    Issue with Outlook recurring events
    26 Posts 2 Posters 7.2k Views 2 Watching
      sdetweil @WallysWellies
      @WallysWellies the event looks correct according to the start/end and rrule
      But
      We do not use the custom timezone configuration in the iCal data
      We use the worldwide standard IANA tz names
      (Why one needs custom timezones is beyond me)
      Because so many users use MS products , I wrote a lookup table 5 years ago for the calendar parser we use, node-iCal
      But
      GMT Standard Time
      Is not in that table (GMT has long been replaced by UTC)
      UTC Standard Time
      Is in the table
      If the tz lookup fails, we use the local system timezone
      S W 2 Replies Last reply Reply Quote 0
        The calendar automatically adjusts for STD/DST time changes
          I don’t know why the rrule until says oct 08:164500, but oct 7 is the last Tuesday in the event cycle
          Sept 30 was excluded
          So all the iCal entry looks good except for the timezone
          • W
            WallysWellies @sdetweil
            @sdetweil the timezone on my Pi is:
                           Local time: Mon 2025-10-06 20:26:51 BST
                       Universal time: Mon 2025-10-06 19:26:51 UTC
                             RTC time: Mon 2025-10-06 19:26:51
                            Time zone: Europe/London (BST, +0100)
            System clock synchronized: yes
                          NTP service: active
                      RTC in local TZ: no
            Is there something I need to do to try and resolve this? My MS calendar is set to a UTC timezone:
              @WallysWellies but iCal is reporting gmt
              • W
                @sdetweil because Microsoft? Not really sure.
                I’ve been digging into the iCal stuff and I see the windowsZones.json file which I presume does your MS to IANA mapping. In there is this line:
                "GMT Standard Time":{"iana":["Europe/London"]}
                Is that what you were referring to - should this not replace the GMT timezone with the IANA equivalent? I’m just wading through code I only partially understand…!
                I can ask a few people for sample icals to see if my GTM timezone is an oddity if that’s any use.
                  @WallysWellies can you add
                  stop MM
                  , "DEBUG"
                  to the logLevel value in config.js at the top
                  and then start MM in debug mode
                  npm start >somefile.txt 2>&1
                  wait til the calendar is up
                  then
                  ctrl-q on the MM screen to shut it down
                  then examine somefile.txt
                  (careful if posting, the debug log contains the full URL of the calendar from config.js)
                  • W
                    WallysWellies
                    I think this is the relevant entry from the log:
                    [2025-10-07 07:52:10.434] [DEBUG] parsed data={
                    "040000008200E00074C5B7101A82E008000000004ECDB12BC10FDC01000000000000000010000000012DADF723AF8140B35A2E374506E8D9": {
                        "type": "VEVENT",
                        "params": [],
                        "rrule": {
                          "_cache": {
                            "all": false,
                            "before": [],
                            "after": [],
                            "between": []
                          "origOptions": {
                            "tzid": "Europe/London",
                            "dtstart": "2025-08-26T17:45:00.000Z",
                            "freq": 2,
                            "until": "2025-10-07T16:45:00.000Z",
                            "interval": 1,
                            "byweekday": [
                                "weekday": 1
                            "wkst": {
                              "weekday": 0
                          "options": {
                            "freq": 2,
                            "interval": 1,
                            "wkst": 0,
                            "count": null,
                            "bysetpos": null,
                            "bymonth": null,
                            "bymonthday": [],
                            "bynmonthday": [],
                            "byyearday": null,
                            "byweekno": null,
                            "byweekday": [
                            "bynweekday": null,
                            "byhour": [
                              17
                            "byminute": [
                              45
                            "bysecond": [
                            "byeaster": null
                        "exdate": [],
                        "uid": "040000008200E00074C5B7101A82E008000000004ECDB12BC10FDC01000000000000000010000000012DADF723AF8140B35A2E374506E8D9",
                        "summary": "My Event",
                        "start": "2025-08-26T16:45:00.000Z",
                        "datetype": "date-time",
                        "end": "2025-08-26T17:30:00.000Z",
                        "class": "PUBLIC",
                        "priority": "5",
                        "dtstamp": "2025-10-07T06:52:10.000Z",
                        "transparency": "OPAQUE",
                        "status": "CONFIRMED",
                        "sequence": "0",
                        "location": "",
                        "MICROSOFT-CDO-APPT-SEQUENCE": "0",
                        "MICROSOFT-CDO-BUSYSTATUS": "BUSY",
                        "MICROSOFT-CDO-INTENDEDSTATUS": "BUSY",
                        "MICROSOFT-CDO-ALLDAYEVENT": "FALSE",
                        "MICROSOFT-CDO-IMPORTANCE": "1",
                        "MICROSOFT-CDO-INSTTYPE": "1",
                        "MICROSOFT-DONOTFORWARDMEETING": "FALSE",
                        "MICROSOFT-DISALLOW-COUNTER": "FALSE",
                        "MICROSOFT-REQUESTEDATTENDANCEMODE": "DEFAULT",
                        "MICROSOFT-ISRESPONSEREQUESTED": "FALSE",
                        "method": "PUBLISH"
                    The timezone does look to be getting updated to the IANA string. But line 33 has:
                    but the final event should be starting at 17:45 and ending at 18:30. So the ical does seem to imply that the series ends prior to the final event starting. Even if we account for the hour difference due to a potential timezone issue, the series is ending right as the final event starts.
                    Is there a particular part of the log that might be useful for digging deeper - a search string I can use to narrow things down? Or are we just looking at another Microsoft quirk…
                      @WallysWellies the ICS has
                      RRULE:FREQ=WEEKLY;UNTIL=20251007T164500Z;INTERVAL=1;BYDAY=TU;WKST=MO
                      so its a source problem. the parser processed this correctly.
                      we have no idea why its set like this, we just process the ICS data.
                      but the until is weird
                      Until Oct 08 (in the UI) , which isn’t a Tuesday, so the event could not happen then anyhow.
                      I’d try changing that and see what happens with the ICS data
                      • W
                        @sdetweil Thanks for the help. I’ll have a play around when I get a chance and see if I can figure out what’s going on.
