    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 404.8k Views 23 Watching
      savage_gr1nd @Gunwoody
      @Gunwoody sorry and no. Skill stays in your root. I was just saying the other thing about installing IoT
      • G
        Gunwoody
        Does the skill in your root actually get referenced or is it just a workspace to create the certs and zip file?
          @Gunwoody I belive a workspace. Because everything in it is essentially code to import to lambda. So opening a YouTube video runs the youtube-node imported into the function itself.
          • G
            Gunwoody
            Hi Savage, that’s what i figured. I need to figure out a way to test connectivity between all the different elements.
            Do you know where the wake word is set?
              @Gunwoody there too many moving parts I think to see it all in one spot. But could be wrong lol
              And where wake word runs depends on which program/version of alexa-sdk you’re using. Like I use alexa-avs-sample-app so mine runs in its own terminal. But that’s soon to change. Gonna run Alexapi so it runs right off of boot instead. That’s my project for tonight lol
              • G
                Gunwoody
                I’m using the same. You’ll have to let me know how it goes with AlexaPi - might be an easier route to take :)
                  @Gunwoody will do :)
                  • zman3Z
                    zman3
                    holy crap I finally got the skill part working. took me doing the whole install npm and everything and uploading the zip all from windows instead of the raspberry. weird
                    • zman3Z
                      zman3
                      of course now i have the problem of it not doing anything with the mirror :/
                      • G
                        Gunwoody
                        Exactly the same here
                          @Gunwoody @zman3 while you were running npm install on the skills dependencies you didn’t sudo npm install right? That blocks amazons access.
                          • zman3Z
                            zman3
                            Nope just regular pi usr
                              savage_gr1nd @zman3
                              Hmm. Add MMM-mirrormirror I to MagicMirror config.js? And also have it installed in the magicmirror/modules folder?
                              • zman3Z
                                zman3
                                Yes and yes I’ll try again tonight ,I’m at work which interferes with my play time
                                • zman3Z
                                  zman3
                                  tried it from the start again the skill its self works but when she says closing module it doesnt close ,no text gets displayed or if I search for snow white images she says displaying but i never see anything.
                                  J 1 Reply Last reply
                                  • A
                                    artifactdev
                                    @joanaz Can you provide a how to or screencast how to get this working with an echo dot? For me it’s not clear how to connect the module with the lambda function which will be triggered by the skill.
                                      joanaz @zman3
                                      @zman3 you copied your certs folder to the mirror module folder? check your terminal to see any error messages
                                      D 1 Reply Last reply
                                        joanaz @artifactdev
                                        @artifactdev that’s what AWS IoT device gateway is for. Just setup the skill and the mirror module as instructed
                                        • zman3Z
                                          zman3
                                          went through redid the awsiot set up did the start.sh copied the certs to the certs folder in the magic mirror module put those in the skill and re uploaded the zip to lambda still get nothing showing on the mirror
                                          lucallmonL 1 Reply Last reply
                                          • lucallmonL
                                            lucallmon @zman3
                                            @zman3 It’s because there’s no guide. It’s just figure it out yourself. You know this isn’t a well-organized module when you look at how many posts/replies are in it.
                                            • 10
                                            • 8 / 10
