    fixuppm2.sh
    6 Posts 2 Posters 649 Views 2 Watching
    • AssassinsA Offline
      Assassins
      pi@MagicMirror:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
      the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
      sudo: npm: command not found
      bash: linje 127: pm2: command not found
      bash: linje 211: pm2: command not found
      bash: linje 214: pm2: command not found
      pi@MagicMirror:~ $ npm -v
      11.6.2
      pi@MagicMirror:~ $
      The log say
      pm2 setup starting - tor okt 16 18:38:30 CEST 2025
      using parameter bash
      system is Linux EmptyImage 6.12.47+rpt-rpi-v7 #1 SMP Raspbian 1:6.12.47-1+rpt1~bookworm (2025-09-16) armv7l GNU/Linux
      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 12 (bookworm) Release: 12 Codename: bookworm
      node version v22.20.0
      force installing latest npm version via npm
      npm version 10.9.3
      pm2 not installed, installing
      get the pm2 platform specific startup command
      startup command =
      pm2 startup command done
      configure the pm2 config file for MagicMirror
      start MagicMirror via pm2 now
      save MagicMirror pm2 config now
      pm2 setup completed - tor okt 16 18:39:22 CEST 2025
      pm2 setup starting - fre okt 17 13:46:28 CEST 2025
      system is Linux MagicMirror 6.12.47+rpt-rpi-v7 #1 SMP Raspbian 1:6.12.47-1+rpt1~bookworm (2025-09-16) armv7l GNU/Linux
      npm version 11.6.2
      startup command =
      pm2 setup completed - fre okt 17 13:46:29 CEST 2025
      i can install pm2 but only with “npm install -g pm2” and not “sudo npm install -g pm2”
        sdetweil @Assassins
        @Assassins -g means it’s available globally across the system
        You can execute it in every folder
        AND globally means adding to the /usr folder tree which require root authority (sudo)
        Without means you have to be in the folder tree where you did npm install, AND If the install folder is NOT in the path, then you have to prefix pm2 with the correct path EVERY TIME
        I think this also breaks boot time support which is the primary value, in my opinion
        AssassinsA 1 Reply Last reply Reply Quote 0
          Assassins @sdetweil
          @sdetweil said in fixuppm2.sh:
          But your script works fine now that I have installed pm2
          • AssassinsA Assassins has marked this topic as solved on
            sdetweil @Assassins
            @Assassins which script?
            And how did you install it. -g or not
              Assassins @sdetweil
              With -g
              My second test was without -g and it works there too
                sdetweil @Assassins
                @Assassins weird
