    Display web widget on mirror through iFrame?
    60 Posts 9 Posters 77.7k Views 9 Watching
    • Mitch1138M
      Mitch1138
      Thanks for the tip, but I didn’t have a lot of success. I punted and installed Auto Refresh Plus extension in Chrome. Running in server mode I can use this to refresh the page on a predefined time cycle.
        roramirez Core Contributors
        Is more easy than that. Check out the function and use of scheduleUpdate function.
        https://github.com/MichMich/MagicMirror/blob/master/modules/default/currentweather/currentweather.js
        Is of currentweather module.
        • michael24hM
          michael24h
          hello
          I also heve problem with iframer. This is what put in my config. but can’t make auto play with adding -->&autoplay=1
          			module: 'iFrame',
          			position: 'bottom_left', // This can be any of the regions.
                          url:  src="https://www.youtube.com/embed/I7hV-5GHWhc",
                          width: '360px', // Optional. Default: 100%
                          height: '360px', //Optional. Default: 100px
          • michael24hM
            michael24h
            @roramirez said in Display web widget on mirror through iFrame?:
            &autoplay=1
            Anyone
            • michael24hM
              michael24h
              already resolved the problem, replace “&” with “?” in the url the video.
              • L
                looolz
                same problem, still not working. Loading the module breaks the file. Here is my code:
                        module: 'iFrame',
                        position: 'bottom_bar', // This can be any of the regions.
                                url: "http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png"
                                width: "828px" // Optional. Default: 100%
                                height: "272px" //Optional. Default: 100px
                The only detail I’ve found in the documentation that seems a little off, is that it suggests the URL formatting to be as such:
                url: "http:http://example.com/"
                But that still doesn’t work.
                • michael24hM
                  michael24h
                  @looolz said in Display web widget on mirror through iFrame?:
                  this one work on my clock
                  module: ‘iFrame’,
                  position: ‘bottom_left’, // This can be any of the regions.
                  // See ‘Configuration options’ for more information.
                  url: “http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png”,
                  width: ‘220%’, // Optional. Default: 100%
                  height: ‘360px’, //Optional. Default: 100px
                  • michael24hM
                    michael24h
                                url: "http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png",
                    L 1 Reply Last reply
                    • L
                      looolz @michael24h
                      @michael24h aaaaaaaah!
                      Yes! That worked, thanks!
                      • michael24hM
                        michael24h
                        no worries
                        • L
                          looolz @michael24h
                          @michael24h By the way, the example config from the readme.md also lacks the comma.
                          • michael24hM
                            michael24h
                            Usual thing good use to
                            • F
                              fox
                              Does the page i want to embedd should meet minimum requirements?
                              I checked here: https://validator.w3.org/#validate_by_input and no problems found. But iFrame-module does not show the page
                              Issues With MMM-WatchDog known?
                              https://forum.magicmirror.builders/post/29827
                              Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                              michael24hM 1 Reply Last reply
                              • michael24hM
                                michael24h @fox
                                @fox
                                can you post config
                                F 1 Reply Last reply
                                • F
                                  fox @michael24h
                                  @michael24h
                                                          module: "MMM-iFrameReload",
                                                          header: "",
        url: "http://192.168.188.30/indexsmall.html",
        width: "100%",
        height: "150px"
                                  page:
                                  http://pastebin.com/KjhxUpYZ
                                  • michael24hM
                                    michael24h
                                    will do if you do:
                                    open frame in new tab
                                    and then paste in:
                                    url:src=“http://cdnx.tribalfusion.com/media/6869616/assets/tab2/tab2.html”,
                                    • michael24hM
                                      michael24h
                                      Or
                                      http://cdnx.tribalfusion.com/media/6869616/assets/video1.mp4
                                      if you like this one :-)
                                      • michael24hM
                                        michael24h
                                        @fox said in Display web widget on mirror through iFrame?:
                                        url: “http://192.168.188.30/indexsmall.html”,
                                        this won’t work url: “http://192.168.188.30/indexsmall.html”,
                                        only way :
                                        ->index or home.html
                                        • F
                                          fox
                                          @michael24h said in Display web widget on mirror through iFrame?:
                                          You mean that i change my config of iFrame with your URL?
                                          like this?
        header: "",
        url: "http://cdnx.tribalfusion.com/media/6869616/assets/video1.mp4",
        width: "100%",
        height: "150px"
                                          • michael24hM
                                            michael24h
                                            yes
                                            page like index.html or home.html need be live.
                                            if I wanna add home page my home pninter:
                                            need somtning like this
                                            http://192.168.0.27/sws/index.html this will.
                                            • 2 / 3
