npm install fails
I have not been able to run the mirror because every time I try to start it fails here is the log.
0 info it worked if it ends with ok 1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ] 2 info using npm@3.10.10 3 info using node@v6.10.0 4 verbose run-script [ 'prestart', 'start', 'poststart' ] 5 info lifecycle magicmirror@2.1.0~prestart: magicmirror@2.1.0 6 silly lifecycle magicmirror@2.1.0~prestart: no script for prestart, continuing 7 info lifecycle magicmirror@2.1.0~start: magicmirror@2.1.0 8 verbose lifecycle magicmirror@2.1.0~start: unsafe-perm in lifecycle true 9 verbose lifecycle magicmirror@2.1.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/root/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin 10 verbose lifecycle magicmirror@2.1.0~start: CWD: /root/MagicMirror 11 silly lifecycle magicmirror@2.1.0~start: Args: [ '-c', 'electron js/electron.js' ] 12 silly lifecycle magicmirror@2.1.0~start: Returned: code: 1 signal: null 13 info lifecycle magicmirror@2.1.0~start: Failed to exec start script 14 verbose stack Error: magicmirror@2.1.0 start: `electron js/electron.js` 14 verbose stack Exit status 1 14 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16) 14 verbose stack at emitTwo (events.js:106:13) 14 verbose stack at EventEmitter.emit (events.js:191:7) 14 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14) 14 verbose stack at emitTwo (events.js:106:13) 14 verbose stack at ChildProcess.emit (events.js:191:7) 14 verbose stack at maybeClose (internal/child_process.js:877:16) 14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5) 15 verbose pkgid magicmirror@2.1.0 16 verbose cwd /root/MagicMirror 17 error Linux 4.4.34-v7+ 18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start" 19 error node v6.10.0 20 error npm v3.10.10 21 error code ELIFECYCLE 22 error magicmirror@2.1.0 start: `electron js/electron.js` 22 error Exit status 1 23 error Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'. 23 error Make sure you have the latest version of node.js and npm installed. 23 error If you do, this is most likely a problem with the magicmirror package, 23 error not with npm itself. 23 error Tell the author that this fails on your system: 23 error electron js/electron.js 23 error You can get information on how to open an issue for this project with: 23 error npm bugs magicmirror 23 error Or if that isn't available, you can get their info via: 23 error npm owner ls magicmirror 23 error There is likely additional logging output above. 24 verbose exit [ 1, true ]after looking around on the forum I decided to try npm install which returns one line
npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.I cannot make any sense of this and have tried updating electron and nodejs and i installed MM with the line on the home page I am using a rasperry pi 3 with the latest version of raspien non lite version.
