    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 400.5k Views 23 Watching
      Journeytojah @savage_gr1nd
      @savage_gr1nd will try, i can imagine i had done that without realizing…
      I like the response time of alexa, and would love to get this integrated, but like i said with less talking and more text.
      Will try again some time and update…
      • G
        Gunwoody
        I’m just revisiting this project as i was getting nowhere. I think i am now even more confused. Can someone tell me ‘where’ the certs folder needs copying to? Is it into the MagicMirror folder or is it somewhere else??
        Thanks anyone :)
        • L
          lucallmon @Gunwoody
          @Gunwoody I gave up on it too. The git is not user friendly and there’s no step by step guide. Pit that together and I’ll come back.
          G 1 Reply Last reply Reply Quote 1
          • G
            Gunwoody @lucallmon
            @lucallmon I’m just getting nowhere. I can setup MagicMirror2. I can configure it and get it to run no problem. Where it gets fuzzy is
            a) where does MMM-Mirroronthewall module go - is it inside the modules folder of MagicMirror2?
            b) Where do you run the aws-iot-device-sdk ?
            c) Where does the certs folder go?
            Just a simple step guide would be ace - anyone??
              joanaz @Gunwoody
              @Gunwoody @lucallmon sorry, you do have to have a little of programming experience and experience of using AWS services to setup this module. I do have a step by step guide in the companion Alexa skill repo, but it would still be hard for people without any software experience.
              • G
                Gunwoody
                I haven’t had any trouble setting up AWS/Lambda - i just can’t get it running loxcally - can you just answer the above questions for me.
                • G
                  Gunwoody
                  I’ve also got Alexa-avs running with sensory wakeword engine - so i’m not a complete idiot :)
                  • G
                    Gunwoody @Gunwoody
                    @Gunwoody Hold the front page - i may have cracked it :)
                    • G
                      Gunwoody @Gunwoody
                      @Gunwoody OK - getting closer.
                      Upload of zip to Lambda finally worked ok.
                      I can now enter Utterances in the service simulator on developer console and get a Lambda response
                      I can see the response properly logged in Cloudwatch logs with no errors
                      But i must be missing something fundamental because when i load Magic Mirror ir run perfectly but doesn’t seem to be listening for the Alexa wake words etc.
                      Oh well getting closer all the time :)
                        savage_gr1nd @Gunwoody
                        @Gunwoody mmm is in modules folder inside magicmirror. Sdk is inside mmm and also inside the skill located in the root. Certs is inside mmm and skill.
                        Iot runs on its own. Alexa-as you need to run your three terminal executions. Then npm start magic mirror after that.
                        Add mmm to magicmirror config and voila. :)
                        • G
                          Gunwoody
                          Thanks Savage - all that seems to be ok as far as i can see. I’ve got new problem now (that didn’t exist before) and i can’t seem to get to the bottom of it. When i start the wakeword engine i get this.
                          INFO:main: Starting Wake Word Agent
                          INFO:WakeWordAgent: State set to IDLE(2)
                          INFO:Initializing Sensory library | library name: TrulyHandsfree | library version: 5.0.0-avs.1 | model file: …/ext/resources/spot-alexa-rpi.snsr
                          WARNING:Library expires on: License expires on 28 May 2017 00:00:00 GMT
                          wakeWordAgent: pcm.c:694: snd_pcm_close: Assertion `pcm’ failed.
                          Aborted
                          • G
                            Gunwoody
                            OK fixed the sound issue. So i can talk to Alexa but it doesn’t seem to invoke the Mirror at all - any ideas??
                              @Gunwoody it only invokes mirror if you ask her to ask mirror.
                              Alexa, ask mirror to show me a video of…
                              Alexa, ask mirror to close calendar…
                              Etc.
                              • G
                                Gunwoody
                                I’m missing something fundamental - I can talk to Alexa (with the three terminals running). I can start Magic Mirror but they don’t seem to be connected. If i ask the question “alexa ask mirror find snow white” on the developer console i get the correct response "“ssml”: " Yes, my Queen, showing images of snow white. "
                                Some where i’m missing a link?? Back to the drawing board!!
                                • G
                                  Gunwoody
                                  I’ve got
                                  MMM-MirrorMirrorOntheWall in MagicMirror modules - check
                                  Certs inside MMM-MirrorMirrorOntheWall - check
                                  Is the Skill supposed to be inside the MagicMirror module somewhere???
                                  Is npm install for aws-iot-device-sdk run in 2 places???
                                  MirrorMirrorOnTheWallSkill/src
                                  and where else???
                                  Sorry for all the questions :)
                                    @Gunwoody also inside MMM-Mirrormirroronthewall located inside magicmirror/modules
                                      @Gunwoody sorry and no. Skill stays in your root. I was just saying the other thing about installing IoT
                                      • G
                                        Gunwoody
                                        Does the skill in your root actually get referenced or is it just a workspace to create the certs and zip file?
                                          @Gunwoody I belive a workspace. Because everything in it is essentially code to import to lambda. So opening a YouTube video runs the youtube-node imported into the function itself.
                                          • G
                                            Gunwoody
                                            Hi Savage, that’s what i figured. I need to figure out a way to test connectivity between all the different elements.
                                            Do you know where the wake word is set?
                                            • 10
                                            • 7 / 10
