    modules
    24 Posts 4 Posters 6.1k Views 4 Watching
      sdetweil @pat59
      @pat59 yes, one or the other
      P 1 Reply Last reply
        pat59 @sdetweil
        @sdetweil Hello, I installed MPlayer but it doesn’t work; the screen is black.
        P S 2 Replies Last reply
          pat59 @pat59
          I uninstalled MPlayer and reinstalled RTSPTream, it works except that I still encounter the same problem
            sdetweil @pat59
            @pat59 black screen, what were the messages at MagicMirror startup time?
              pat59 @sdetweil
              @sdetweil Good evening, no message, normal startup for the Raspberry Pi, normal startup for MagicMirrorr2, and a black screen, no message.
                sdetweil @pat59
                @pat59 can you show the messages
                P 2 Replies Last reply
                  pat59 @sdetweil
                  @sdetweil Good evening, there was no message displayed for MPlayer, so I uninstalled it in config.js and reinstalled RTSTseam. Everything is back to normal except that I still have the taskbar displayed. Thank you.
                    pat59 @sdetweil
                      sdetweil @pat59
                      @pat59 I know. But if you keep changing we can’t debug what’s going on
                      There had to be at least one message for bolster in the startup messages.
                        pat59 @sdetweil
                        @sdetweil Hello, yes, I understand perfectly. Excuse me, being a novice, I’m too afraid I won’t be able to get it working again. I’ve put the old module back in. I’m going to try again with MPlayer and will get back to you. Once again, I’m sorry, I’m very attached to my mirror.
                          sdetweil @pat59
                          @pat59 I understand. I suggest using a new separate config file for new individual modules until you get them working
                          You can use the environment variable to define it
                          export MM_CONFIG_FILE=config/fribble.js
                          Or whatever name you choose
                          Then
                          npm start
                          After turning off any pm2 instance
                          Then you haven’t touched your good config
                          Can stop any time, have only one module of output to deal with
                          Once all good, you copy this one module def to your good config
                            pat59 @pat59
                            Sorry to be back, I had to be away. I’m taking this opportunity to ask you to close the request as I’m currently unable to address the issue. Thank you for your understanding.
                            Sincerely,
                            I would like to thank everyone who contributed. See you soon.
                              sdetweil @pat59
                              @pat59 no problem leaving it open. Come back when you can.
