    Weather module with openmeteo sends wrong Data
    11 Posts 2 Posters 450 Views 2 Watching
    • T Offline
      TiLow
      TLDR: Weather module using openmeteo as provider randomly starts throwing the Error: “[openmeteo] Could not find current time in hourly data, using index 0” and then displays wrong Data.
      Hello everyone,
      since some time I have a problem that my weather Data (especially the Feels Like Temperature) is completely wrong.
      The error only comes up sometimes, but I have not figured out a pattern yet, it seems to be random.
      I have looked a little bit into it and found that sometimes there is a debug message in my Logs saying: “[openmeteo] Could not find current time in hourly data, using index 0”.
      I am guessing that this is the reason for the wrong data, but I have no Idea how to fix this.
      I hope some of you are smarter than I am :)
        sdetweil @TiLow
        @TiLow the weather module fix was just released in 2.36
        Use my upgrade script
          sdetweil @TiLow
          @TiLow what MagicMirror version are you on?
          • T Offline
            TiLow
            I am using version 2.35.0 on a Raspberry Pi 3B+.
            I have just found another Error Message that is being created in the Terminal Logs when starting up the MagicMirror: [ERROR] [unknown] (node:8839) [DEP0040] DeprecationWarning: The punycode module is deprecated. Please use a userland alternative instead. (Use electron --trace-deprecation … to show where the warning was created).
            But i doubt that this has anything to do with the weather module not showing the correct Data.
            Thanks in advance :)
              sdetweil @TiLow
              @TiLow I’ve opened issue in the MagicMirror repo
              https://github.com/MagicMirrorOrg/MagicMirror/issues/4122
              Could you post your weather config
              Thx
              The punycode problem Is a different module that hasn’t been updated in a while MMM-HomeAssistantDisplay was one I checked out before release .
              • T Offline
                TiLow
                Sure, here is the weather part of my config.js file (I just redacted some personal information).
                I have three different parts of this module (Current, hourly and daily).
                The one with the problem (Feels like temperature wrong) is the first instance (current).
                		module: "weather",
                			weatherProvider: "openmeteo",
                			type: "current",
                			appendLocationNameToHeader: false,
                			lat: ,
                			lon: ,
                			degreeLabel: true,
                			updateInterval: 300000,
                			showPrecipitationProbability: true,
                			showPrecipitationAmount: true,
                			showUVIndex: true,
                			showFeelsLike: true
                		module: "weather",
                		position: "bottom_right",
                			type: "hourly",
                			lat: ,
                			lon: ,
                			degreeLabel: true,
                			fade: false,
                			maxEntries: 12,
                			showUVIndex: true
                		module: "weather",
                			type: "daily",
                			lat: ,
                			lon: ,
                			degreeLabel: true,
                			fade: false,
                			maxEntries: 5,
                			ignoreToday: false,
                  sdetweil @TiLow
                  @TiLow thanks
                  • T Offline
                    TiLow
                    I just checked the Github issue that you created and it seems like the problem has been solved.
                    Thank you very much for your help :).
                    Just another question as you seem to know a lot more about MagicMirror than I do:
                    Is there some kind of fix for the punycode problem that I can do, or can I just ignore it as it seems to work fine the way it is.
                    Additional modules that I am using are:
                    https://github.com/ZachR19/MMM-Todoist2
                    https://github.com/LukeSkywalker92/MMM-Globe
                    https://github.com/fewieden/MMM-Fuel
                    Thanks in advance.
                      sdetweil @TiLow
                      @TiLow just ignore the punycode message.
                      We are discussing ways to distribute a number of fixes
                        sdetweil @TiLow
                        • S sdetweil has marked this topic as solved
                        • T Offline
                          TiLow
                          @sdetweil I have updated the module and been running the new version for some days now and it seems to work as intended again.
                          Thank you very much for helping me out :)
                            sdetweil @TiLow
                            @TiLow awesome! As moderator here, I think my job is to help users make and keep their mirrors running. Watch for trouble and find ways to resolve it.
                            Your clear description of the problem helped identify a good resolution. I didn’t do any of the work. Just connected the dots.
