    Alexa light ring
    6 Posts 3 Posters 2.8k Views 4 Watching
    • A
      abdiz1
      Hi
      Is there a module, that replaces the Alexa activated sound, with a flashing light circle? i would like to have the module on the bottom of the mirror. And when i activate Alexa, this light circle appear on screen. Just like Alexa Echo
      (am a noob, so dont even care to ask me sudo stuff :) )
        jeffkdanies
        You can find the Reset button at the base of your device. After you press and hold the Reset button, the light ring on your Echo device turns orange, and then blue. Wait for the light ring to turn off and on again. The light ring then turns orange, and your device enters setup mode.
          sdetweil @jeffkdanies
          @jeffkdanies he wants it on screen when he talks to the alexa module. to indicate alexa is listening
          i’m sure you can do this with css…
            @abdiz1 I think something like this should be doable (bigger of course)
            https://codepen.io/SDETWEIL/pen/XWJxQYK
              how did that 3 year old topic get to the top again?
                jeffkdanies
                You can find the Reset button at the base of your device. After you press and hold the Reset button, blue light filter for pc the light ring on your Echo device turns orange, and then blue. Wait for the light ring to turn off and on again. The light ring then turns orange, and your device enters setup mode.
