    32 bit Trixie
    5 Posts 2 Posters 296 Views 2 Watching
      musson
      I am trying to install MagicMirror on a 32 bit version of raspberry pi Trixie using sdetweils install script.
      Screen output:
      install log being saved to /home/pi/install.log
      Updating packages …
      Installing helper tools …
      installing correct version of node and npm, please wait
      /usr/local/bin/n: line 753: /usr/local/bin/node: cannot execute: required file not found
      node failed to install, exiting
      Last few lines of install.log:
      added 1 package in 467ms
      installing on trixie
      installed node version = v20.19.2
      No npm engines section specified in package.json, using default=V10.9.3 …
      installing : node-v22.18.0
      mkdir : /usr/local/n/versions/node/22.18.0
      fetch : https://nodejs.org/dist/v22.18.0/node-v22.18.0-linux-arm64.tar.xz
      copying : node/22.18.0
      installed : (with npm 10.9.3)
      Note: the node command changed location and the old location may be remembered in your current shell.
      old : /usr/bin/node
      new : /usr/local/bin/node
      If “node --version” shows the old version then start a new shell, or reset the location hash with:
      hash -r (for bash, zsh, ash, dash, and ksh)
      rehash (for csh and tcsh)
      node version was installed
      Any idea on what’s wrong or how to fix it?
      I am using 32 bit because I have 2 raspberry pi zero 2w that I run a small display on.
      The zero 2w doesn’t like 64 bit, very slow.
      Thanks!
      S 3 Replies Last reply Reply Quote 0
        sdetweil @musson
        @musson haven’t tried 32 bit trixie
        Will check It out later this afternoon , eye doctor appt shortly
          sdetweil @musson
          @musson 1st test was bookworm 32 on pi2w… all ok with script…
          flashing trixie now
            sdetweil @musson
            @musson 32 bit trixie is a mess…
            can’t change swap without a reboot…
            electron takes 20 minutes to start
            firefox puts up a web prompt, shouldn’t do this on less than 1 gig, have to click , came up but did not use the parms to go to the MM web page
            midori won’t go fullscreen via commandline, like it says it does…
            installing surf to see if it works
            surf crashes
            use bookworm 32 bit.
              musson @sdetweil
              Ok thanks for all your effort.
