    Version 2.33.0/node v22.21.0 - Error: write EFAULT
    9 Posts 2 Posters 835 Views 2 Watching
      Mr.Sponti
      I’ve done a new installation on a RPI 4. Everthing is running fine, independant of a error message at start time where I don’t have any idea which module or core function produce the message.
      Here is my configuration:
      MM v2.33.0
      node 22.21.0
      trixie: Linux devpi 6.12.47+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1 (2025-09-16) aarch64 GNU/Linux
      Maybe, there is someone who has already fixed that problem. How to proceed to identify this issue?
      Nov 21 15:18:47 devpi mm[2438]: [2025-11-21 15:18:47.026] [LOG]   Starting MagicMirror: v2.33.0
      Nov 21 15:18:47 devpi mm[2438]: [2025-11-21 15:18:47.034] [LOG]   Loading config ...
      Nov 21 15:18:55 devpi mm[2438]: [2025-11-21 15:18:55.059] [LOG]   MMM-NotificationBoard helper started ...
      Nov 21 15:18:55 devpi mm[2438]: [2025-11-21 15:18:55.060] [LOG]   Connecting socket for: MMM-RTSPphas
      Nov 21 15:18:55 devpi mm[2438]: [2025-11-21 15:18:55.060] [LOG]   MMM-RTSPphas helper started ...
      Nov 21 15:18:55 devpi mm[2438]: [2025-11-21 15:18:55.060] [LOG]   Connecting socket for: MMM-EnergyMonitor
      Nov 21 15:18:55 devpi mm[2438]: [2025-11-21 15:18:55.131] [LOG]   Connecting socket for: MMM-Spotify
      Nov 21 15:18:55 devpi mm[2438]: [2025-11-21 15:18:55.133] [LOG]   Connecting socket for: MMM-SpeechToCommand
      Nov 21 15:18:55 devpi mm[2438]: [2025-11-21 15:18:55.134] [LOG]   MMM-SpeechToCommand helper started ...
      Nov 21 15:18:55 devpi mm[2438]: [2025-11-21 15:18:55.135] [LOG]   Sockets connected & modules started ...
      Nov 21 15:18:56 devpi mm[2438]: [2025-11-21 15:18:56.117] [ERROR] Error: write EFAULT
      Nov 21 15:18:56 devpi mm[2438]:     at afterWriteDispatched (node:internal/stream_base_commons:159:15)
      Nov 21 15:18:56 devpi mm[2438]:     at writeGeneric (node:internal/stream_base_commons:150:3)
      Nov 21 15:18:56 devpi mm[2438]:     at Socket._writeGeneric (node:net:966:11)
      Nov 21 15:18:56 devpi mm[2438]:     at Socket._write (node:net:978:8)
      Nov 21 15:18:56 devpi mm[2438]:     at writeOrBuffer (node:internal/streams/writable:572:12)
      Nov 21 15:18:56 devpi mm[2438]:     at _write (node:internal/streams/writable:501:10)
      Nov 21 15:18:56 devpi mm[2438]:     at Writable.write (node:internal/streams/writable:510:10)
      Nov 21 15:18:56 devpi mm[2438]:     at execSync (node:child_process:999:20)
      Nov 21 15:18:56 devpi mm[2438]:     at node:electron/js2c/node_init:2:17346
      Nov 21 15:18:56 devpi mm[2438]:     at /home/pi/MagicMirror/node_modules/systeminformation/lib/system.js:175:28
      Nov 21 15:18:56 devpi mm[2438]:     at ChildProcess.exithandler (node:child_process:410:7)
      Nov 21 15:18:56 devpi mm[2438]:     at ChildProcess.emit (node:events:519:28)
      Nov 21 15:18:56 devpi mm[2438]:     at maybeClose (node:internal/child_process:1101:16)
      Nov 21 15:18:56 devpi mm[2438]:     at Socket.<anonymous> (node:internal/child_process:456:11)
      Nov 21 15:18:56 devpi mm[2438]:     at Socket.emit (node:events:519:28)
      Nov 21 15:18:56 devpi mm[2438]:     at Pipe.<anonymous> (node:net:346:12)
      Nov 21 15:18:56 devpi mm[2438]: [2025-11-21 15:18:56.118] [LOG]   Node NOT Exiting...
