    Installer scripts on Raspberry Pi Zero 2 W
    14 Posts 2 Posters 1.8k Views 2 Watching
    • K Offline
      kribbitykrab
      Apologies if this is a duplicate topic.
      I’ve been trying to get Magic Mirror installed on my Pi Zero 2 W. I have tried to run the master install script from here: https://github.com/sdetweil/MagicMirror_scripts
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
      However this gives me the following error:
      “nodejs version required for MagicMirror is no longer available for armv61 (pi0w) devices”
      I’ve also tried the below:
      git clone https://github.com/MichMich/MagicMirror
      cd MagicMirror/
      npm install --only=prod --omit=dev
      However I see a series of error codes here as well:
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: magicmirror@2.32.0
      npm error notsup Required: {“node”:“>=22.14.0”}
      npm error notsup Actual: {"NPM:“10.8.2”,“node”:“v20.18.1”}
      Currently on node v20.18.1 and npm 10.8.2.
      It seems the newer versions of MM require versions of nodejs which aren’t supported on the Zero 2 W hardware. Is there a version of the installer script that will let me point to an older version of MM?
      Any guidance would be appreciated!
        sdetweil @kribbitykrab
        @kribbitykrab Zero 2w is armv7, Zero w is armv6
        the required nodejs is not available for armv6
        send me the ~/install.log
        file
        same userid at gmail
        i believe you have the pi Zero w. not 2w
        MagicMirror manual install requires node 22.14 or higher
        you have node 20
          @kribbitykrab you can get an earlier release thru git by using the version tag
          do
          git fetch --tags
          git checkout v2.30.0
          npm run install-mm
          you cannot upgrade from there
          K 1 Reply Last reply Reply Quote 1
          • K Offline
            kribbitykrab @sdetweil
            @sdetweil Thank you so much for the reply! I believe you are correct, I think this is indeed a Pi Zero W, not the 2W–thanks for getting me on the right track.
            I’ll give the v2.30.0 MM a shot, appreciate it! Will try to send the install log to you over email as well.
              @kribbitykrab you can look at the log, search for armv6
              or do
              uname -a
              • K Offline
                @sdetweil Ok, so I got the v2.30.0 MM installed using your instructions above, thanks again.
                I also was able to get pm2 installed with a:
                sudo npm install -g pm2
                I was able to get pm2 to auto generate the ecosystem.config.js somehow. I also had to copy an index.js in from somewhere into the MagicMirror directory. I also made a copy of the sample_config.js and titled it config.js just for a dry run.
                But now when I try to do a:
                pm2 start
                I get a few warnings and errors:
                [PM2][WARN] Applications service-worker not running, starting…
                [PM2][ERROR] Error: Script not found: /home/./MagicMirror/service-worker
                I clearly need a service-worker script to start something, guessing something listed in the default config.js. When I do a pm2 list I see the v2.30.0 MM with PID 2444, which is neat I guess.
                How do I figure out what service-worker script I’m missing and how do I get it installed where I need to?
                I should mention at this point I was hoping to use this project to self-host and display a calendar on a display via MM. I’m starting to think I may need to upgrade to a beefier pi than the Zero W given the challenges so far, but want to see how far I can get first given that this is the hardware I already have on hand.
                  @kribbitykrab just run the fixuppm2 script from my scripts repo
                    @kribbitykrab pi 0w is a tough env now.
                    i think the next challenge is lack of the electron browser on armv6l processors
                    in my installer script when run on armv6l, i setup server mode and launch a browser over it.
                    you can run the setup_browser_over_server script to do that outside install
                    see the scripts repo readme for the browsers supported and how to inform the startup script which to use
                    • K Offline
                      @sdetweil I executed the following commands one after the other according to the readme:
                      export external_browser=midori
                      DISPLAY=:0 npm start
                      This gives me the following readout:
                      magicmirror@2.30.0 start
                      npm run start:x11
                      magic mirror@2.30.0 start:x11
                      sh: 1: ./node_modules/.bin/electron: not found
                      I had though that Midori supported electron, and I am (barely) able to get Midori to boot from the desktop environment. Advice?
                      Thanks!
                        @kribbitykrab if you ran the setup _over_server
                        it should have changed the start script in
                        package.json to
                        "start":"./run-start.sh",
                        can you confirm that
                        looks like i had a bug in the script, run it again
