    MM Screen goes blank 5-20min after starting (was stable on 2.31) - Pi Zero 2W running MagicMirrorOS
    15 Posts 3 Posters 3.1k Views 3 Watching
      scottwalsh @karsten13
      @karsten13 said in MM Screen goes blank 5-20min after starting (was stable on 2.31) - Pi Zero 2W running MagicMirrorOS:
      You did not write which OS you are using, 32-bit or 64-bit. The 32-bit is more resource-saving
      Hadn’t checked, until now. Have been using the 32-bit version.
      Will reimage with the 64-bit version and see if it is more stable.
      karsten13K S 2 Replies Last reply Reply Quote 0
      • karsten13K Offline
        karsten13 @scottwalsh
        @scottwalsh
        I think not … but you can try it.
          sdetweil @scottwalsh
          @scottwalsh the 64bit version takes about 500m more memory than the 32 bit version…
          you need to increase the swap space on the 2w, as it only has 512m ram.
          but you WILL page/swap a LOT, so the sd card speed is critical.
          before bootable USB support came along,
          I built and SD card image
          then copied that to a high speed USB stick, and modified the /etc/fstab to map the mounted space to the USB after boot from the SD card. (this required changing the UUID of the USB stick partition)
          this moved all the runtime I/O access to the USB stick…
            scottwalsh
            @sdetweil said in MM Screen goes blank 5-20min after starting (was stable on 2.31) - Pi Zero 2W running MagicMirrorOS:
            Away
            3 minutes ago
            Thanks for the tip, what’d you recommend as a min swap size? Will just try it off the SD card to start (as don’t have a USD at hand).
              @scottwalsh on the low ram machines I set it to 1024m
              in the installer script…
              free -m
              will give you defined and used for physical and swap
              from my 8 gig pi 4
               free -m
                             total        used        free      shared  buff/cache   available
              Mem:            7810        1418        2106          19        4426        6391
              Swap:           2047           8        2039
                karsten13 @sdetweil
                is already set to 1024
                  sdetweil @karsten13
                  @karsten13 he should examine use and adjust as required…
                    scottwalsh
                    3 minutes ago
                    As @karsten13 noted, defaults to 1024 on a 2W (have done first boot post imaging). Will give it a go at 2048, likely a bit oversized.
                      scottwalsh
                      Moving to 64bit looks like might have helped. Up for 18 hours since rebuilding so far with my full calendar configuration.
                      Observation - took about 30 min to boot through displaying the calendar. Load average getting up to 20.0+ during boot, assume swapping a lot via the slow SD card interface. So although looks more stable, much slower performance.
                        scottwalsh
                        Although moving to 64 bit made it more stable, still found it was going blank after a few days requiring the mm container restarted.
                        Think the Zero 2W was too under powered for what I was trying to do. So have upgraded to a Pi 4.
                        S S 2 Replies Last reply Reply Quote 0
                          @scottwalsh and did the problem go away?
                            scottwalsh @scottwalsh
                            Installed the pi 4 today.
                            Was getting up to 4 days on the 02W without it crashing, so will need to give it a week to know for sure.
