Solved Calendar Color
I am trying to add multiple calendars in one module and have them each have a different color, here is what I have so far, the maximumNumberOfDays is working, but the calendar is still showing up in the default color.
module: 'calendar', header: 'family', position: 'top_left', config: { colored: true, calendars: [ { symbol: 'male', url: 'xxxxxxx', }, ], color: '#f70000', maximumNumberOfDays: '14', } },
@billp100 based on the documentation it should look somehow like this
{ module: 'calendar', header: 'family', position: 'top_left', config: { colored: true, calendars: [ { symbol: 'male', url: 'xxxxxxx', color: '#f70000' } ], maximumNumberOfDays: 14 } },
@strawberry-3.141 I’ve tried it that way too with no luck.
@billp100 are you using the develop branch? this feature is currently not merged in the master branch
@strawberry-3.141 That’s it then. I didn’t realize that. Is there away for me to get that feature without having to start over?
@billp100 to use the develop branch you just have to do the following
cd ~/MagicMirror git fetch git checkout develop git pull npm install
@strawberry-3.141 I just did those steps and got an npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed message
Got it! thank you for your help
Great discussion. I have also added the options to add color the my two calendars, without success. Does anyone know if color is active in the current code? Here is my config setup:
{ module: 'calendar', header: 'My Calendar', position: 'top_left', config: { colored: true, calendars: [ { symbol: 'calendar ', url: 'https://calendar.google.com/calendar/ical/.../basic.ics', color: '#f70000' }, { symbol: 'calendar-o ', url: 'https://calendar.google.com/calendar/ical/.../basic.ics' color: '#04f448' }, ] } },
Many thanks
@Mitch1138 its still in the develop branch only
