-05-03 17:06:27.983] [LOG]   Module helper loaded: calendar
                                            0|MagicMir | [2025-05-03 17:06:27.983] [LOG]   All module helpers loaded.
                                            0|MagicMir | [2025-05-03 17:06:27.986] [LOG]   Starting server on port 8080 ...
                                            0|MagicMir | [2025-05-03 17:06:28.296] [LOG]   Server started ...
                                            0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Connecting socket for: MMM-CurlToNotification
                                            0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Starting module helper: MMM-CurlToNotification
                                            0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Connecting socket for: MMM-Logging
                                            0|MagicMir | [2025-05-03 17:06:28.298] [LOG]   2025-05-03T17:06:28 <log> Module helper started for MMM-Logging (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:19 Class.start)
                                            0|MagicMir | [2025-05-03 17:06:28.298] [LOG]   Connecting socket for: MMM-MoonPhase
                                            0|MagicMir | [2025-05-03 17:06:28.304] [LOG]   Starting module helper: MMM-MoonPhase
                                            0|MagicMir | [2025-05-03 17:06:28.304] [LOG]   Connecting socket for: MMM-JsonValue
                                            0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   Connecting socket for: MMM-MyGarbage
                                            0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   2025-05-03T17:06:28 <log> Starting node_helper for module: MMM-MyGarbage (/home/pi/MagicMirror/modules/MMM-MyGarbage/node_helper.js:9 Class.start)
                                            0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   Connecting socket for: MMM-Strava
                                            0|MagicMir | [2025-05-03 17:06:28.306] [LOG]   2025-05-03T17:06:28 <log> Starting module helper: MMM-Strava (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:47 Class.start)
                                            0|MagicMir | [2025-05-03 17:06:28.306] [LOG]   Connecting socket for: MMM-Todoist
                                            0|MagicMir | [2025-05-03 17:06:28.307] [LOG]   2025-05-03T17:06:28 <log> Starting node helper for: MMM-Todoist (/home/pi/MagicMirror/modules/MMM-Todoist/node_helper.js:19 Class.start)
                                            0|MagicMir | [2025-05-03 17:06:28.307] [LOG]   Connecting socket for: MMM-FRITZ-Box-Callmonitor-py3
                                            0|MagicMir | [2025-05-03 17:06:28.312] [LOG]   2025-05-03T17:06:28 <log> Starting module: MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:28 Class.start)
                                            0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: MMM-SystemMonitor
                                            0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Starting module helper: MMM-SystemMonitor
                                            0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: MMM-SystemInfo
                                            0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Starting node helper: MMM-SystemInfo
                                            0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: birthdaylist
                                            0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify
                                            0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Connecting socket for: newsfeed
                                            0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Starting node helper for: newsfeed
                                            0|MagicMir | [2025-05-03 17:06:28.318] [LOG]   Connecting socket for: MMM-Remote-Control
                                            0|MagicMir | [2025-05-03 17:06:28.319] [LOG]   Starting node helper for: MMM-Remote-Control
                                            0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Connecting socket for: calendar
                                            0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Starting node helper for: calendar
                                            0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Sockets connected & modules started ...
                                            0|MagicMir | [2025-05-03 17:06:28.540] [LOG]   Launching application.
                                            0|MagicMir | [2025-05-03 17:06:28.915] [INFO]  System information:
                                            0|MagicMir | ### SYSTEM:   manufacturer: ; model: ; virtual: false
                                            0|MagicMir | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-2712
                                            0|MagicMir | ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                                            0|MagicMir | ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                                            0|MagicMir | [2025-05-03 17:06:29.613] [LOG]   [MMM-Remote-Control] Could not get defaults for MMM-RAIN-MAP. See #335.
                                            0|MagicMir | [2025-05-03 17:06:31.249] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/xxxxxxxxxxxx%40group.calendar.google.com/private-5yyyyyyyyyyyyyyyyyyyyyy/basic.ics - Interval: 300000
                                            0|MagicMir | [2025-05-03 17:06:31.278] [LOG]   2025-05-03T17:06:31 <info> MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
                                            0|MagicMir | [2025-05-03 17:06:31.279] [LOG]   2025-05-03T17:06:31 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                            0|MagicMir | [2025-05-03 17:06:31.303] [LOG]   2025-05-03T17:06:31 <log> Received config for MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:56 Class.socketNotificationReceived)
                                            0|MagicMir | [2025-05-03 17:06:31.304] [LOG]   2025-05-03T17:06:31 <log> MMM-FRITZ-Box-Callmonitor-py3 is waiting for incoming calls. (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:118 Class.setupMonitor)
                                            0|MagicMir | [2025-05-03 17:06:31.376] [LOG]   Create new newsfetcher for url: https://www.gutekueche.de/feed/wochenrezepte - Interval: 300000
                                            0|MagicMir | [2025-05-03 17:06:31.382] [LOG]   Create new newsfetcher for url: https://www.gutekueche.de/feed/tagesrezept - Interval: 300000
                                            0|MagicMir | [2025-05-03 17:06:31.385] [LOG]   Create new newsfetcher for url: https://www.chefkoch.de/recipe-of-the-day/rss - Interval: 300000
                                            0|MagicMir | [2025-05-03 17:06:31.389] [LOG]   Create new calendarfetcher for url: https://www.feiertage-deutschland.de/kalender-download/ics/feiertage-deutschland.ics - Interval: 604800000
                                            0|MagicMir | [2025-05-03 17:06:31.394] [LOG]   2025-05-03T17:06:31 <log> Starting module helper:  birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:27 Class.socketNotificationReceived)
                                            0|MagicMir | [2025-05-03 17:06:32.046] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                            0|MagicMir | [2025-05-03 17:06:32.050] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                            0|MagicMir | [2025-05-03 17:06:32.194] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                            0|MagicMir | [2025-05-03 17:06:32.353] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                                            0|MagicMir | [2025-05-03 17:06:32.398] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                                            0|MagicMir | [2025-05-03 17:06:32.495] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                                            0|MagicMir | [2025-05-03 17:06:32.734] [INFO]  Calendar-Fetcher: Broadcasting 51 events from https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-yyyyyyyyyyyyyyyyyyyyyyyyyyyy/basic.ics.
                                            0|MagicMir | [2025-05-03 17:06:32.827] [LOG]   2025-05-03T17:06:32 <log> Refreshed access token because it has expired. Expired at: 17:06:31 now is: 17:06:32 (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/core/SpotifyConnector.js:24 )
                                            0|MagicMir | [2025-05-03 17:06:33.418] [LOG]   2025-05-03T17:06:33 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                            0|MagicMir | [2025-05-03 17:06:34.302] [INFO]  Calendar-Fetcher: Broadcasting 22 events from https://www.feiertage-deutschland.de/kalender-download/ics/feiertage-deutschland.ics.
                                            • 2 / 4
