    Open Weather not displaying
    10 Posts 3 Posters 2.3k Views 3 Watching
    • G Offline
      Guku
      After upgrading MM to vers 2.32 font of all my modules changed and my MMM-openweatherMapForecast is not displaying. no errors just the header on the screen with the name for my weather location. Alo top bar that was used for update notifications displays “undefined” msg.
        sdetweil @Guku
        @Guku what version did you upgrade from?
        and how did u upgrade?
        • G Offline
          Guku @sdetweil
          went to MM folder and ran :
          git pull && npm run install-mm
            sdetweil @Guku
            @Guku can you look in the output of npm start
            there should be messages there
            if using pm2 to launch MagicMirror then
            pm2 logs --lines=xxx
            where xxx is the number of most recent lines, default 15
            you may need to use 100
            • G Offline
              Guku @sdetweil
              i run MM in a VM and use “npm run server” to start it.
              when i used pm2 log i got this
              lolo@raspberry:~/MagicMirror $ pm2 logs --lines=100
              /home/lolo/.pm2/pm2.log last 100 lines:
              PM2 | 2025-06-22T17:14:53: PM2 log: [PM2] This PM2 is not UP TO DATE
              PM2 | 2025-06-22T17:14:53: PM2 log: [PM2] Upgrade to version 6.0.8
              PM2 | 2025-06-23T17:14:53: PM2 log: [PM2] This PM2 is not UP TO DATE
              PM2 | 2025-06-23T17:14:53: PM2 log: [PM2] Upgrade to version 6.0.8
              PM2 | 2025-06-24T17:14:53: PM2 log: [PM2] This PM2 is not UP TO DATE
              PM2 | 2025-06-24T17:14:53: PM2 log: [PM2] Upgrade to version 6.0.8
              PM2 | 2025-06-25T17:14:53: PM2 log: [PM2] This PM2 is not UP TO DATE
              PM2 | 2025-06-25T17:14:53: PM2 log: [PM2] Upgrade to version 6.0.8
              PM2 | 2025-06-26T17:14:53: PM2 log: [PM2] This PM2 is not UP TO DATE
              PM2 | 2025-06-26T17:14:53: PM2 log: [PM2] Upgrade to version 6.0.8
              PM2 | 2025-06-27T17:14:53: PM2 log: [PM2] This PM2 is not UP TO DATE
              PM2 | 2025-06-27T17:14:53: PM2 log: [PM2] Upgrade to version 6.0.8
              PM2 | 2025-06-28T17:14:53: PM2 log: [PM2] This PM2 is not UP TO DATE
              PM2 | 2025-06-28T17:14:53: PM2 log: [PM2] Upgrade to version 6.0.8
              PM2 | 2025-06-29T17:14:53: PM2 log: [PM2] This PM2 is not UP TO DATE
              PM2 | 2025-06-29T17:14:53: PM2 log: [PM2] Upgrade to version 6.0.8
              PM2 | 2025-06-30T17:14:53: PM2 log: [PM2] This PM2 is not UP TO DATE
              PM2 | 2025-06-30T17:14:53: PM2 log: [PM2] Upgrade to version 6.0.8
              PM2 | 2025-07-01T07:17:19: PM2 log: ===============================================================================
              PM2 | 2025-07-01T07:17:19: PM2 log: — New PM2 Daemon started ----------------------------------------------------
              PM2 | 2025-07-01T07:17:19: PM2 log: Time : Tue Jul 01 2025 07:17:19 GMT-0400 (Eastern Daylight Time)
              PM2 | 2025-07-01T07:17:19: PM2 log: PM2 version : 5.3.0
              PM2 | 2025-07-01T07:17:19: PM2 log: Node.js version : 20.18.1
              PM2 | 2025-07-01T07:17:19: PM2 log: Current arch : x64
              PM2 | 2025-07-01T07:17:19: PM2 log: PM2 home : /home/lolo/.pm2
              PM2 | 2025-07-01T07:17:19: PM2 log: PM2 PID file : /home/lolo/.pm2/pm2.pid
              PM2 | 2025-07-01T07:17:19: PM2 log: RPC socket file : /home/lolo/.pm2/rpc.sock
              PM2 | 2025-07-01T07:17:19: PM2 log: BUS socket file : /home/lolo/.pm2/pub.sock
              PM2 | 2025-07-01T07:17:19: PM2 log: Application log path : /home/lolo/.pm2/logs
              PM2 | 2025-07-01T07:17:19: PM2 log: Worker Interval : 30000
