    Version 2.34.0 - Missing X Server or $DISPLAY (Docker version of MMOS)
    15 Posts 3 Posters 3.5k Views 3 Watching
      sdetweil @karsten13
      @karsten13 thanks
      karsten13K 1 Reply Last reply
      • karsten13K
        karsten13 @sdetweil
        other questions (not clear from description):
        Are you using mmos or are you using Raspberry Pi OS or another OS?
        If not mmos, how did you the install? With the install script inside the repo?
        Can you provide output of docker compose config?
          Mathes75
          Thanks a lot for having a look at my issue!
          As mentioned in the first post, I downloaded the most recent Docker image of MagicMirrorOS. - no desktop, lite version. Wrote the image with Balena Etcher and let the Rpi do it’s magic after booting until “factory” MagicMirror was shown. SSHed into the Rpi and ran sudo raspi-config to adjust locales and WiFi.
          I installed the desired Modules, modified the config.js - and now the Mirror works only at every third or fourth boot. (Sometimes real power cycle, sometimes sudo shutdown -r now - sometimes first works, sometimes second)
          Currently it’sworking, only one Module has issues. Both containers recreated and restarted, output of docker logs labwc
          00:00:00.000 [INFO] [seatd/seat.c:48] Created VT-bound seat seat0
          00:00:00.000 [INFO] [seatd/seatd.c:194] seatd started
          failed to connect to display
          00:00:01.036 [INFO] [seatd/server.c:145] New client connected (pid: 1, uid: 1000, gid: 1000)
          00:00:01.036 [INFO] [seatd/seat.c:239] Added client 1 to seat0
          00:00:01.037 [INFO] [seatd/seat.c:563] Opened client 1 on seat0
          HDMI-A-1 "Lenovo Group Limited T2224pD V902B58B (HDMI-A-1)"
            Make: Lenovo Group Limited
            Model: T2224pD
            Serial: V902B58B
            Physical size: 480x270 mm
            Enabled: yes
            Modes:
              1920x1080 px, 60.000000 Hz (preferred, current)
              1920x1080 px, 59.939999 Hz
              1920x1080 px, 50.000000 Hz
              1680x1050 px, 59.882999 Hz
              1600x900 px, 75.000000 Hz
              1600x900 px, 60.000000 Hz
              1280x1024 px, 75.025002 Hz
              1280x1024 px, 70.000999 Hz
              1280x1024 px, 60.020000 Hz
              1440x900 px, 59.901001 Hz
              1366x768 px, 59.790001 Hz
              1152x864 px, 75.000000 Hz
              1280x720 px, 60.000000 Hz
              1280x720 px, 59.939999 Hz
              1280x720 px, 50.000000 Hz
              1024x768 px, 75.028999 Hz
              1024x768 px, 70.069000 Hz
              1024x768 px, 60.004002 Hz
              832x624 px, 74.551003 Hz
              800x600 px, 75.000000 Hz
              800x600 px, 72.188004 Hz
              800x600 px, 60.317001 Hz
              800x600 px, 56.250000 Hz
              720x576 px, 50.000000 Hz
              720x480 px, 60.000000 Hz
              720x480 px, 59.939999 Hz
              640x480 px, 75.000000 Hz
              640x480 px, 72.808998 Hz
              640x480 px, 60.000000 Hz
              640x480 px, 59.939999 Hz
              720x400 px, 70.082001 Hz
            Position: 0,0
            Transform: normal
            Scale: 1.000000
            Adaptive Sync: disabled
          Output of docker compose config
          services:
            labwc:
              container_name: labwc
              environment:
                LAB_WC_HIDE_CURSOR: "true"
                RANDR_PARAMS: ""
                RANDR_POLL: 1m
                XDG_RUNTIME_DIR: /run/user/1000
              image: karsten13/labwc:latest
              networks:
                default: null
              privileged: true
              restart: always
              volumes:
                - type: bind
                  source: /run/user/1000
                  target: /run/user/1000
                  bind: {}
                - type: bind
                  source: /run/udev
                  target: /run/udev
                  bind: {}
            magicmirror:
              container_name: mm
              environment:
                DBUS_SESSION_BUS_ADDRESS: unix:path=/run/user/1000/bus
                DBUS_SYSTEM_BUS_ADDRESS: unix:path=/run/user/1000/bus
                DISPLAY: unix:0.0
                ELECTRON_ENABLE_GPU: "0"
                MM_CUSTOMCSS_FILE: css/custom.css
                MM_MODULES_DIR: modules
                MM_OVERRIDE_DEFAULT_MODULES: "true"
                MM_SCENARIO: electron
                MM_SHOW_CURSOR: "false"
                WAYLAND_DISPLAY: wayland-0
              image: karsten13/magicmirror:latest
              network_mode: host
              privileged: true
              restart: always
              shm_size: "268435456"
              volumes:
                - type: bind
                  source: /tmp/.X11-unix
                  target: /tmp/.X11-unix
                  bind: {}
                - type: bind
                  source: /home/pi/.Xauthority
                  target: /home/node/.Xauthority
                  bind: {}
                - type: bind
                  bind: {}
                - type: bind
                  source: /opt/mm/mounts/config
                  target: /opt/magic_mirror/config
                  bind: {}
                - type: bind
                  source: /opt/mm/mounts/modules
                  target: /opt/magic_mirror/modules
                  bind: {}
                - type: bind
                  source: /opt/mm/mounts/css/custom.css
                  target: /opt/magic_mirror/css/custom.css
                  bind: {}
              post_start:
                - command:
                    - /bin/sh
                    - -c
                      [ "init" = "init" ] || exit 0
                      chown -R 1000:1000 config modules css/custom.css
                      chmod -R 777 config modules css/custom.css
                  user: root
                  environment:
                    MM_CHMOD: null
                    MM_GID: null
                    MM_INIT: null
                    MM_UID: null
          networks:
            default:
          Have a nice weekend!
