    multiple MMM-HTMLSnippet
    5 Posts 2 Posters 240 Views 2 Watching
      costascontis
      hi guys,i use MMM-HTMLSnippet module to display 6 cameras of my home.I renamed the modules from MMM-HTMLSnippet1 to MMM-HTMLSnippet6.I use custom css to arrange cameras correctly and all my 6 cams working just fine.Yesterday i got a seventh one to use as a bird camera watching my bird feeder at my yard.I renamed everything as it should and put it at top_left .The issue is that after adding the seventh cam only six cams is showing at once.The first six that loading after restarting magicmirror.I cant understand it.My magicmirror is running at a rpi4 2gig ram.Is there a limit of how much of the same module a can run simultaneously?
        sdetweil @costascontis
        @costascontis seems to be a browser limit, 6 per url hostname/domain
          @costascontis did you change the name inside the modulename.js
            costascontis @sdetweil
            @sdetweil yes …everywhere.The first 6 r working nice.It doesnt matter the cam.It shows only the first 6 ,the sevnth it does not load the video.I moved things around,i disabled all modules exept MMM-HTMLSnippet(s),there is no error at logs… The 6 first loading cameras r showing video ,the last does not load.I put delay at several cameras to confirm that only the last one,doent matter who it is ,its not loading…very strange.I am out of ideas!
                @sdetweil tnhx mate this was very helpfull
                • C costascontis has marked this topic as solved on