      Nov 21 15:18:56 devpi mm[2438]: [2025-11-21 15:18:56.283] [LOG]   Launching application.
        sdetweil @Mr.Sponti
        @Mr.Sponti we are trying to get the system information for this output
        [2025-11-21 10:30:49.475] [LOG] Launching application.
        [2025-11-21 10:30:50.438] [INFO]
        System Information
        • SYSTEM: manufacturer: System manufacturer; model: System Product Name; virtual: false; MM: 2.33>
        • OS: platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-160-ge>
        • VERSIONS: electron: 38.3.0; used node: 22.20.0; installed node: 22.18.0; npm: 10.9.3; pm2: 6.0.13
        • ENV: XDG_SESSION_TYPE: x11; MM_CONFIG_FILE: undefined
          WAYLAND_DISPLAY: undefined; DISPLAY: :0.0; ELECTRON_ENABLE_GPU: undefined
        • RAM: total: 48077.12 MB; free: 6870.40 MB; used: 41206.72 MB
        • OTHERS: uptime: 44548 minutes; timeZone: America/Chicago
        but appears there is a fault.
          Mr.Sponti
          Here my System Information (started with: node --run start:wayland):
          [2025-11-22 10:47:48.003] [LOG]   Sockets connected & modules started ...
          [2025-11-22 10:47:49.223] [ERROR] Error: write EFAULT
          [2025-11-22 10:47:49.224] [LOG]   Node NOT Exiting...
          [2025-11-22 10:47:49.395] [LOG]   Launching application.
          [2025-11-22 10:47:56.485] [INFO]
          ####  System Information  ####
          - SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.1; virtual: false; MM: 2.33.0
          - OS:       platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.47+rpt-rpi-v8
          - VERSIONS: electron: 38.1.2; used node: 22.19.0; installed node: 22.21.0; npm: 10.9.4; pm2: 6.0.13
          - ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
                      WAYLAND_DISPLAY:  wayland-0; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
          - RAM:      total: 906.64 MB; free: 449.86 MB; used: 456.78 MB
          - OTHERS:   uptime: 21 minutes; timeZone: Europe/Berlin
            Mr.Sponti
            So, after further investigations I found the issue in the module: ./MagicMirror/node_modules/systeminformation/lib/system.js:175:28
            I’m not a nodejs expert, but it seems that execSync returns a invalid or corrupted raw buffer. The encoding option solved the issue, as in my case execSync returns now an empty string.
            const stdout = execSync('dmesg 2>/dev/null | grep -iE "virtual|hypervisor" | grep -iE "vmware|qemu|kvm|xen" | grep -viE "Nested Virtualization|/virtual/"', {encoding: 'utf-8'});
              sdetweil @Mr.Sponti
              @Mr.Sponti if you take the contents of the execSync() and run it at the command line does it work?
                Mr.Sponti
                Yes, without any error, but also without any output!
                  sdetweil @Mr.Sponti
                  @Mr.Sponti how about the 1st command
                  dmesg
                  In the line in the execSync it throws away any errors
                    Mr.Sponti
                    Sam, the kernel buffer does not include a line with ‘virtual’ or ‘hypervisor’. So, the retuen value of the execSync is a emty string.
                    pi@devpi:~ $ dmesg | grep virtual
                    pi@devpi:~ $ dmesg | grep hypervisor
                    pi@devpi:~ $ dmesg | grep zram0
                    [    4.928549] zram_generator::config[229]: zram0: system has too much memory (905MB), limit is 0MB, ignoring.
                    [    5.775275] systemd[1]: Expecting device dev-zram0.device - /dev/zram0...
                    [    5.977908] zram: Added device: zram0
                    [    6.771158] zram0: detected capacity change from 0 to 1853440
                    [    6.998349] Adding 926716k swap on /dev/zram0.  Priority:100 extents:1 across:926716k SS
                      sdetweil @Mr.Sponti
                      @Mr.Sponti yep errors, too much ram. Etc
                      What is this running in?
