    audio problem
    13 Posts 2 Posters 3.9k Views 2 Watching
    • T Offline
      tommyk
      hi there, I am using my mirror as a jukebox
      and everything works fine on manual start
      hello lucy welcomes me with a message and mmm jukebox plays my music
      with no problem, but i have used a bash file to autostart my mirror which works well except there is no audio until i close the mirror and manual start it,
      could anyone please help
      thanks
      tommyk
      • T Offline
        tommyk @sdetweil
        @sdetweil Hi Sam
        turned my pi4 on this morning
        bluetooth speaker said I am now connected
        Magic Mirror started after a short pause
        hello lucy said hello and welcome to magic mirror jukebox
        I clicked on a jukebox button and woke the neighbors up . lol…joking
        and I thought (yippi) music played
        now, I mess around with so many different things at once I confuse myself
        so I dont know exactly what I done, but I did put a pound sigh at the start of the bash file
        and changed the sleep time to 30
        and done what you advised , run start with x11 etc.
        Im not sure but I think I may have pasted some of your pm2 script in terminal
        but whatever i did , thanks to you my problem is solved, I think you are a genius
        my next project is to get my android phone to control the mirror
        I tried mmm remote once and failed , so now that the autostart is working
        I will try that again
        thank you so much for all your help
        ps, I think I may be back to you regarding this remote module
        thank you
        tommyk
          sdetweil @tommyk
          @tommyk can you describe the environment, how does the music get played?
          What do you mean by manual start bs auto?
          What version of MagicMirror are you running?
          Show the system info section of the output from startup
          As for your other post, all messages from users with reputation below 2 are reviewed before posting on the forum
            sdetweil @tommyk
            @tommyk looking at the code, I think the system is busy during bootup, and this causes an uncaught failure
            There is a new notification , sent after updateDom() is called, to inform the app that the content has been drawn.
            See
            https://docs.magicmirror.builders/module-development/notifications.html#system-notifications
            MODULE_DOM_UPDATED
            I think the module needs to use that notification to wait to start the play of the audio element it just added
            • T Offline
              tommyk @sdetweil
              @sdetweil Hi sam
              thanks for your reply, and thanks to everyone for all these wonderful modules
              firstly I must say that I am a complete novice ,but love messing about with this mirror thing
              I am running a pi 4 with debian 13 (trixie).
              so when I type in terminal (cd MagicMirror npm start) the mirror starts with audio… ie Manual start
              but when I created a bash file to autostart the mirror, which I got on utube from the fuzz guy
              the mirror starts up automatically when the pi has loaded up… but there is no audio…
              then if i click control and m to close the mirror and type in terminal the audio is on again.
              so it seems something is not loading on autostart.
              thats about all I know, sorry but I dont know how to show system info
              thanks
              tommyk
                sdetweil @tommyk
                @tommyk I understand
                Maybe there will be some info here
                After starting from boot , where the audio fails,
                Open the browser developers window
                ctrl-shift-i
                Select the console tab, and put juke in the filter field
                To see if there are any errors, usually marked in red
                If so, copy paste them here
                Same keystroke to get out of dev window
                Let me know what you find
                Another test thing to try, is add a sleep 30
                In the script before launching MagicMirror to see if that makes a difference
                • T Offline
                  tommyk @sdetweil
                  @sdetweil hello again
                  thanks for your help sam.
                  I said I was a novice but neglected to say I am also a 77 year old fool, and I have just realized that I overlooked an issue which may be the problem I am having…so let me recap…
                  when I start up my pi 4 my speaker says bluetooth is now connected, then after 20 seconds the mirror starts with no audio, so I close the mirror and paste npm in terminal… ok…
                  then I just realized that the mirror wont start because the port is being used by another ?
                  so I have to open config.js to change the port number…
                  then the mirror opens up with audio and works fine…
                  so it seems it is a port issue…but how to fix this, I have no idea lol.
                  I just dont understand if it working ok when I change the port number , why is does not work on restart the next day.
                  why is the port being used by another something or other…
                  if the port was’nt being used then the mirror would autostart with no problem…I assume
                  any advice on that would be appreciated, and sorry for being a nusance
                  thanks again
                  tommyk
                  S T 2 Replies Last reply Reply Quote 0
                    sdetweil @tommyk
                    @tommyk no nuisance at all.
                    So, how did you setup to auto start. If you are using pm2 then there are commands that can help you without editing the config file to change the port
                    • T Offline
                      tommyk @tommyk
                      well I tried pm2 method but could not get it to work
                      so I found a utube vid by the fuzz guy on how to autostart magic mirror
                      so I followed his instructions and finally got it to work
                      https://www.youtube.com/watch?v=iqNHX8v8cPY
                      perhaps I did something wrong . as I had to try a few times before it would actually autostart
                      cheers
                        sdetweil @tommyk
                        @tommyk awesome… thanks…
                        ps. I am the current author/maintainer of the scripted MM install and upgrade scripts.
