    remote control help needed
    28 Posts 4 Posters 9.6k Views 4 Watching
    • T Offline
      tommyk @tommyk
      yeah sam,
      I am so confused, dont understand it
      but thanks for all your help
        sdetweil @tommyk
        @tommyk mm is meant to be a closed system on the wall…
        no one needs to access this, as its output only… SO
        the default config says ONLY apps INSIDE this SAME machine can access the MM server
        localhost is the name of the network connection (loop back)
        now, it so happens one could add controls to limit JUST ONE (or a few) machines too…
        this is the ipWhitelist
        but as we’ve seen that (output only with no external access) doesn’t work for a number of use cases.
        remote control, my mmm-config, …
        SO, changing the config
        address means listen for incoming requests on A network adapter, wifi OR ethernet…
        address=“192.168.2.106” (for my desktop ethernet address)
        but what if you have both? or more than one…
        you can ONLY put ONE address there…
        so there is a shortcut , “0.0.0.0”, means listen on ALL adapters, regardless their address…
        now… i’ll just make an example, not implying anything…
        you built this thing, and if ANYONE in your house could get in and fiddle with the MM parts, or others,
        they might take the system down or something else…
        kids that don’t know, but LOVE to explore…!!
        how can i keep THEM out…
        we I could limit access to ONLY MY phone, laptop,… then they couldn’t get in…
        so you could put your phone and laptop ip addresses in the ipWhitelist:[] list
        and then only YOU can get into the MM app system …
        the RemoteControl readme, mentions this change in the config…
        • T Offline
          tommyk @sdetweil
          @sdetweil yes, I understand what you are saying sam
          but if I put 0.0.0.0 as per instructions anyone can access it, right ?
          so I dont get why I cant
          phone app says error with javascript
          I am at my wits end lol
            sdetweil @tommyk
            @tommyk only anyone on your home network… not anyone in the world…
            I don’t know on the phone app… I didnt install the app…
            • T Offline
              tommyk @sdetweil
              @sdetweil yep right
              there is only me using the mirror
              so when I run MM
              RC shows the bar code and ip address
              when I scan code it tries to connect to app
              it says… error when trying to to load javascript file
                sdetweil @tommyk
                @tommyk ok, I just added the QR to mine,
                what is the address shown under the QR code??
                mine shows
                http://192.168.2.106:8090/remote.html
                which is my server address, and port
                here is those values in my config.js
                    address: "0.0.0.0",
                    port: 8090,
                    ipWhitelist: [],
                the app opens on my phone correctly
                same view as on my computer
                T 2 Replies Last reply Reply Quote 0
                • T Offline
                  tommyk @sdetweil
                  http://192.168.1.172:8080/remote.html
                  • T Offline
                    tommyk @sdetweil
                    @sdetweil let config = {
                    address: “0.0.0.0”,
                    port: 8080,
                    ipWhitelist: [],
                      sdetweil @tommyk
                      @tommyk and using
                      That url in browser on phone does not work? (Bypass qr)
                      But if you do
                      Brings up the MagicMirror page on phone?
                      • T Offline
                        tommyk @sdetweil
                        @sdetweil ok tried that. still no joy
                        will have to try again tomorrow
                        thanks again
                        tommyk
                        S T 2 Replies Last reply Reply Quote 0
                          sdetweil @tommyk
                          @tommyk no joy at what? Opening the MagicMirror page?
                          • T Offline
                            tommyk @tommyk
                            no joy at posting url in browser…
                            but the good news is… the app is now on my phone and jukebox is working
                            i was messing about on phone and config and I have no idea what i done
                            but I scanned the QR again and it connected.
                            only trouble is ,now I am afraid I might mess it up again…
                            without your help there is no way I would have gotten this thing to work
                            so thank you so much sam, you are a genius
                            ps … I have two MM setups, one in living room and one in bedroom
                            so now I am goin to try and put RC on other one…lol
                            wish me luck
                            thanks again
                            tommyk
                              sdetweil @tommyk
                              @tommyk glad you got it working. Hopefully the other system won’t be so hard.