          • karsten13K
            karsten13 @Mathes75
            @Mathes75
            not sure I really fixed it but you can try
            cd /opt/mm
            git pull
            ./install/install.sh electron
            Let me know if there are still problems after reboot or not.
            M 1 Reply Last reply
              Mathes75 @karsten13
              Thanks @karsten13!
              git pull needed a commit to work. Done. Installing Electron revealed no change to apply.
              At least I seem to be one step further: Recreating the images as mentioned in a post above repeatedly resolved the "missing X Server"message each time and started MagicMirror…
              As I am quite done with all changes and adaptions, I am fine to keep the workaround with recreating the image(s), once the mirror needs a restart.
              • karsten13K
                karsten13 @Mathes75
                @Mathes75
                Let me know if you get another black screen without mm start after reboot (I want to know if it is fixed or not …)
                Can you please show me again the output of docker compose config (so I can check if you have the latest changes)?
                  Mathes75 @karsten13
                  @karsten13 New issue. I did the
                  cd /opt/mm
                  git pull
                  again and now I’m facing:
                  pi@magicmirrorMB:/opt/mm $ ./install/install.sh electron
                  --> Check docker installation
                  Docker is already installed:
                  Docker version 29.1.3, build f52814d
                  Docker Compose version v5.0.1
                  Found no xserver or wayland so using own container
                  --> Pulling container images and starting magicmirror
                  Going to remove mm
                  [+] remove 1/1
                   ✔ Container mm Removed        0.1s
                  WARN[0000] No services to build
                  [+] up 2/2
                   ✘ Container labwc Error dependency labwc failed to start        1.3s
                   ✔ Container mm    Created        0.6s
                  dependency failed to start: container labwc has no healthcheck configured
                  Don´t know what went wrong.
                  Output of docker compose config is:
                  pi@magicmirrorMB:/opt/mm/run $ docker compose config
                  services:
                    labwc:
                      environment:
                        RANDR_PARAMS: ""
                        RANDR_POLL: 1m
                        XDG_RUNTIME_DIR: /tmp/labwc
                      networks:
                        default: null
                      privileged: true
                      restart: always
                      volumes:
                        - type: bind
                          source: /tmp/labwc
                          target: /tmp/labwc
                          bind: {}
                        - type: bind
                          source: /run/udev
                          target: /run/udev
                          bind: {}
                    magicmirror:
                      container_name: mm
                      depends_on:
                        labwc:
                          condition: service_healthy
                          restart: true
                          required: true
                      environment:
                        DISPLAY: unix:0.0
                      network_mode: host
                      privileged: true
                      restart: always
                      volumes:
                        - type: bind
                          bind: {}
                        - type: bind
                          bind: {}
                        - type: bind
                          source: /tmp/labwc
                          target: /tmp/labwc
                          bind: {}
                        - type: bind
                          bind: {}
                        - type: bind
                          bind: {}
                        - type: bind
                          bind: {}
                      post_start:
                        - command:
                            - /bin/sh
                            - -c
                              if [ "init" = "init" ]; then
                                # update volume permissions
                              fi
                              if command -v node_modules/.bin/electron > /dev/null; then
                                # if electron is installed then start dbus-daemon to avoid errors in the logs
                                dbus-daemon --system || true
                              fi
                          user: root
                  networks:
                    default:
                  Any way to get back to the easy issue?
                  • karsten13K
                    karsten13 @Mathes75
                    @Mathes75
                    looks like you still have an old labwc image, try from /opt/mm/run folder:
                    docker compose pull
                    docker compose up -d
                      Mathes75 @karsten13
                      @karsten13
                      Back to function! Several restarts without blank screen!
                      Output of docker compose config - in case it is useful…
                      services:
                        labwc:
                          environment:
                            RANDR_PARAMS: ""
                            RANDR_POLL: 1m
                          networks:
                            default: null
                          privileged: true
                          restart: always
                          volumes:
                            - type: bind
                              source: /tmp/labwc
                              target: /tmp/labwc
                              bind: {}
                            - type: bind
                              source: /run/udev
                              target: /run/udev
                              bind: {}
                        magicmirror:
                          container_name: mm
                          depends_on:
                            labwc:
                              restart: true
                              required: true
                          environment:
                            DISPLAY: unix:0.0
                          network_mode: host
                          privileged: true
                          restart: always
                          volumes:
                            - type: bind
                              bind: {}
                            - type: bind
                              bind: {}
                            - type: bind
                              source: /tmp/labwc
                              target: /tmp/labwc
                              bind: {}
                            - type: bind
                              bind: {}
                            - type: bind
                              bind: {}
                            - type: bind
                              bind: {}
                          post_start:
                            - command:
                                - /bin/sh
                                - -c
                                  fi
                                  fi
                              user: root
                      networks:
                        default:
                        Mathes75 @Mathes75
                        Pi rebooted twice today (initiated by myself) and issue didn’t come back - I think this can bei marked as resolved - thanks a lot!
                        Now I can take care about Python and fritzconnector…
                          sdetweil @Mathes75
                          @Mathes75 can you find the message that best explains the fix,
                          click the 3 dots to the right and select
                          Mark this post as the correct answer
                          • M Mathes75 has marked this topic as solved on
