mmm remote control
mmm remote control
hi
I have installed mmm remote control so I can use my android phone to control my mirror
but am having trouble trying to understand the setup.
I have the qr code on my screen but when I scan it wont let me connect
err connection refused
could anyone please help
thanks in advance -
@tommyk by default, MM does not allow anything outside to connect…
this is from the address , and ipWhitelist settings in config.jsto allow outside access(phone, tablet, laptop) , change those values to these, and restart MM
address:"0.0.0.0", ipWhitelist:[],later you can tune the ipWhitelist to only allow your phone if you need to limit access from your local network.
the 0.0.0.0 for address means, if you have ethernet and wifi, listen on ALL adapters for incoming traffic…
you could use ONE of them by specifying the exact network adapter address instead of 0.0.0.0 , but usually this leads to unexpected confusion later… (I know I changed from localhost, it why cant I connect from X…) -
@sdetweil wow
that is fantastic, thanks sam
I will be playing around with this for a bit
thank you so much, you made my day
tommyk -
@sdetweil its all very confusing to me,
could you tell my what all these ips are for from the remote control instructions
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.0.42”, “::ffff:192.168.0.50”],"and this… http://192.168.xxx.xxx:8080/remote.html
thanks -
@tommyk sorry. Danger if I know. Maybe just examples of how it could be.
127.0.0.1 is the address for localhost
192.168. Is a typical default network address setupI leave it empty, cause I don’t want to force my devices to fixed addresses (dont want the mgmt job)