                        referenced in the MM install doc, Alternative install methods…
                        I provide the mm.sh. and the pm2 setup to use it.
                        if you say no during install, then I provide a separate script to add that after the fact
                        I use pm2 because it fixes the one problem you have…
                        crontab started mm from a background script… BUT there is no EASY way to restart it without reboot…(which really isn’t needed) , unless you change the port like you found and start ANOTHER copy…
                        pm2 has ONE tiny drawback/benefit… its JOB is to START an app, AND KEEP IT RUNNING, if it fails for some reason, then it will get restarted… so, your old, crtl-q to quit, oops the app ends, pm2 will restart it
                        to work around that, pm2 is a commandline command, so ctrl-m to minimze MM, then open a terminal window,
                        ctrl-alt-t, and use pm2 status
                        to see the apps running under pm2 control
                        then using the name or number of the line with the app (I have a few apps under pm2 control)
                        id │ name                │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                        │ 8  │ MagicMirror         │ default     │ 2.32.0… │ fork    │ N/A      │ 0      │ 245… │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                        │ 7  │ MagicMirror 8       │ default     │ 2.31.0… │ fork    │ N/A      │ 0      │ 8    │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                        │ 10 │ MagicMirror-test    │ default     │ 2.37.0… │ fork    │ N/A      │ 0      │ 30   │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                        so to restart my current test version MM, I need to use the number 10, or the name MagicMirror-test
                        pm2 stop 10
                        pm2 start 10
                        or
                        pm2 restart 10
                        a learning thing, under linux, raspios, … by convention commandline commands are required to provide easy access help, by responding to the --help parm
                        pm2 --help
                        will do that… but ANY command should respond appropriately
                        — back to the problem
                        the mm.sh script he uses
                        npm run start
                        run start is a shortcut to npm run start
                        starting in release 2.35 we changed the startup to use the Raspberrypi default wayland display environment.
                        you can see this by examining the scripts: list in package.json (see below)
                        BUT many are not using that, still on x11… SO,
                        you need to change the script to use
                        npm run start:x11
                        (my mm.sh has that built in)
                        a part the package.json scripts list (I added comments, not allowed in a json file)
                          "scripts": {
                                        "config:check": "node js/check_config.js",
                                        "postinstall": "git clean -df fonts vendor modules/default",
                                        "install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                                        "install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier && npx playwright install chromium",
                                        "lint:css": "stylelint 'css/**/*.css' 'defaultmodules/**/*.css' --fix",
                                        "lint:js": "eslint --fix",
                                        "lint:markdown": "markdownlint-cli2 . --fix",
                                        "lint:prettier": "prettier . --write",
                                        "prepare": "[ -f node_modules/.bin/husky ] && husky || echo no husky installed.",
                                        "server": "node ./serveronly",
                                        "server:watch": "node ./serveronly/watcher.js",
                                        "start": "node --run start:wayland",    <----------------------------  start launch start:wayland
                                        "start:dev": "node --run start:wayland -- dev",
                                        "start:wayland": "WAYLAND_DISPLAY=\"${WAYLAND_DISPLAY:=wayland-1}\" ./node_modules/.bin/electron js/electron.js --ozone-platform=wayland", <-- start:wayland
                                        "start:wayland:dev": "node --run start:wayland -- dev",
                                        "start:windows": ".\\node_modules\\.bin\\electron js\\electron.js",
                                        "start:windows:dev": "node --run start:windows -- dev",
                                        "start:x11": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
                        anyhow after ALL THAT… i’d edit your existing mm.sh and increase the time from 20 to 30 to try and let the system settle down some more… this is just a test…
                        if you want to switch to my pm2 setup, you can edit the crontab, and add a pound sign/hash ‘#’ as the first char of your launch of mm.sh, this will make it a comment
                        reboot so MM is not running (there are cool ways to make tools(scripts) that can solve that problem, but not trying to go there
                        and then copy/paste the command to setup pm2 launch from my scripts repo… not git clone, just copy paste one line to a terminal window
                        see https://github.com/sdetweil/MagicMirror_scripts#add-using-pm2-to-autostart-magicmirror-at-bootup
                        ps, i’m only a couple years younger then you…
                        • T Offline
                          tommyk
                          wow, thats a lot of info, I will maybe have to ponder over that a while to let it sink in
                          I will get back to you when I have digested some of this info
                          and hopefully gained some knowledge
                          thank you again
                          tommyk
                            sdetweil @tommyk
                            @tommyk yeh, but I wanted to explain WHY and WHAT you can DO…
                            anytime, we’re here to help.
                            I do the scripts to help users get MM up and running, and KEEP their systems running… feel successful…
                            • T Offline
                              tommyk @sdetweil
                              @sdetweil Hi Sam
                              thank you
                              tommyk
                                sdetweil @tommyk
                                @tommyk glad you got it working
                                As for remote control , open another topic. I’m sure someone can help
