    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 404.8k Views 23 Watching
    • zman3Z
      zman3
      That’s the error I always get also. I have the the contents of the folder zipped not the folder I left the keys as MagicMirror also and have index.handler selected.
        joanaz @savage_gr1nd
        @savage_gr1nd yeah, but it requires a physical pushbutton. I’m using AlexaPi with my own wake word, so I can activate Alexa by saying “Mirror mirror”.
          savage_gr1nd @joanaz
          @joanaz ahhhh. That sucks. I’m running wake word also. I just liked the idea of not having to run it in terminal. Then run mirror. Would have made rebooting simple and flawless. Lol
          J 1 Reply Last reply
            Journeytojah
            @joanaz @savage_gr1nd I had my certs both as MagicMirror and other names, made sure everything in the code is correct every time I changed anything.
            It just wont take it.
            I will go around this another way, I’m starting to lose interest in the whole tts concept and will go with something simpler using text :)
              @savage_gr1nd you can setup AlexaPi to run automatically after reboot
                joanaz @Journeytojah
                @Journeytojah @zman3 see whether this thread helps you.
                https://github.com/lorenwest/node-config/issues/275
                  @joanaz nice. I’ll look at switching over after work.
                  You need to work on the YouTube functions lol
                  • zman3Z
                    zman3
                    I tried all that last time you posted it with the exeption of process.env.NODE_CONFIG_DIR=‘/var/task/config’;
                      Journeytojah @joanaz
                      @joanaz been there, tried it… nothing worked…
                        joanaz @zman3
                        @zman3 no, that’s not the point, he uses the config library, we don’t. They mentioned some good points, such as “OSX makes node_modules readable only by the user so AWS cannot read it”, so you need to check the permission of your node_modules folder. And also make sure the node_modules inside the zip file is not empty.
                          savage_gr1nd @Journeytojah
                          @Journeytojah don’t sudo anything in this git. I made that mistake also.
                            Journeytojah @savage_gr1nd
                            @savage_gr1nd will try, i can imagine i had done that without realizing…
                            I like the response time of alexa, and would love to get this integrated, but like i said with less talking and more text.
                            Will try again some time and update…
                            • G
                              Gunwoody
                              I’m just revisiting this project as i was getting nowhere. I think i am now even more confused. Can someone tell me ‘where’ the certs folder needs copying to? Is it into the MagicMirror folder or is it somewhere else??
                              Thanks anyone :)
                              lucallmonL 1 Reply Last reply
                              • lucallmonL
                                lucallmon @Gunwoody
                                @Gunwoody I gave up on it too. The git is not user friendly and there’s no step by step guide. Pit that together and I’ll come back.
                                G 1 Reply Last reply
                                • G
                                  Gunwoody @lucallmon
                                  @lucallmon I’m just getting nowhere. I can setup MagicMirror2. I can configure it and get it to run no problem. Where it gets fuzzy is
                                  a) where does MMM-Mirroronthewall module go - is it inside the modules folder of MagicMirror2?
                                  b) Where do you run the aws-iot-device-sdk ?
                                  c) Where does the certs folder go?
                                  Just a simple step guide would be ace - anyone??
                                    joanaz @Gunwoody
                                    @Gunwoody @lucallmon sorry, you do have to have a little of programming experience and experience of using AWS services to setup this module. I do have a step by step guide in the companion Alexa skill repo, but it would still be hard for people without any software experience.
                                    • G
                                      Gunwoody
                                      I haven’t had any trouble setting up AWS/Lambda - i just can’t get it running loxcally - can you just answer the above questions for me.
                                      • G
                                        Gunwoody
                                        I’ve also got Alexa-avs running with sensory wakeword engine - so i’m not a complete idiot :)
                                        • G
                                          Gunwoody @Gunwoody
                                          @Gunwoody Hold the front page - i may have cracked it :)
                                          • G
                                            Gunwoody @Gunwoody
                                            @Gunwoody OK - getting closer.
                                            Upload of zip to Lambda finally worked ok.
                                            I can now enter Utterances in the service simulator on developer console and get a Lambda response
                                            I can see the response properly logged in Cloudwatch logs with no errors
                                            But i must be missing something fundamental because when i load Magic Mirror ir run perfectly but doesn’t seem to be listening for the Alexa wake words etc.
                                            Oh well getting closer all the time :)
                                            S M 2 Replies Last reply
                                            • 10
                                            • 6 / 10