              PM2 | 2025-07-01T07:17:19: PM2 log: Process dump file : /home/lolo/.pm2/dump.pm2
              PM2 | 2025-07-01T07:17:19: PM2 log: Concurrent actions : 2
              PM2 | 2025-07-01T07:17:19: PM2 log: SIGTERM timeout : 1600
              PM2 | 2025-07-01T07:17:19: PM2 log: [Watch] Start watching MagicMirror
              PM2 | 2025-07-01T07:17:19: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2 | 2025-07-01T07:17:19: PM2 log: App [MagicMirror:0] online
              PM2 | 2025-07-01T07:17:19: PM2 log: App [MagicMirror:0] exited with code [127] via signal [SIGINT]
              PM2 | 2025-07-01T07:17:19: PM2 error: Cancelling versioning data parsing
              PM2 | 2025-07-01T07:17:19: PM2 error: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
              PM2 | 2025-07-01T07:17:19: PM2 error: Error caught while calling pidusage
              PM2 | 2025-07-01T07:17:19: PM2 error: Error: No matching pid found
              PM2 | 2025-07-01T07:17:19: PM2 log: Script /home/lolo/MagicMirror/installers/mm.sh had too many unstable restarts (16). Stopped. “errored”
              PM2 | 2025-07-02T07:17:20: PM2 log: [PM2] This PM2 is not UP TO DATE
              PM2 | 2025-07-02T07:17:20: PM2 log: [PM2] Upgrade to version 6.0.8
              /home/lolo/.pm2/logs/MagicMirror-out.log last 100 lines:
              0|MagicMir |
              0|MagicMir | > magicmirror@2.28.0 start
              0|MagicMir | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir |
              0|MagicMir | > magicmirror@2.29.0 start
              0|MagicMir |
              /home/lolo/.pm2/logs/MagicMirror-error.log last 100 lines:
              0|MagicMir | bash: /home/lolo/MagicMirror/installers/mm.sh: No such file or directory
              • K Offline
                khrusher
                I am similar…undefined in weather, notifications, news
                [PM2] Applying action restartProcessId on app [all](ids: [ 0 ])
                [PM2] MagicMirror ✓
                │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                │ 0 │ MagicMirror │ default │ 2.32.0 │ fork │ 3212 │ 0s │ 3 │ online │ 0% │ 2.7mb │ chris │ enabled │
                chris@raspberrypi:~/MagicMirror $ npm run install-mm
                magicmirror@2.32.0 install-mm
                npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                npm error code EBADENGINE
                npm error engine Unsupported engine
                npm error engine Not compatible with your version of node/npm: @jest/console@30.0.2
                npm error notsup Not compatible with your version of node/npm: @jest/console@30.0.2
                npm error notsup Required: {“node”:“^18.14.0 || ^20.0.0 || ^22.0.0 || >=24.0.0”}
                npm error notsup Actual: {“npm”:“10.9.2”,“node”:“v23.11.0”}
                npm error A complete log of this run can be found in: /home/chris/.npm/_logs/2025-07-02T14_09_26_052Z-debug-0.log
                • K Offline
                  khrusher @khrusher
                  I had a backup and restored. everything works again…back to two commits behind
                    sdetweil @khrusher
                    @khrusher use my upgrade script, you need nodejs upgraded too
                    see https://github.com/sdetweil/MagicMirror_scripts
                    K 1 Reply Last reply Reply Quote 1
                    • K Offline
                      khrusher @sdetweil
                      @sdetweil thanks…I was getting used to “git pull” in the modules.
                      All is good
                        sdetweil @khrusher
                        @khrusher yes, but sometimes modules need refresh when MagicMirror is updated
                        my script does all that too
