    Upgrade error on upgrade to 2.32.0
    3 Posts 2 Posters 1.2k Views 2 Watching
    • F Offline
      FritsdeGroot
      I tried to upgrade my Magic Mirror to the July 1st release but I got stuck at:
      ~/MagicMirror $ npm install
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: @jest/console@30.0.2
      npm error notsup Not compatible with your version of node/npm: @jest/console@30.0.2
      npm error notsup Required: {"node":"^18.14.0 || ^20.0.0 || ^22.0.0 || >=24.0.0"}
      npm error notsup Actual:   {"npm":"10.9.2","node":"v23.11.0"}
      npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-07-02T15_39_15_469Z-debug-0.log
      Later I tried:
      npm run install-mm
      > magicmirror@2.32.0 install-mm
      > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
      npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-07-02T15_46_56_484Z-debug-0.log
      Same result,
      It looks like I am running the wrong version of node. Do I understand it correcly that v23 is no longer supported? And if so what action could I take to repair this?
      I am running MM on a Raspberry Pi 3 on “Raspbian GNU/Linux 12 (bookworm)”
      Any support would be much appreciated.
      Kind regards
      Frits
        sdetweil @FritsdeGroot
        @FritsdeGroot 23 is broken
        so you have to install 22.14 or 24
        24 is not available in 32 bit mode
        do (if you had used my script before)
        sudo npm install n -g
        n 22.14
        then
        npm run install-mm
        • F Offline
          FritsdeGroot @sdetweil
          It works :-)
          Thnx Sam!
