    Display web widget on mirror through iFrame?
    60 Posts 9 Posters 75.8k Views 9 Watching
      roramirez Core Contributors @Mitch1138
      @Mitch1138 There no way to force update using iFrame. Its a something is possible add a option for autorefresh. I think will not difficult added. Why do you no try?
      • Mitch1138M Offline
        Mitch1138
        Thanks, I like your confidence in my abilities! I will keep working on trying to find a way to update the link.
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Mitch1138
          @Mitch1138 as a hint, check how other modules update their content.
            Mitch1138
            Thanks for the tip, but I didn’t have a lot of success. I punted and installed Auto Refresh Plus extension in Chrome. Running in server mode I can use this to refresh the page on a predefined time cycle.
              Is more easy than that. Check out the function and use of scheduleUpdate function.
              https://github.com/MichMich/MagicMirror/blob/master/modules/default/currentweather/currentweather.js
              Is of currentweather module.
              • michael24hM Offline
                michael24h
                hello
                I also heve problem with iframer. This is what put in my config. but can’t make auto play with adding -->&autoplay=1
                			module: 'iFrame',
                			position: 'bottom_left', // This can be any of the regions.
                                url:  src="https://www.youtube.com/embed/I7hV-5GHWhc",
                                width: '360px', // Optional. Default: 100%
                                height: '360px', //Optional. Default: 100px
                  michael24h
                  @roramirez said in Display web widget on mirror through iFrame?:
                  &autoplay=1
                  Anyone
                    michael24h
                    already resolved the problem, replace “&” with “?” in the url the video.
                    • L Offline
                      looolz
                      same problem, still not working. Loading the module breaks the file. Here is my code:
                              module: 'iFrame',
                              position: 'bottom_bar', // This can be any of the regions.
                                      url: "http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png"
                                      width: "828px" // Optional. Default: 100%
                                      height: "272px" //Optional. Default: 100px
                      The only detail I’ve found in the documentation that seems a little off, is that it suggests the URL formatting to be as such:
                      url: "http:http://example.com/"
                      But that still doesn’t work.
                        michael24h
                        @looolz said in Display web widget on mirror through iFrame?:
                        this one work on my clock
                        module: ‘iFrame’,
                        position: ‘bottom_left’, // This can be any of the regions.
                        // See ‘Configuration options’ for more information.
                        url: “http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png”,
                        width: ‘220%’, // Optional. Default: 100%
                        height: ‘360px’, //Optional. Default: 100px
                          michael24h
                                      url: "http://www.yr.no/sted/Norge/Oslo/Oslo/Oslo/meteogram.png",
                          • L Offline
                            looolz @michael24h
                            @michael24h aaaaaaaah!
                            Yes! That worked, thanks!
                              michael24h
                              no worries
                              • L Offline
                                looolz @michael24h
                                @michael24h By the way, the example config from the readme.md also lacks the comma.
                                  michael24h
                                  Usual thing good use to
                                  • F Offline
                                    fox
                                    Does the page i want to embedd should meet minimum requirements?
                                    I checked here: https://validator.w3.org/#validate_by_input and no problems found. But iFrame-module does not show the page
                                    Issues With MMM-WatchDog known?
                                    https://forum.magicmirror.builders/post/29827
                                    Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                    michael24hM 1 Reply Last reply Reply Quote 0
                                      michael24h @fox
                                      @fox
                                      can you post config
                                      • F Offline
                                        fox @michael24h
                                        @michael24h
        module: "MMM-iFrameReload",
        header: "",
        url: "http://192.168.188.30/indexsmall.html",
        width: "100%",
        height: "150px"
                                        page:
                                        http://pastebin.com/KjhxUpYZ
                                          michael24h
                                          will do if you do:
                                          open frame in new tab
                                          and then paste in:
                                          url:src=“http://cdnx.tribalfusion.com/media/6869616/assets/tab2/tab2.html”,
                                            michael24h
                                            Or
                                            http://cdnx.tribalfusion.com/media/6869616/assets/video1.mp4
                                            if you like this one :-)
                                            • 2 / 3
