Cannot access MM2 across the network - localhost ok
Hi All. I have been using computers for a long time, and have recently taken the jump into Linux. My wife started my interest with the MagicMirror project.
So far all has been great. I’ve install the MM2 v2.33 and had it running. I’ve added modules and all was good. Testing on the Pi was fine, and I would even access from my Laptop. However, I have made some silly mistake somewhere, which only became apparent when I rebooted. I cannot access from the IP any longer. localhost on the Pi still works, but Modules like FormulaOne and getting my Gmail calendar just sit “loading”. All was good before the reboot.
Can anyone offer any suggestions?
I’ve checked config.js and the IP is blank, and IPWhitelist is blank (unchanged from before the reboot)
On starting the MM
[2025-12-14 15:19:39.798] [LOG] Starting MagicMirror: v2.33.0 [2025-12-14 15:19:39.814] [LOG] Loading config ... [2025-12-14 15:19:39.818] [LOG] config template file not exists, no envsubst [2025-12-14 15:19:41.369] [INFO] Checking config file /home/den/MagicMirror/config/config.js ... [2025-12-14 15:19:41.638] [INFO] Your configuration file doesn't contain syntax errors :) [2025-12-14 15:19:41.646] [INFO] Checking modules structure configuration ... [2025-12-14 15:19:41.936] [ERROR] This module configuration contains errors: undefinedmust be object [2025-12-14 15:19:41.943] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read properties of undefined (reading 'module') [2025-12-14 15:19:41.946] [LOG] Loading module helpers ... [2025-12-14 15:19:41.981] [LOG] Initializing new module helper ... [2025-12-14 15:19:41.983] [LOG] Module helper loaded: updatenotification [2025-12-14 15:19:41.984] [LOG] No helper found for module: helloworld. [2025-12-14 15:19:41.985] [LOG] All module helpers loaded. [2025-12-14 15:19:42.011] [LOG] Starting server on port 8080 ... [2025-12-14 15:19:42.999] [LOG] Server started ... [2025-12-14 15:19:43.003] [LOG] Connecting socket for: updatenotification [2025-12-14 15:19:43.005] [LOG] Starting module helper: updatenotification [2025-12-14 15:19:43.006] [LOG] Sockets connected & modules started ... [2025-12-14 15:19:43.344] [LOG] Launching application.There seems to be an error, but it isn’t giving me any pointers
Many thanks for any help
[2025-12-14 15:19:41.943] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read properties of undefined (reading ‘module’)you have a bad config.js, and it started with the default which is not outside enabled…
can you post your config.js , make sure to xxx out any personal info, apikeys or calendar urls…
use the code blockbefore posting do this
cd ~/MagicMirror/config node -c config.jssee if that provides a better error messsage
@dangerousden this error is reported when there are 2 commas in a row between modules
},, { module: "foo",the next release shows this error in detail,
Your configuration file contains syntax errors :( Line 1726 column 9: Unexpected comma in middle of array.node -c doesn’t report it
