    mm watching disabled?
    4 Posts 2 Posters 930 Views 2 Watching
      Periz
      Hello everyone,
      I am experiencing an issue where my mm is no longer displayed. I am unable to identify the error at this time. I would appreciate another pair of eyes to take a look at it.
        sdetweil @Periz
        @Periz you cannot have the SAME port being used by multiple apps
        you have 3 instances running, probably ALL trying to use port:8080
        (as defined in config.js, a few lines above what you displayed)
        so,
        pm2 logs --lines=100
        then
        pm2 stop all
        then
        # clear logs
        pm2 flush
        pm2 start 0
        also you can check the config from the commandline
        npm run config:check
        • P Periz has marked this topic as solved
          Periz @sdetweil
          @sdetweil Thank you for the fast answer!!
            sdetweil @Periz
            @Periz another thing I didnt mention that could lead you from the pm2 status output
            The column Uptime tells you how long the app has been running
            0 is a bad sign
            The column to the right of Uptime
            Shows the count of restarts for the app
            large numbers are not good
