    Fresh Install / node: bad option: --run
    6 Posts 2 Posters 1.3k Views 2 Watching
      r0t
      i’m super fresh into MagicMirror and on my first installation attempt i have problems.
      I have a Raspi4B with RaspiOS
      I installed nodejs
      node --version
      returns -> v20.19.2
      I have pulled the git with
         git clone https://github.com/MagicMirrorOrg/MagicMirror
      and i’m in the repository but the command
      node --run install-mm
      Gives me this prompt: node: bad option: --run
      i’m feeling dumb but im not very got at linux at all ,D bu i want too learn
        sdetweil @r0t
        @r0t we need node 22.18, the release notes say
        If you had used the scripted install it would have handled that
          r0t
          OK ist working with your Script … How convenient
          Thx you for the super fast answer and your work putting together that Script.
            r0t
            @sdetweil first try with your Script failed with this prompt
            install log being saved to /home/red/install.log
            Updating packages ...
            Installing helper tools ...
            installing correct version of node and npm, please wait
            sudo: n: command not found
            node failed to install, exiting
            After Updating to node v24.11.0
            im waiting for
            Installing dependencies ...
            i give you feedback when i’m up and running ;D
              sdetweil @r0t
              @r0t can you send me ~/install.log
              My email is this userid at gmail
                r0t
                @sdetweil I have send you the Mail with the log. Also the Mirror ist runnig so this thread is solved.
                • R r0t has marked this topic as solved on
