    Which version of Debian to use
    20 Posts 2 Posters 3.6k Views 2 Watching
      sdetweil @DarrenO 0
      @DarrenO-0 just install the default display env. MagicMirror is a browser app, and we require whatever the browser requires
      debian 12 (bookworm) is the current base for raspi os
      new one (trixie) coming soon
        DarrenO 0 @sdetweil
        @sdetweil Thanks, so during the OS installation, when I get to the point where I am prompted to select and install software, I should just keep the default selected options of Debian desktop environment and GNOME?
          sdetweil @DarrenO 0
          @DarrenO-0 are you using the prebuilt raspi os images? i dont see those prompts
          https://www.raspberrypi.com/software/
          ill have to try the bare debian vm again
            DarrenO 0 @sdetweil
            @sdetweil No, using the Debian .iso distro from the debian.org site.
            I’m installing on a NUC, not a RasPi.
              sdetweil @DarrenO 0
              @DarrenO-0 got it
                sdetweil @DarrenO 0
                @DarrenO-0 I installed the latest debian 12.x on my intel machine, in vmware.
                and hit enter when it said gnome
                started, added me to sudoers. installed curl, and then ran my install script
                and MM came up at end of install
                  DarrenO 0 @sdetweil
                  I re-installed Debian12 and left the default Desktop Environment selections of Debian and GNOME selected.
                  Pretty much the vanilla/default install.
                  Did you have to do anything regarding how, when the Debian is eventually displayed, that MM is shown automatically?
                  I can’t seem to get MM to show and even though pm2 is enabled and running, I am stuck at the Desktop view where the Activities Overview button is shown in the top-left corner.
                  If I can’t get around this, the alternative is to run it as a headless installation and just access MM via browser from other computers.
                    DarrenO 0 @sdetweil
                    I also configured Debian to autologin as a given user account that I created during the installation process so I am not prompted to login after the computer reboots and it just goes straight to the Desktop.
                      sdetweil @DarrenO 0
                      @DarrenO-0 i ran my install script, said yes to pm2
                      MagicMirror came up at the end.
                      i did not set auto login, but i will change it and reboot
                      i dont expect problems
                        sdetweil @DarrenO 0
                        @DarrenO-0 my mm.sh was broken, fixed now… the UI is running under wayland, not X11
                        so we need a different command…
                        I have fixed it, deleted the pm2 app, deleted the MagicMirror folder and then rerun the install script
                        MM came up
                        I rebooted
                        MM came up, NOT in the full screen view but in the reduced desktop view touch it and it goes full screen like the main panel does…
                        have to look at that
                        if you used my installer, you can fix the one file by doing
                        cd ~/MagicMirror/installers
                        curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/refs/heads/master/mm.sh >mm.sh
                        sudo reboot
                        mine looks like this after reboot
